Hardware model + communication: Arduino with HC-06/HC-05
Android Phone: Huawei Nova 5t
im using blynk server and using the latest version of blynk. I tried using the code generator on the blynk website, on my first try it work using hc-06 and on hc-05 not working but on the next day it no longer work either hc-05 or hc-06. I want to create a push button (virtual) controlling a dc motor but from the start,it is not communicating. how to connect arduino to the blynk server so it will not show device wasn’t online… I want to control a dc motor to simulate a ventilation of a room. there is no shield and no motor driver, Im just connecting my project to hc05/hc06.
PLEASE help me, i also want to try this bluetooth to my nodemcu
http://twitter.com/blynk_app
Note: This only works on Android!
iOS does not support Bluetooth 2.0 Serial Port Profile
You may need to pair the module with your smartphone
via Bluetooth settings. Default pairing password is 1234
NOTE: Bluetooth support is in beta!
You can use this sketch as a debug tool that prints all incoming values
sent by a widget connected to a Virtual Pin 1 in the Blynk App.
App project setup:
Slider widget (0...100) on V1
SoftwareSerial SerialBLE(10, 11); // RX, TX
// in Blynk app writes values to the Virtual Pin 1
BLYNK_WRITE(V1)
// You can also use:
// String i = param.asStr();
// double d = param.asDouble();
Serial.print("V1 Slider value is: ");
Serial.println(pinValue);
SerialBLE.begin(9600);
Blynk.begin(SerialBLE, auth);
