trên Blynk v2 có authtoken k nhỉ ?
để mình dùng api của blynk
help!!!
Yes there is, go to the console ( blynk.cloud ) then devices, choose a device and you should see device info tab.
i use api
Blynk HTTP RESTful API · Apiary.
it need authtoken but i don’t have authtoken in Blynk console
Have you created a device ion the web console, then created a device based on that template?
If you have then when you view the device and select the Device Info tab then the auth token is displayed in the left hand column, about half way down the screen.
It’s also displayed in a box labelled “Firmware Configuration” in the top right of that same screen.
also, you’re using blynk legacy http api. in blynk IOT it’s different, check this out
https://docs.blynk.io/en/blynk.cloud/https-api-overview
oh thanks bro
blynk legacy is dead
RIP blynk legacy
