Display non-numeric data on gauge widget
hi!
i use a gauge widget in one of my project to display temperature.
however, in case if the sensor fails on the go, or gets disconnected, i would like to display an error message on the gauge, instead of the temperature. but i observed, that if i send a string, it does not displays. this is normal behaviour, or bug? if normal behaviour, there are any workarounds for this? (not super important, but it would be nice)
thanks!
Can’t you display an extreme value on the gauge? Let’s say if you sensor goes from 0 -100, display 150 if there is an error?
Or make a LED indicator :slight_smile:
thanks, yes this is what i’ve done so far. it displays -999 c.
just it was a bit strange that this widget does not displays strings.
Is there no label which you can change with the set properties thing? And maybe color?
there is a label of course, but it is soo small, that not easy to read anyway. i will go with the -999c value display. that is the best solution up to now.
