sometimes a value change doesn’t make sense in the current state of the client. So it would be really great if widget could be disabled temporarliy by the client.
For a better understanding, here is an example.
- I have motor driver with two input modes, PWM and digital (I2C).
- I have a Button to switch between those two modes.
- For PWM Mode i have a slider to set the value,
- for digital i have a dropdown to select certain effects
I’m using a DRV2605 Haptic Controller from Adafriut btw.
Now i would like to disable either the slider or the dropdown, to show the user that they have no effect currently.
Cu
David
