I HAVE A PROBLEM WITH THE FOLLOWING CODE.
EVERYTHING WORKS I SEE THE DATA IN THE SERIAL MONITOR BUT IN THE GAUGE TEMPERATURE AND HUMIDITY APP BLINK DOES NOT RECEIVE ANY DATA.
WHO CAN HELP ME
char auth[] = "XXXXXXXXXXXXXXX";
char ssid[] = "XXXXXXXXXXXXX";
char pass[] = "XXXXXXXXX";
#include <DHT.h>
#define DHTPIN 14 // what pin we're connected to
//#define DHTTYPE DHT22 // DHT 22
DHT dht(DHTPIN, DHTTYPE);
#define BLYNK_GREEN "#23C48E"
#define BLYNK_RED "#D3435C"
#define BLYNK_BLUE "#04C0F8"
float t, h;
float setpoint;
int value = 0;
WidgetLED led1(V1);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V3,h);
Blynk.virtualWrite(V4,t);
Serial.println(h);
Serial.println(t);
if ((setpoint > t ) && (value == 1)) {
digitalWrite(5, LOW);
digitalWrite(5, HIGH);
void ledCaldaia()
if (digitalRead(5) == 1) {
Serial.println("RELE OFF");
led1.off();
led1.setColor(BLYNK_BLUE);
Serial.println("RELE ON");
led1.on();
led1.setColor(BLYNK_RED);
dht.begin();
timer.setInterval(5000L, sendSensor);
timer.setInterval(2000L, ledCaldaia);
pinMode(5, OUTPUT); // rele caldaia
BLYNK_CONNECTED() {
Blynk.syncAll();
BLYNK_WRITE(V2)
setpoint = param.asInt(); // Get value as integer
Serial.println(setpoint);
BLYNK_WRITE(V0)
value = param.asInt(); // Use param as usual.
Serial.println(value);
becasue I have no idea why I said that?? I have even used it myself that way… doh
