Hey there guys, I have an issue with my project I mean I can upload to the board, because it seems that I don’t have the whole libraries, but I recently downloaded them. So please help me.
This is the code, I got it from the sketch browser of blynk.
this is the code
Release v1.3.2 · blynkkk/blynk-library · GitHub
http://twitter.com/blynk_app
Note: This only works on Android!
iOS does not support Bluetooth 2.0 Serial Port Profile
You may need to pair the module with your smartphone
via Bluetooth settings. Default pairing password is 1234
Feel free to apply it to any other example. It’s simple!
NOTE: Bluetooth support is in beta!
This example shows how value can be pushed from Arduino to
the Blynk App.
WARNING :
For this example you’ll need Adafruit DHT sensor libraries:
GitHub - adafruit/Adafruit_Sensor: Common sensor library
GitHub - adafruit/DHT-sensor-library: Arduino library for DHT11, DHT22, etc Temperature & Humidity Sensors
App project setup:
Value Display widget attached to V5
Value Display widget attached to V6
#include <DHT.h>
char auth = “26dee6e492b847969383c9587f9d499d”;
SoftwareSerial SerialBLE(0, 1); // RX, TX
#define DHTPIN 2 // What digital pin we’re connected to
// Uncomment whatever type you’re using!
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
// This function sends Arduino’s up time every second to Virtual Pin (5).
// In the app, Widget’s reading frequency should be set to PUSH. This means
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
Serial.println(“Failed to read from DHT sensor!”);
return;
// Please don’t send more that 10 values per second.
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
SerialBLE.begin(9600);
Blynk.begin(SerialBLE, auth);
Serial.println(“Waiting for connections…”);
dht.begin();
