This code is working. It activates relays and toggles LED widgets. The problem is it will not set the digital pins to high or low unless I first use a button widget set to the digital pin. Then it works as expected. I have to do this each time the processor is turned off and on.
Serial.begin(38400);
Blynk.setDeviceName("Blynk");
Blynk.begin(auth);
BLYNK_WRITE(V0) {
int pinValue = param.asInt();
if (pinValue == 1)
digitalWrite(2, HIGH);
Blynk.virtualWrite(V1, 255);
Blynk.virtualWrite(V2, 0);
delay(200);
digitalWrite(2, LOW);
BLYNK_WRITE(V4) {
if (pinValue == 1)
digitalWrite(13, HIGH);
Blynk.virtualWrite(V1, 0);
Blynk.virtualWrite(V2, 255);
delay(200);
digitalWrite(13, LOW);
BLYNK_WRITE(V5) {
if (pinValue == 1)
digitalWrite(12, HIGH);
Blynk.virtualWrite(V8, 255);
Blynk.virtualWrite(V9, 0);
delay(200);
digitalWrite(12, LOW);
BLYNK_WRITE(V10) {
if (pinValue == 1)
digitalWrite(14, HIGH);
Blynk.virtualWrite(V9, 255);
Blynk.virtualWrite(V8, 0);
delay(200);
digitalWrite(14, LOW);
