You mean “export”, I think. but it isn’t a whole flow then, just what is selected. Give me some time, I need to go through it.
can you give me whole your program (in private if you want) ? so i can exploit the theme ?
You mean whole NODE-RED stuff? That’s what I want to do, just wait a bit, as I need to copy it from server. It’s not secret - only tokens, which I gonna reset here…
okay i’ll be waiting thanks
OK, here it is:
[{"id":"37d56206.0fdc9e","type":"tab","label":"Sonoff DUAL #2","disabled":false,"info":"Flow for Sonoff DUAL switch - house's front lights"},{"id":"e58ef59.66a3308","type":"tab","label":"Sonoff 4ch","disabled":false,"info":"Flow for 4ch SONOFF device"},{"id":"b64588a7.104e78","type":"tab","label":"domek gościnny","disabled":false,"info":""},{"id":"8c817c66.e66f5","type":"tab","label":"Monitor kotła","disabled":false,"info":""},{"id":"6ce581cb.c8c52","type":"tab","label":"Dust sensor","disabled":false,"info":""},{"id":"a6431d8.6b825e","type":"tab","label":"Aux","disabled":false,"info":""},{"id":"95356bc2.d75ca8","type":"mqtt-broker","z":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willPayload":"","birthTopic":"","birthQos":"0","birthPayload":""},{"id":"782ab728.45f3c8","type":"blynk-ws-client","z":"","name":"Sonoff #2","path":"ws://localhost:8080/websockets","key":"","dbg_all":false,"dbg_read":false,"dbg_write":false,"dbg_notify":false,"dbg_mail":false,"dbg_prop":false,"dbg_sync":false,"dbg_bridge":false,"dbg_low":false,"dbg_pins":"","multi_cmd":false,"proxy_type":"no","proxy_url":""},{"id":"e24f9445.cccd78","type":"ui_group","z":"","name":"Poziom sygn. (RSSI)","tab":"41c374bd.4b7fcc","order":3,"disp":true,"width":"4"},{"id":"a6164922.4950c8","type":"ui_base","theme":{"name":"theme-dark","lightTheme":{"default":"#0094CE","baseColor":"#0094CE","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":true,"reset":false},"darkTheme":{"default":"#097479","baseColor":"#327ae7","baseFont":"Lucida Sans Unicode,Lucida Grande,sans-serif","edited":true,"reset":false},"customTheme":{"default":"#4B7930","baseColor":"#097479","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"},"themeState":{"base-color":{"default":"#097479","value":"#327ae7","edited":true},"page-titlebar-backgroundColor":{"value":"#327ae7","edited":false},"page-backgroundColor":{"value":"#111111","edited":false},"page-sidebar-backgroundColor":{"value":"#ffffff","edited":false},"group-textColor":{"value":"#76a6ef","edited":false},"group-borderColor":{"value":"#555555","edited":false},"group-backgroundColor":{"value":"#333333","edited":false},"widget-textColor":{"value":"#eeeeee","edited":false},"widget-backgroundColor":{"value":"#327ae7","edited":false},"widget-borderColor":{"value":"#333333","edited":false},"base-font":{"value":"Lucida Sans Unicode,Lucida Grande,sans-serif"}}},"site":{"name":"Node-RED Dashboard","hideToolbar":"false","allowSwipe":"false","dateFormat":"DD/MM/YYYY","sizes":{"sx":50,"sy":50,"gx":6,"gy":6,"cx":6,"cy":6,"px":0,"py":0}}},{"id":"41c374bd.4b7fcc","type":"ui_tab","z":"","name":"Home","icon":"dashboard"},{"id":"c02cd95b.338c88","type":"ui_group","z":"","name":"Temperatura","tab":"41c374bd.4b7fcc","order":5,"disp":true,"width":"6","collapse":false},{"id":"d66ff1d4.2bc76","type":"ui_group","z":"","name":"Oświetlenie","tab":"41c374bd.4b7fcc","order":1,"disp":true,"width":"4","collapse":false},{"id":"5fd40025.abb28","type":"ui_group","z":"","name":"Wykresy","tab":"41c374bd.4b7fcc","order":4,"disp":true,"width":"8"},{"id":"86663659.31d338","type":"ui_group","z":"","name":"Pyły zawieszone","tab":"41c374bd.4b7fcc","order":2,"disp":true,"width":"4"},{"id":"f2ae4bf1.ae0688","type":"ui_tab","z":"","name":"Jakość powietrza","icon":"blur_on"},{"id":"40af5220.16d1dc","type":"ui_group","z":"","name":"Wykresy","tab":"f2ae4bf1.ae0688","disp":true,"width":"14","collapse":false},{"id":"4d258579.8b07dc","type":"blynk-ws-client","z":"","name":"Climate monitor","path":"ws://localhost:8080/websockets","key":"","dbg_all":false,"dbg_read":false,"dbg_write":false,"dbg_notify":false,"dbg_mail":false,"dbg_prop":false,"dbg_sync":false,"dbg_bridge":false,"dbg_low":false,"dbg_pins":"","multi_cmd":false,"proxy_type":"no","proxy_url":""},{"id":"c829260a.5a45f8","type":"mqtt-broker","z":"","broker":"localhost","port":"8440","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willPayload":"","birthTopic":"","birthQos":"0","birthPayload":""},{"id":"3a5cccb9.0d61f4","type":"blynk-ws-client","z":"","name":"GSM board","path":"ws://localhost:8080/websockets","key":"","dbg_all":false,"dbg_read":false,"dbg_write":false,"dbg_notify":false,"dbg_mail":false,"dbg_prop":false,"dbg_sync":false,"dbg_bridge":false,"dbg_low":false,"dbg_pins":"","multi_cmd":false,"proxy_type":"no","proxy_url":""},{"id":"af53a00f.cf502","type":"mqtt in","z":"37d56206.0fdc9e","name":"Sonoff #2, Relay 1","topic":"light/frontside/relay/0","qos":"2","broker":"95356bc2.d75ca8","x":170,"y":115,"wires":[["2d181c6e.0e06f4","c389e45b.f614d8"]]},{"id":"bed7ca05.9fe9c8","type":"schedex","z":"37d56206.0fdc9e","name":"","suspended":false,"lat":"51.0394","lon":"17.0599","ontime":"dusk","ontopic":"light/frontside/relay/1/set","onpayload":"1","onoffset":"+10","onrandomoffset":0,"offtime":"22:30","offtopic":"light/frontside/relay/1/set","offpayload":"0","offoffset":"0","offrandomoffset":0,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":true,"sun":true,"x":190,"y":340,"wires":[["89963a97.50f188"]]},{"id":"2d181c6e.0e06f4","type":"blynk-ws-out-write","z":"37d56206.0fdc9e","name":"","pin":"0","pinmode":0,"client":"782ab728.45f3c8","x":440,"y":115,"wires":[]},{"id":"144f4bd7.14f1b4","type":"blynk-ws-in-write","z":"37d56206.0fdc9e","name":"Gniazda zewn.","pin":"0","pin_all":false,"client":"782ab728.45f3c8","x":180,"y":240,"wires":[["1d1c840.b2ae07c"]]},{"id":"1d1c840.b2ae07c","type":"mqtt out","z":"37d56206.0fdc9e","name":"Sonoff #2, Relay 1","topic":"light/frontside/relay/0/set","qos":"","retain":"","broker":"95356bc2.d75ca8","x":450,"y":240,"wires":[]},{"id":"4bd13d49.d583c4","type":"blynk-ws-in-write","z":"37d56206.0fdc9e","name":"Ośw. podjazdu","pin":"1","pin_all":false,"client":"782ab728.45f3c8","x":180,"y":400,"wires":[["89963a97.50f188"]]},{"id":"89963a97.50f188","type":"mqtt out","z":"37d56206.0fdc9e","name":"Sonoff #2, Relay 2","topic":"light/frontside/relay/1/set","qos":"","retain":"","broker":"95356bc2.d75ca8","x":550,"y":400,"wires":[]},{"id":"25837f7c.18a76","type":"mqtt in","z":"37d56206.0fdc9e","name":"Sonoff #2, Relay 2","topic":"light/frontside/relay/1","qos":"2","broker":"95356bc2.d75ca8","x":170,"y":621,"wires":[["2bcaa14d.801c4e","c9e34ffe.e6526","94876201.6909e"]]},{"id":"2bcaa14d.801c4e","type":"blynk-ws-out-write","z":"37d56206.0fdc9e","name":"","pin":"1","pinmode":0,"client":"782ab728.45f3c8","x":540,"y":620,"wires":[]},{"id":"4caf836a.2f804c","type":"mqtt in","z":"37d56206.0fdc9e","name":"Sonoff #2 RSSI","topic":"light/frontside/rssi","qos":"0","broker":"95356bc2.d75ca8","x":180,"y":51,"wires":[["ddd748ff.35cee8"]]},{"id":"1c3636e3.99de49","type":"mqtt out","z":"e58ef59.66a3308","name":"Sonoff 4ch, RLY1","topic":"light/halogen/relay/0/set","qos":"","retain":"","broker":"95356bc2.d75ca8","x":530,"y":280,"wires":[]},{"id":"a5a8d62c.fb7e78","type":"mqtt out","z":"e58ef59.66a3308","name":"Sonoff 4ch, RLY 2","topic":"light/halogen/relay/1/set","qos":"","retain":"","broker":"95356bc2.d75ca8","x":530,"y":340,"wires":[]},{"id":"a058624.ba5e4a","type":"mqtt out","z":"e58ef59.66a3308","name":"Sonoff 4ch, RLY 3","topic":"light/halogen/relay/2/set","qos":"","retain":"","broker":"95356bc2.d75ca8","x":530,"y":400,"wires":[]},{"id":"3c70251c.7c73ca","type":"mqtt out","z":"e58ef59.66a3308","name":"Sonoff 4ch, RLY 4","topic":"light/halogen/relay/3/set","qos":"","retain":"","broker":"95356bc2.d75ca8","x":530,"y":460,"wires":[]},{"id":"8e7c75d4.23b478","type":"blynk-ws-in-write","z":"e58ef59.66a3308","name":"Sonoff 4ch V10","pin":"10","client":"782ab728.45f3c8","x":320,"y":280,"wires":[["1c3636e3.99de49"]]},{"id":"caf49891.39f778","type":"blynk-ws-in-write","z":"e58ef59.66a3308","name":"Sonoff 4ch, V11","pin":"11","client":"782ab728.45f3c8","x":320,"y":340,"wires":[["a5a8d62c.fb7e78"]]},{"id":"b5081d4e.eac53","type":"blynk-ws-in-write","z":"e58ef59.66a3308","name":"Sonoff 4ch, V12","pin":"12","client":"782ab728.45f3c8","x":320,"y":400,"wires":[["a058624.ba5e4a"]]},{"id":"d9a2a3e3.90e5e","type":"blynk-ws-in-write","z":"e58ef59.66a3308","name":"Sonoff 4ch, V13","pin":"13","client":"782ab728.45f3c8","x":320,"y":460,"wires":[["3c70251c.7c73ca"]]},{"id":"8d34128a.e4027","type":"blynk-ws-out-write","z":"e58ef59.66a3308","name":"","pin":"13","pinmode":0,"client":"782ab728.45f3c8","x":520,"y":220,"wires":[]},{"id":"31d96fed.04dc8","type":"blynk-ws-out-write","z":"e58ef59.66a3308","name":"","pin":"12","pinmode":0,"client":"782ab728.45f3c8","x":520,"y":160,"wires":[]},{"id":"96b9043.e3278f8","type":"blynk-ws-out-write","z":"e58ef59.66a3308","name":"","pin":"11","pinmode":0,"client":"782ab728.45f3c8","x":520,"y":100,"wires":[]},{"id":"7268c2ad.313eec","type":"blynk-ws-out-write","z":"e58ef59.66a3308","name":"","pin":"10","pinmode":"0","client":"782ab728.45f3c8","x":520,"y":40,"wires":[]},{"id":"7d3ff181.9e5ca","type":"mqtt in","z":"e58ef59.66a3308","name":"","topic":"light/halogen/relay/3","qos":"2","broker":"95356bc2.d75ca8","x":310,"y":220,"wires":[["8d34128a.e4027","8f985f84.20167"]]},{"id":"380e08af.9a2908","type":"mqtt in","z":"e58ef59.66a3308","name":"","topic":"light/halogen/relay/2","qos":"2","broker":"95356bc2.d75ca8","x":310,"y":160,"wires":[["31d96fed.04dc8","edb347cf.0e47e8"]]},{"id":"3728aef0.0e2a42","type":"mqtt in","z":"e58ef59.66a3308","name":"","topic":"light/halogen/relay/1","qos":"2","broker":"95356bc2.d75ca8","x":310,"y":100,"wires":[["96b9043.e3278f8","a0118356.fb743"]]},{"id":"28754e8a.999b52","type":"mqtt in","z":"e58ef59.66a3308","name":"","topic":"light/halogen/relay/0","qos":"2","broker":"95356bc2.d75ca8","x":310,"y":40,"wires":[["7268c2ad.313eec","8612a9bf.401d28"]]},{"id":"1e040012.9b2c","type":"mqtt in","z":"e58ef59.66a3308","name":"RSSI read","topic":"light/halogen/rssi","qos":"0","broker":"95356bc2.d75ca8","x":340,"y":520,"wires":[["465d900d.c37db"]]},{"id":"490fc82d.2b18b8","type":"delay","z":"37d56206.0fdc9e","name":"","pauseType":"delay","timeout":"60","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":450,"y":480,"wires":[[]]},{"id":"94876201.6909e","type":"function","z":"37d56206.0fdc9e","name":"Switch state","func":"if (msg.payload == \"1\") {\n var msg1 = { payload:\"0\" };\n}\nreturn [msg1]","outputs":1,"noerr":0,"x":290,"y":480,"wires":[["490fc82d.2b18b8"]]},{"id":"ddd748ff.35cee8","type":"ui_text","z":"37d56206.0fdc9e","group":"e24f9445.cccd78","order":0,"width":"0","height":"0","name":"","label":"Moduł ośw. frontu","format":"{{msg.payload}}dBi","layout":"row-spread","x":450,"y":51,"wires":[]},{"id":"2a0dba39.e01f46","type":"ui_text","z":"e58ef59.66a3308","group":"e24f9445.cccd78","order":0,"width":0,"height":0,"name":"","label":"Moduł halogenów","format":"{{msg.payload}}dBi","layout":"row-spread","x":670,"y":520,"wires":[]},{"id":"1b27c1fc.6c003e","type":"mqtt in","z":"e58ef59.66a3308","name":"temperatura","topic":"light/halogen/temperature","qos":"2","broker":"95356bc2.d75ca8","x":330,"y":620,"wires":[["40ad196e.53a868"]]},{"id":"4f0980fc.93f52","type":"ui_gauge","z":"e58ef59.66a3308","name":"","group":"c02cd95b.338c88","order":3,"width":"3","height":"3","gtype":"gage","title":"Strych","label":"°C","format":"{{value| number:1}}","min":"-10","max":"40","colors":["#0252b3","#29a400","#cc4242"],"seg1":"","seg2":"","x":690,"y":640,"wires":[]},{"id":"8612a9bf.401d28","type":"ui_switch","z":"e58ef59.66a3308","name":"","label":"Halogen LEWY","group":"d66ff1d4.2bc76","order":1,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"","style":"","onvalue":"1","onvalueType":"str","onicon":"","oncolor":"","offvalue":"0","offvalueType":"str","officon":"","offcolor":"","x":740,"y":40,"wires":[["1c3636e3.99de49"]]},{"id":"a0118356.fb743","type":"ui_switch","z":"e58ef59.66a3308","name":"","label":"Halogen OGRÓD","group":"d66ff1d4.2bc76","order":2,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"","style":"","onvalue":"1","onvalueType":"str","onicon":"","oncolor":"","offvalue":"0","offvalueType":"str","officon":"","offcolor":"","x":750,"y":100,"wires":[["a5a8d62c.fb7e78"]]},{"id":"edb347cf.0e47e8","type":"ui_switch","z":"e58ef59.66a3308","name":"","label":"Halogen PRAWY","group":"d66ff1d4.2bc76","order":3,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"","style":"","onvalue":"1","onvalueType":"str","onicon":"","oncolor":"","offvalue":"0","offvalueType":"str","officon":"","offcolor":"","x":750,"y":160,"wires":[["a058624.ba5e4a"]]},{"id":"8f985f84.20167","type":"ui_switch","z":"e58ef59.66a3308","name":"","label":"Halogen FRONT","group":"d66ff1d4.2bc76","order":4,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"","style":"","onvalue":"1","onvalueType":"str","onicon":"","oncolor":"","offvalue":"0","offvalueType":"str","officon":"","offcolor":"","x":750,"y":220,"wires":[["3c70251c.7c73ca"]]},{"id":"c9e34ffe.e6526","type":"ui_switch","z":"37d56206.0fdc9e","name":"","label":"Oświetlenie podjazdu","group":"d66ff1d4.2bc76","order":5,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"","style":"","onvalue":"1","onvalueType":"str","onicon":"","oncolor":"","offvalue":"0","offvalueType":"str","officon":"","offcolor":"","x":360,"y":540,"wires":[["89963a97.50f188"]]},{"id":"c389e45b.f614d8","type":"ui_switch","z":"37d56206.0fdc9e","name":"","label":"Gniazda zewn.","group":"d66ff1d4.2bc76","order":6,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"","style":"","onvalue":"1","onvalueType":"str","onicon":"","oncolor":"","offvalue":"0","offvalueType":"str","officon":"","offcolor":"","x":320,"y":180,"wires":[["1d1c840.b2ae07c"]]},{"id":"465d900d.c37db","type":"function","z":"e58ef59.66a3308","name":"Display 'czekaj' if retained","func":"if (msg.retain === true) {\n var msg1 = { payload:\"czekaj...\" };\n}\nelse {\n var msg1 = {payload:msg.payload};\n}\nreturn [msg1];","outputs":1,"noerr":0,"x":490,"y":580,"wires":[["2a0dba39.e01f46"]]},{"id":"40ad196e.53a868","type":"function","z":"e58ef59.66a3308","name":"Display 'czekaj' if retained","func":"if (msg.retain === true) {\n var msg1 = { payload:\"czekaj...\" };\n}\nelse {\n var msg1 = {payload:msg.payload};\n}\nreturn [msg1];","outputs":1,"noerr":0,"x":490,"y":680,"wires":[["4f0980fc.93f52"]]},{"id":"ba64456a.95d338","type":"mqtt in","z":"b64588a7.104e78","name":"","topic":"domek/temperatura","qos":"2","broker":"95356bc2.d75ca8","x":241,"y":311,"wires":[["7ee0836f.b95c7c","52ea35e9.f5e41c"]]},{"id":"429949d8.5b0a08","type":"mqtt in","z":"b64588a7.104e78","name":"","topic":"domek/RSSI","qos":"2","broker":"95356bc2.d75ca8","x":263,"y":393,"wires":[["bff165c9.65b1b8"]]},{"id":"bff165c9.65b1b8","type":"function","z":"b64588a7.104e78","name":"Display 'czekaj' if retained","func":"if (msg.retain === true) {\n var msg1 = { payload:\"czekaj...\" };\n}\nelse {\n var msg1 = {payload:msg.payload};\n}\nreturn [msg1];","outputs":1,"noerr":0,"x":470,"y":393,"wires":[["82cf74e2.624e68"]]},{"id":"82cf74e2.624e68","type":"ui_text","z":"b64588a7.104e78","group":"e24f9445.cccd78","order":0,"width":0,"height":0,"name":"","label":"domek","format":"{{msg.payload}}dBi","layout":"row-spread","x":679,"y":393,"wires":[]},{"id":"7ee0836f.b95c7c","type":"ui_gauge","z":"b64588a7.104e78","name":"","group":"c02cd95b.338c88","order":4,"width":"3","height":"3","gtype":"gage","title":"domek gościnny","label":"°C","format":"{{value}}","min":"-10","max":"40","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":709,"y":313,"wires":[]},{"id":"d39e22df.24682","type":"mqtt in","z":"8c817c66.e66f5","name":"","topic":"remeha_monitor/Tzewn","qos":"2","broker":"95356bc2.d75ca8","x":240,"y":240,"wires":[["53512176.d86d4"]]},{"id":"7e063dee.6c2474","type":"mqtt in","z":"8c817c66.e66f5","name":"","topic":"remeha_monitor/Twewn","qos":"2","broker":"95356bc2.d75ca8","x":240,"y":300,"wires":[["de2ba755.f0e638"]]},{"id":"926cb223.d7c93","type":"mqtt in","z":"8c817c66.e66f5","name":"","topic":"remeha_monitor/TCWU","qos":"2","broker":"95356bc2.d75ca8","x":240,"y":360,"wires":[["39dcae90.23cf12"]]},{"id":"d44b1c2.5b55de","type":"mqtt in","z":"8c817c66.e66f5","name":"","topic":"remeha_monitor/RSSI","qos":"2","broker":"95356bc2.d75ca8","x":240,"y":420,"wires":[["d99c4d9d.658a7"]]},{"id":"53512176.d86d4","type":"ui_gauge","z":"8c817c66.e66f5","name":"","group":"c02cd95b.338c88","order":1,"width":"3","height":"3","gtype":"gage","title":"Temp. zewnętrzna","label":"C","format":"{{value}}","min":"-10","max":"40","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":530,"y":240,"wires":[]},{"id":"de2ba755.f0e638","type":"ui_gauge","z":"8c817c66.e66f5","name":"","group":"c02cd95b.338c88","order":2,"width":"3","height":"3","gtype":"gage","title":"Temp. wewnętrzna","label":"C","format":"{{value}}","min":"-10","max":"40","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":530,"y":300,"wires":[]},{"id":"39dcae90.23cf12","type":"ui_gauge","z":"8c817c66.e66f5","name":"","group":"c02cd95b.338c88","order":5,"width":"3","height":"3","gtype":"gage","title":"Temperatura CWU","label":"C","format":"{{value}}","min":"20","max":"60","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":530,"y":360,"wires":[]},{"id":"a1b96994.fe3e68","type":"ui_text","z":"8c817c66.e66f5","group":"e24f9445.cccd78","order":0,"width":0,"height":0,"name":"","label":"Monitor kotła","format":"{{msg.payload}}dBi","layout":"row-spread","x":550,"y":420,"wires":[]},{"id":"d99c4d9d.658a7","type":"function","z":"8c817c66.e66f5","name":"Display 'czekaj' if retained","func":"if (msg.retain === true) {\n var msg1 = { payload:\"czekaj...\" };\n}\nelse {\n var msg1 = {payload:msg.payload};\n}\nreturn [msg1];","outputs":1,"noerr":0,"x":430,"y":500,"wires":[["a1b96994.fe3e68"]]},{"id":"93f19a88.1d5168","type":"ui_chart","z":"b64588a7.104e78","name":"","group":"5fd40025.abb28","order":0,"width":"8","height":"9","label":"temperatura","chartType":"line","legend":"true","xformat":"dd HH:mm","interpolate":"linear","nodata":"oczekiwanie na dane...","dot":false,"ymin":"","ymax":"","removeOlder":"3","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"colors":["#1eb5b5","#6fff55","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"x":690,"y":220,"wires":[[],[]]},{"id":"508a6bd0.534df4","type":"mqtt in","z":"6ce581cb.c8c52","name":"","topic":"piwnica/pm2dot5","qos":"0","broker":"95356bc2.d75ca8","x":120,"y":200,"wires":[["63c5ff1c.99db","c075bcb8.5448c"]]},{"id":"63c5ff1c.99db","type":"ui_gauge","z":"6ce581cb.c8c52","name":"","group":"86663659.31d338","order":0,"width":0,"height":0,"gtype":"gage","title":"PM2.5","label":"ug/m3","format":"{{value}}","min":0,"max":"150","colors":["#00b500","#e6e600","#ca3838"],"seg1":"36","seg2":"60","x":550,"y":200,"wires":[]},{"id":"f86e5071.a510b","type":"ui_gauge","z":"6ce581cb.c8c52","name":"","group":"86663659.31d338","order":0,"width":0,"height":0,"gtype":"gage","title":"PM10","label":"ug/m3","format":"{{value}}","min":0,"max":"200","colors":["#00b500","#e6e600","#ca3838"],"seg1":"60","seg2":"100","x":550,"y":260,"wires":[]},{"id":"ccc44414.e7ea48","type":"mqtt in","z":"b64588a7.104e78","name":"","topic":"remeha_monitor/Tzewn","qos":"2","broker":"95356bc2.d75ca8","x":240,"y":220,"wires":[["52ea35e9.f5e41c"]]},{"id":"52ea35e9.f5e41c","type":"change","z":"b64588a7.104e78","name":"","rules":[{"t":"change","p":"topic","pt":"msg","from":"remeha_monitor/Tzewn","fromt":"str","to":"ZEWNĘTRZNA","tot":"str"},{"t":"change","p":"topic","pt":"msg","from":"light/halogen/temperature","fromt":"str","to":"STRYCH","tot":"str"},{"t":"change","p":"topic","pt":"msg","from":"domek/temperatura","fromt":"str","to":"DOMEK GOŚĆ.","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":220,"wires":[["93f19a88.1d5168"]]},{"id":"df653250.f12a8","type":"mqtt in","z":"6ce581cb.c8c52","name":"","topic":"piwnica/rssi","qos":"0","broker":"95356bc2.d75ca8","x":170,"y":140,"wires":[["8aa9ba30.3b7598"]]},{"id":"8aa9ba30.3b7598","type":"ui_text","z":"6ce581cb.c8c52","group":"e24f9445.cccd78","order":0,"width":0,"height":0,"name":"","label":"Czujnik PMS","format":"{{msg.payload}}dBi","layout":"row-spread","x":570,"y":140,"wires":[]},{"id":"84375c94.5d74b","type":"ui_text","z":"a6431d8.6b825e","group":"e24f9445.cccd78","order":0,"width":0,"height":0,"name":"","label":"Aux device","format":"{{msg.payload}}","layout":"row-spread","x":150,"y":120,"wires":[]},{"id":"5da94453.4b64fc","type":"mqtt in","z":"b64588a7.104e78","name":"temperatura","topic":"light/halogen/temperature","qos":"2","broker":"95356bc2.d75ca8","x":270,"y":140,"wires":[["52ea35e9.f5e41c"]]},{"id":"dcb44792.9e3e78","type":"mqtt in","z":"6ce581cb.c8c52","name":"","topic":"piwnica/pm10","qos":"0","broker":"95356bc2.d75ca8","x":110,"y":260,"wires":[["f86e5071.a510b","c075bcb8.5448c"]]},{"id":"c075bcb8.5448c","type":"change","z":"6ce581cb.c8c52","name":"","rules":[{"t":"change","p":"topic","pt":"msg","from":"piwnica/pm2dot5","fromt":"str","to":"PM2,5","tot":"str"},{"t":"change","p":"topic","pt":"msg","from":"piwnica/pm10","fromt":"str","to":"PM10","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":380,"y":320,"wires":[["3039eb29.2af384"]]},{"id":"3039eb29.2af384","type":"ui_chart","z":"6ce581cb.c8c52","name":"","group":"40af5220.16d1dc","order":0,"width":0,"height":0,"label":"Pyły zawieszone","chartType":"line","legend":"true","xformat":"dd HH:mm","interpolate":"linear","nodata":"Oczekiwanie na dane...","dot":false,"ymin":"","ymax":"","removeOlder":"3","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"colors":["#be148f","#de9f29","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"x":590,"y":320,"wires":[[],[]]},{"id":"73e076d.be87388","type":"mqtt in","z":"6ce581cb.c8c52","name":"","topic":"piwnica/temperature","qos":"2","broker":"95356bc2.d75ca8","x":150,"y":380,"wires":[["c24875a0.8741e8"]]},{"id":"c24875a0.8741e8","type":"ui_gauge","z":"6ce581cb.c8c52","name":"","group":"c02cd95b.338c88","order":0,"width":"3","height":"3","gtype":"gage","title":"Piwnica","label":"°C","format":"{{value}}","min":"-10","max":"40","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":560,"y":380,"wires":[]},{"id":"8a372c00.5e11e8","type":"tcp in","z":"a6431d8.6b825e","name":"","server":"server","host":"","port":"15002","datamode":"single","datatype":"utf8","newline":",","topic":"motionAlert","base64":false,"x":150,"y":50,"wires":[["8fcf9737.cd2f78"]]},{"id":"8fcf9737.cd2f78","type":"debug","z":"a6431d8.6b825e","name":"","active":true,"console":"false","complete":"true","x":540,"y":50,"wires":[]},{"id":"5b194c8e.4bd794","type":"mqtt in","z":"37d56206.0fdc9e","name":"","topic":"#","qos":"2","broker":"c829260a.5a45f8","x":767,"y":228,"wires":[[]]},{"id":"76de6eeb.f9d52","type":"blynk-ws-zergba","z":"a6431d8.6b825e","name":"ZeRGBa","pin":0,"client":"3a5cccb9.0d61f4","x":70,"y":280,"wires":[["d6d1695c.3484c8"]]},{"id":"566ebcb2.0f4fb4","type":"ui_colour_picker","z":"a6431d8.6b825e","name":"","label":"","group":"d66ff1d4.2bc76","format":"rgb","outformat":"object","showSwatch":false,"showPicker":true,"showValue":false,"showHue":true,"showAlpha":false,"showLightness":true,"dynOutput":"false","order":0,"width":0,"height":0,"passthru":false,"topic":"","x":260,"y":280,"wires":[["9b123bf9.bb00e8"]]},{"id":"ba2b1357.20dcc","type":"ui_switch","z":"a6431d8.6b825e","name":"","label":"Kolor LED","group":"d66ff1d4.2bc76","order":0,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"","style":"","onvalue":"1","onvalueType":"str","onicon":"","oncolor":"","offvalue":"0","offvalueType":"str","officon":"","offcolor":"","x":320,"y":450,"wires":[["60894c77.bfd604"]]},{"id":"60894c77.bfd604","type":"http request","z":"a6431d8.6b825e","name":"V1","method":"GET","ret":"txt","url":"http://localhost:8080/token/update/V1?value={{{payload}}}","tls":"","x":590,"y":450,"wires":[[]]},{"id":"74a2c667.6b0958","type":"template","z":"a6431d8.6b825e","name":"create HTTP API headers","field":"headers","fieldType":"msg","format":"handlebars","syntax":"plain","template":"Content-Type:application/json","output":"str","x":500,"y":280,"wires":[["2123d918.ba58b6"]]},{"id":"2123d918.ba58b6","type":"http request","z":"a6431d8.6b825e","name":"V0 update","method":"PUT","ret":"txt","url":"http://192.168.1.130:8080/token/update/V0","tls":"","x":610,"y":390,"wires":[[]]},{"id":"9b123bf9.bb00e8","type":"template","z":"a6431d8.6b825e","name":"create RGB payload","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"[\n\"{{payload.r}}\",\n\"{{payload.g}}\",\n\"{{payload.b}}\"\n]","output":"json","x":360,"y":390,"wires":[["74a2c667.6b0958"]]},{"id":"e9d80160.6d59a","type":"blynk-ws-in-write","z":"a6431d8.6b825e","name":"","pin":"1","pin_all":0,"client":"3a5cccb9.0d61f4","x":100,"y":450,"wires":[["ba2b1357.20dcc"]]},{"id":"d6d1695c.3484c8","type":"template","z":"a6431d8.6b825e","name":"parse RGB","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{hex}}","output":"str","x":120,"y":390,"wires":[["566ebcb2.0f4fb4"]]},{"id":"4e2c32e7.fc6e0c","type":"blynk-ws-in-write","z":"a6431d8.6b825e","name":"read 'pressure' pin","pin":"3","pin_all":0,"client":"4d258579.8b07dc","x":290,"y":520,"wires":[["a30c7519.11b6e8"]]},{"id":"a30c7519.11b6e8","type":"ui_gauge","z":"a6431d8.6b825e","name":"","group":"86663659.31d338","order":0,"width":0,"height":0,"gtype":"gage","title":"ciśnienie atm.","label":"hPa","format":"{{value}}","min":"970","max":"1050","colors":["#0012f4","#0de401","#e22121"],"seg1":"1000","seg2":"1030","x":540,"y":520,"wires":[]},{"id":"d1771d67.fbfc8","type":"blynk-ws-out-sync","z":"a6431d8.6b825e","name":"sync 'pressure' pin","pin":"3","pinmode":0,"client":"4d258579.8b07dc","x":550,"y":580,"wires":[]},{"id":"def53300.b2515","type":"inject","z":"a6431d8.6b825e","name":"Trigger every 5 min","topic":"","payload":"1","payloadType":"str","repeat":"300","crontab":"","once":true,"x":280,"y":580,"wires":[["d1771d67.fbfc8"]]},{"id":"1c3de103.3b4e9f","type":"ui_text_input","z":"a6431d8.6b825e","name":"","label":"GSM Terminal input","group":"e24f9445.cccd78","order":0,"width":0,"height":0,"passthru":false,"mode":"text","delay":"0","topic":"","x":290,"y":670,"wires":[["eac0f536.351f68"]]},{"id":"eac0f536.351f68","type":"http request","z":"a6431d8.6b825e","name":"V10","method":"GET","ret":"txt","url":"http://localhost:8080/token/update/V10?value={{{payload}}}","tls":"","x":510,"y":670,"wires":[[]]}]
appreciate that
In node red? Never did it, so can’t help. It have to be as easy as redirecting formatted payload to file. The only way I’m exporting csv’s is from SuperChart via email. Rarely using it though.
