Hello there. I use my local server on raspberry !
I use my custom domain and i have open the ports in my router!
I can connect from outside my network but not from inside…
Any good idea or solution ???
Thanks!
Thanks!
It is called NAT loopback. You need to check your router settings in order to find out if your router supports that. Enabling it should resolve this problem.
If not, you have 2 options:
Thanks for the response!
I have DD wrt firmware can you help me with that?
It didn’t works
