o1y
April 4, 2018, 7:51pm
1
Hey,
I have a strange problem. I use a Virtual pin V1 to manually control a relay which is on GPIO12 via a switch button. The problem is that GPIO12 is never switched when using digitalWrite(). I only get a LOW/HIGH when I switch in the Buttons Output Settings between V1 to D12 and back. I know this sounds crazy, but that’s the only way it works. And that works only until I restart the NodeMCU …
#include <BlynkSimpleEsp8266_SSL.h>
int RELAIS = 12;
void RELAIS_OPEN() {
digitalWrite(RELAIS, LOW);
Serial.println("Open");
Blynk.virtualWrite(V1, 1);
void RELAIS_CLOSE() {
digitalWrite(RELAIS, HIGH);
Serial.println("Closed");
Blynk.virtualWrite(V1, 0);
BLYNK_WRITE(V1) {
int pinData = param.asInt();
if (pinData == 1) {
RELAIS_OPEN();
int delayedOff = timer.setTimeout(3000, RELAIS_CLOSE);
char auth[] = "xxxx";
char ssid[] = "xxxx";
char pass[] = "xxxx";
Any ideas?
Try changing this
to this
o1y
April 4, 2018, 8:08pm
3
Unfortunately, that makes no difference. Even if I write it without the variable
You need to add this to your setup() as well. Hopefully this does the trick.
pinMode(RELAIS, OUTPUT); // set pin to output
digitalWrite(RELAIS, HIGH); // set initial state of relay (CLOSED)
I believe at startup the pins default as INPUTs
Gunner
April 4, 2018, 8:21pm
5
o1y:
You have to follow these commands with a virtual sync command in order to actually process the new value.
EDIT what you have is fine for just a display or changing a button state.
But if you want to “automatically” have the button "pressed’ after a state change, then the sync is needed.
o1y
April 4, 2018, 8:23pm
6
This works! Thank you so much!
o1y
April 4, 2018, 8:29pm
7
Yea, it was just a quick hack for showing the button state change. But thanks for your help
ankit
September 18, 2022, 2:09pm
8
can i use this code for Wemos D1 mini pro.
Which code, and what is it that you are trying to achieve?
Are you using Blynk Legacy or the new Blynk IoT?
