DHT22+temperature&humidity-widget problem random crashes
Hi Everyone,
I have a problem with my selfmade weatherstation.
I use the dht22 humidity&temperature sensor and the wemos d1 mini to get temperature and humidity data to my blynk-app,
But There is a problem when i Turn on the whole station, the Widgets for humidity and temperature randomly Crash.
I don’t know bis to fix it. I also got a lux-sensor which is connectet by an I2C Bus ans it’s working fine.
I Hope you Guys can help me.
Thanks in advance
Janjy
Can’t help without code to debug.
#include <Ethernet.h>
#include <TimeLib.h>
#include <Wire.h>
#include <Makerblog_TSL45315.h>
#include <DHT.h>
#include <RCSwitch.h>
#include <WidgetRTC.h>
#define DHTPIN 12 //pin gpio 12 in sensor
#define DHTTYPE DHT22   // DHT 22 Change this if you have a DHT11
#define TRANSMITTER_PIN    13
DHT dht(DHTPIN, DHTTYPE);
RCSwitch mySwitch = RCSwitch();
Makerblog_TSL45315 luxsensor = Makerblog_TSL45315(TSL45315_TIME_M4);
char auth[] = "1c6af0a64246421690ce62168b1b00db";  // Put your Auth Token here. (see Step 3 above)
WidgetRTC rtc;
void clockDisplay()
  // You can call hour(), minute(), ... at any time
  // Please see Time library examples for details
  Serial.print(currentTime);
  Serial.print(" ");
  Serial.print(currentDate);
  Serial.println();
  // Send time to the App
  Blynk.virtualWrite(V7, currentTime);
  // Send date to the App
  Blynk.virtualWrite(V6, currentDate);
   Blynk.begin(auth, "Nix_da_ihr_WLAN-Schnorrer", "Nicht_Geheim");
    // Wait until connected
  luxsensor.begin();
    mySwitch.enableTransmit(TRANSMITTER_PIN);
     rtc.begin();
  timer.setInterval(2000L, sendUptime);
  timer.setInterval(10000L, clockDisplay);
  timer.setInterval(6000L, sendUptimelux);
BLYNK_WRITE(V0) {
  if(param.asInt() == 0) {
    mySwitch.switchOff("11011", "00011");
    mySwitch.switchOn("11011", "00011");
BLYNK_WRITE(V1) {
    delay(2000);
void sendUptime()
   //Read the Temp and Humidity from DHT
  float h = dht.readHumidity();
  Blynk.virtualWrite(10, t); // virtual pin
  Blynk.virtualWrite(12, t); // virtual pin
  Blynk.virtualWrite(11, h); // virtual pin
  Blynk.virtualWrite(13, h); // virtual pin
void sendUptimelux()
 uint32_t lux = luxsensor.readLux();
  Blynk.virtualWrite(14, lux); // virtual pin
  Blynk.virtualWrite(15, lux); // virtual pin
  if (hour() == 13 && minute() == 43 && second() == 00)
    delay(2000);
Is you widget set to PUSH ?
No i use the gauge Widget and the labled value Display where i can’t Set push
You can set the reading rate on both on PUSH
Ah ok i see should i set it to push ?
yes try that
I’ve tried it but same result…
what else can i so ?
What does it do when it crashes, does your device disconnect ?
No only the temperature and humidity Widget Shows me “nan°C” randomly
have you tried to reboot your device ?
Yeah multiple times, but still the same
That’s correct. DHT sensor may fail. In that case it will return NAN. You need to guard your code with :
  if (isnan(t)) {
    return;
You should also get rid of all delay() calls, and move the lines above Blynk.run() and timer.run() into a function. Then using timers to run a function every xxxx milliseconds achieves the purpose of the delays, but using millis().
