esp32, blynk 2.0 app, aurdino ide
So just made some additional calibration inputs but now my device wont connect i already checked my auth, temp, and name, as well as wifi credentials and now i assume it has something to do with pushing too many reads per second not really sure how to diagnose that if it is the case,
my codes down below if anyone can notice a quick fix or any reason why this wouldn’t be working would be greatly appreciated.
@MISCHIEF_GROWS DIY DOSER AND WATERING CONTROLLER CODE
SYSTEM CAN ACTIVATE FEED PUMP TO WATER PLANTS OR DOSE RES FROM 3 NUTE SOURCES
GENERALLY IS RECOMMENDED FOR 2 PART NUTE SYSTEMS W/ 3 SOURCE AS WATER SOURCE
(MOST EFFECTIVE AUTOMATED SETUP) - IF MORE SOURCES NEEDED ADD A RELAY WITH MORE
CHANNELS AND COPY CODE MARKED *SOURCE EXTENSION* AND ADD BELOW THE CODE COPIED
WITH VARIBLE CHANGED AND NEW PIN USED DEFINED.
CAN BE MODIFIED TO BE A PH UP AND PH DOWN ADJUSTER AS WELL JUST ADD GRAVITY
PH SENSOR AND DM ME ON INSTA ILL WRITE A SIMPLE CODE IF THERES INTREST IN THIS.
SIMPLE EASY TO FOLLOW AND MODIFY CODE MAKE SURE TO READ COMMENTS BEFORE CHANGIN
#define BLYNK_TEMPLATE_ID "TMPLAr7hm1Hz"
#define BLYNK_DEVICE_NAME "WATERING CONTROLLER"
#define BLYNK_AUTH_TOKEN "cbbz5HS8JpdpgkHcT7YDKwjHgiXRZcwy"
#define RELAY_PIN 27
#define PUMP_A 26
#define PUMP_B 25
#define PUMP_C 33 //*EXTENSION* copy <- number corresponds to pin used for relay in5,6,7 pin
//*EXTENSION* paste here
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
////WIFI STUFF CHANGE TO YOUR NETWORK OR DEVICE WONT CONNECT TO WIFI
char ssid[] = "NETGEAR64";
char pass[] = "Loki2020!";
//variables to be used later
int timecheck = digitalRead(V6);
int SHUT_DOWN = 0;
int FEED_LOCK = 0;
int doseML_A = digitalRead(V15);
int doseML_B = digitalRead(V16);
int doseML_C = digitalRead(V17); //*EXTENSION* copy <- initalize and declare pump inital value
int calA = digitalRead(V21);
int calB = digitalRead(V22);
int calC = digitalRead(V23); //*EXTENSION* copy <- initalize and declare pump inital value
int feedTimeA = doseML_A/calA;
int feedTimeB = doseML_B/calB;
int feedTimeC = doseML_C/calC; //*EXTENSION* copy <- initalize and declare pump inital value
int calMain = digitalRead(V24);
///CALIBRATION CODE/////////////////////////////////////////////////
//doser pumps
BLYNK_WRITE(V21){
calA = param.asInt();
BLYNK_WRITE(V22){
calB = param.asInt();
BLYNK_WRITE(V23){ // copy section *EXTENSION*
calC = param.asInt(); //
// paste here
//feed pump
BLYNK_WRITE(V24){
calMain = param.asInt();
//PUMP CODE//////////////////////////////////////////////////////////////
BLYNK_WRITE(V0)
// Set incoming value from pin V0 to a variable
// Update state
int count = param.asInt();
while(count == 1 && SHUT_DOWN==0){
digitalWrite(V27, 1);
digitalWrite(RELAY_PIN,1);
delay(timecheck*1000); //change to millis so kill code works mid feed = CALIBRATE
digitalWrite(RELAY_PIN,0);
count = 0;
digitalWrite(V27, 0);
//USER INPUT WATER TIME --> OUTPUTS ML EXPECTED PER PORT (MUST BE CALIBRATED IN CALBRATION INPUTS)
BLYNK_WRITE(V6)
//reads user time input and displays ML conversion based on time input.
timecheck = param.asInt();
Blynk.virtualWrite(V12, calMain*timecheck);
//lock system to prevent unwanted waterings to occur
BLYNK_WRITE(V9)
SHUT_DOWN = param.asInt();
//DOSER PUMP CODE////////////////////////////////////////////////////////
//PUMP-A DOSE
BLYNK_WRITE(V15)
doseML_A = param.asInt();
//PUMP-B DOSE
BLYNK_WRITE(V16)
doseML_B = param.asInt();
//PUMP-C DOSE // copy section *EXTENSION*
BLYNK_WRITE(V17) //
doseML_C = param.asInt(); //
// paste here adjust name to next leter
//DOSE FEED///////////////////////////////////////////////////////////
//feed lock input switch
BLYNK_WRITE(V3)
FEED_LOCK = param.asInt();
BLYNK_WRITE(V18)
digitalWrite(V26, 1);
while(count == 1 && FEED_LOCK==0){
digitalWrite(PUMP_A,1);
delay(feedTimeA*1000); //change to millis so kill code works mid feed + CALIBRATE
digitalWrite(PUMP_A,0);
count = 0;
count = 1;
digitalWrite(PUMP_B,1);
delay(feedTimeB*1000); //change to millis so kill code works mid feed + CALIBRATE
digitalWrite(PUMP_B,0);
count = 0;
count = 1;
while(count == 1 && FEED_LOCK==0){ // Copy section *EXTENSION*
digitalWrite(PUMP_C,1); //
delay(feedTimeC*1000); //change to millis so kill code works mid feed + CALIBRATE //
digitalWrite(PUMP_C,0); //
count = 0; //
// paste BEFORE V26 write command
digitalWrite(V26, 0);
//test pump code///////////////////////////////////////
BLYNK_WRITE(V19)
delay(1000);
delay(1000);
delay(1000);
delay(1000);
delay(1000);
count = 0;
// precoded blynk stuff i just commented it out if anyone ends up wanting the skelton code
BLYNK_CONNECTED()
Blynk.sendInternal("rtc", "sync"); //request current local time for device
// Change Web Link Button message to "Congratulations!"
Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
Blynk.setProperty(V3, "onImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
Blynk.virtualWrite(V2, millis() / 1000);
//**DONT TOUCH LEAVE ANY CODE BELOW THIS POINT IF YOU DONT KNOW WHAT YOUR DOING!
pinMode(RELAY_PIN, OUTPUT);
pinMode(PUMP_A, OUTPUT);
pinMode(PUMP_B, OUTPUT);
pinMode(PUMP_C, OUTPUT);
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
// to avoid delay() function!
