I am finding it impossible to connect to Blynk server. I have been trying for months. I’m using Wemos mini. I have a led widget on the console and Iphone it say’s not connected but I can turn it on and off from the console and vise versa. Here is my code, Thank you.
You’ll need:
- Blynk IoT app (download from App Store or Google Play)
- ESP8266 board
example.
#define BLYNK_TEMPLATE_ID "XXXXXXX"
#define BLYNK_DEVICE_NAME "Test"
#define BLYNK_AUTH_TOKEN "XXXXXXXXX"
char ssid[] = "Network";
char pass[] = "Stub";
// Select your pin with physical button
const int btnPin = 2;
WidgetLED led3(V0);
// V0 LED Widget represents the physical button state
boolean btnState = false;
void buttonLedWidget()
// Read button
boolean isPressed = (digitalRead(btnPin) == LOW);
// If state has changed...
if (isPressed != btnState) {
if (isPressed) {
led3.on();
Serial.println("Led ON");
led3.off();
Serial.println("Led OFF");
btnState = isPressed;
Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
// to avoid delay() function!
