I have a Plduino. It has a Esp8266 02. on Serial2 on the Mega that its bonded to.
// Hardware Serial on Mega, Leonardo, Micro…
#define EspSerial Serial2
I have flashed the ESP with AT firmware.
I looked at the Plduino schematic and it shows, the RX and TX pins of ESP8266 on 16,17 of the Mega.
I also tried
//#include <SoftwareSerial.h>
//SoftwareSerial EspSerial(16, 17); // RX, TX
I keep getting.
[604] Connecting to Blynk Sever
[1614] Failed to disable Echo
I have been trying to use the blynk hardware sheild example.
Thank you for any input on this.
psoro
October 15, 2017, 7:51pm
2
cory3640:
This is an old message, first of all, update your Blynk library!
I updated Blynk Library .the ESP is not responding.
psoro
October 15, 2017, 8:19pm
4
Are you sure you installed the last one?
In this release
Improvements & new features:
More readable warning “ESP is not responding” instead of “Cannot disable echo”.
BlynkTimer updated
Table.updateRow() support
Major fixes:
BLYNK_APP_CONNECTED, BLYNK_APP_DISCONNECTED (bug #313)
Big improvements on Particle stability (+ fix of bug #322)
Updated examples & documentation
Full list of supported hardware is here .
Grab the update here: https://github.com/blynkkk/blynk-library/releases/latest
BTW, if you like Blynk, don…
Check again please.
[19]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ / '/
/ / /_, / // //_
/ __/ v0.4.8 on Arduino Mega
[1618] ESP is not responding
psoro
October 15, 2017, 8:41pm
6
cory3640:
16,17 of the Mega
This is the Serial2, there’s no need to use “sofware serial”, use “hardware serial”.
Serial: 0 (RX) and 1 (TX); Serial 1: 19 (RX) and 18 (TX); Serial 2: 17 (RX) and 16 (TX); Serial 3: 15 (RX) and 14 (TX)
I still get ESP is not responding
I know the ESP8266 works becasue when I load factory Plduino firmware it produces an AP, and I can connect.
I just cant seem to get it to work with Blynk.
psoro
October 15, 2017, 8:48pm
9
how do i post my code properly?
psoro
October 15, 2017, 8:54pm
12
Mate, you should check the “search” tool more often…
#include <ESP8266_Lib.h>
char auth[] = "075ff68aa34b4e98827ee93c99fa284e";
char ssid[] = "Blynk Sever";
char pass[] = "12345678";
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
// Set ESP8266 baud rate
Blynk.begin(auth, wifi, ssid, pass, "192.168.1.113", 8442);
psoro
October 15, 2017, 9:03pm
14
The code seems to be OK for me, what about the Baud-rate for the ESP?
I dont know the baud rate of the ESP, I have tried setting it to 9600 115200 74880, nothing seems to work. I flashed it with NODEMCU flasher and put v1.3.03_ATfirmware.bin on it at 74800. it successfully flashed
I followed this tutorial http://community.mydevices.com/t/connecting-the-plcduino-to-cayenne/3689
this person was able to modify the blynk espsheild example.
psoro
October 15, 2017, 9:15pm
17
This is really important, otherwise your system won’t work…
Below you can find the tool I used to use to flash the ESP8266 when my set-up was using Arduino+ESP:
Give it a try…
I can upload to Dropbox the file used. It should be ok nowadays…
Let me know…
I know for sure my baud rate is 74880. still no luck.
Gunner
October 15, 2017, 9:53pm
19
Odd setting, I use #define ESP8266_BAUD 115200
for my MEGA/ESP-01 setup
Then you need to use that same BAUD, that your ESP is set for, in your sketch as well.
psoro
20
In that case, you should change your code:
to
#define ESP8266_BAUD 74880
