I want to use wifi module esp8266 to get temperature reading from thermal sensor on the Blynk app on my phone. Below is my code:
This is a simple demo of sending and receiving some data.
Be sure to check out other examples!
#define BLYNK_TEMPLATE_ID "TMPL36H7YvY4F"
#define BLYNK_TEMPLATE_NAME "Test"
#define BLYNK_AUTH_TOKEN "xS6gNoCI_fngvgxH9vXGAoPKq_W-l6BF"
char ssid[] = "iPhone";
char pass[] = "abcdabcd";
// This function is called every time the Virtual Pin 0 state changes
BLYNK_WRITE(V0)
// Set incoming value from pin V0 to a variable
int value = param.asInt();
// Update state
Blynk.virtualWrite(V1, value);
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
Blynk.virtualWrite(V2, millis() / 1000);
//Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass, "blynk.cloud", 80);
//Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass, IPAddress(192,168,1,100), 8080);
timer.setInterval(10000L, myTimerEvent);
// to avoid delay() function!
I am getting the following error on running this:
Exception (4):
epc1=0x4000dd07 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
>>>stack>>>
ctx: cont
sp: 3ffffdc0 end: 3fffffd0 offset: 0160
3fffff20: 00000000 00002c0d 00c49ba5 0032ef08
3fffff30: 00000000 00ac12d7 0000464f 00001f60
3fffff40: 00002c0d 00002c0d 00000000 00001f60
3fffff50: 0000464f 00000000 00000000 4020545e
3fffff60: 00000000 00000000 3ffeeef0 40201290
3fffff70: 00000000 000000bb 3ffeef98 00001f60
3fffff80: 0000464f 3ffeeef0 00000000 402021ac
3fffff90: 40208294 7e57240a feefeffe feefeffe
3fffffa0: feefeffe feefeffe feefeffe 3ffef120
3fffffb0: 3fffdad0 00000000 3ffef0f4 40204c54
3fffffc0: feefeffe feefeffe 3fffdab0 40100e75
<<<stack<<<
In addition, on the web version of Blynk, it is displaying that the device is offline.
How to fix these problems?
