Digital Pin D5 and D6 don't work
Hello Blynk Community,
while i was trying to control my DC motor with a L9110s my digital Pins D5 and D6 suddenly stopped working. I loaded an (empty) new sketch on my board to see if there is a mistake in my code, but the pins still didn’t react.
When i am measuring the outputs the digital pin D5 always shows 3,3V. The pin D6 always shows 1,6V. Even if i try to change the status in the code, the pins always remain in output 3,3V and 1,6V.
I tried a lot to control them or change their status, but they never seem to react. I don’t get it. Do I need to define a certain pinMode in the code? Or are the pins just destroyed?
PS: It is just with these two pins. All the other ones work.
Best regards
Timo
What specific ESP8266 device are you using?
billd
Hey Bill
i am using is a NodeMCU Lua Amica Modul V2 ESP8266 ESP-12F WIFI Wifi Development Board.
If you are using actual code for pin control, AKA digitalWrite() etc, then YES you need the appropriate pinMode() for each pin used.
Post your sketch, we can have a look.
billd
#include <ESP8266WebServer.h>
const int A1A = D5; // WarmwasserkugelhahnA
const int A1B = D6; // WarmwasserkugelhahnA
const int B1A = D4; // KaltwasserkugelhahnB
const int B1B = D7; // KaltwasserkugelhahnB
// temperature sensor
int Thermistorstatus;
int ThermistorPin = 0;
int Vo;
float R1 = 10000;
float logR2, R2, T;
float c1 = 1.009249522e-03, c2 = 2.378405444e-04, c3 = 2.019202697e-07;
// starting loop from simple timer
void WarmwasserKugelhahn(){
  WarmwasserKugelhahnA ('R');// Turn motor A to RIGHT
  delay(3000);
  WarmwasserKugelhahnA ('0');
  Serial.println("Stopp");
  delay(3000);
void KaltwasserKugelhahn(){
  KaltwasserKugelhahnB ('L');// Turn motor B to RIGHT
  delay(3000);
  KaltwasserKugelhahnB ('0');
  delay(3000);
// loop for temperature sensor
void Temperaturmesser(){
  Vo = analogRead(ThermistorPin); // ESP8266 is reading the temperature on analog Pin Number AD0 and declarates it to integer "Vo".
  R2 = R1 * (1023.0 / (float)Vo - 1.0);  //following is the calculation for the temperature.
  logR2 = log(R2);
  T = (1.0 / (c1 + c2*logR2 + c3*logR2*logR2*logR2));
  T = T - 273.15;
  T = (T * 9.0)/ 5.0 + 32.0;
  T = (T - 32)* 5/9;
  Serial.print("Temperature: "); // printing to serial monitor.
  Serial.print(T);
  Serial.println(" °C");
  delay(500); // repeating the process every 1/2 seconds.
void WarmwasserKugelhahnA(char d){
  if(d =='R'){
    digitalWrite(A1A,LOW);
    digitalWrite(A1B,HIGH);
  }else if (d =='L'){
    digitalWrite(A1A,HIGH);
    digitalWrite(A1B,LOW);
  }else{
void KaltwasserKugelhahnB(char d){
    if(d =='R'){
      digitalWrite(B1A,LOW);
      digitalWrite(B1B,HIGH);
    }else if(d =='L'){
      digitalWrite(B1A,HIGH);
      digitalWrite(B1B,LOW);
    }else{
  pinMode(A1A,OUTPUT);
  pinMode(A1B,OUTPUT);
  pinMode(B1A,OUTPUT);
  pinMode(B1B,OUTPUT);
  delay(3000);
  timer.setInterval(1000L, WarmwasserKugelhahn);
  timer.setInterval(1000L, KaltwasserKugelhahn);
  timer.setInterval(1000L, Temperaturmesser);
  timer.run(); // runs the simple Timer library
They could be floating. Did you try a simple non blynk sketch that
digitalWrite(D5,LOW);
Then test the voltage…
