I’m a little bit confused with organizations, accounts and devices.
Using my main account (PRO plan) as admin , say ADMIN, I have created my own organization. I have my own devices attached to this organization and everythings runs fine.
I have created an organization for a client, say ORG-CLIENT
I have created a device in ORG-CLIENT, say DEV-CLIENT, owner is ADMIN
I have invited some users in ORG-CLIENT, they can see and use the DEV-CLIENT in app
I can access to DEV-CLIENT from the blynk.console logged as ADMIN.
so far everything is fine
now for some reasons I need to add the DEV-CLIENT to my ADMIN account, to access it from my smartphone and not only from the blynk.console
following the instructions :
I tried to invite my ADMIN account from the ORG-CLIENT :
blynk.console → organizations → select organization ORG-CLIENT → users → + invite a new user
but the email address of my ADMIN account is refused with error : “this email address already exists”
Devices from a sub-organization are also available in applications for the Admin of the root organization.
In order to see the device you need to switch to the sub organization in the menu:
My Households - select the desired organization - select the organization in which the device is located.
After some tries I’m sorry but it is still not very clear to me :
In Blynk.console → devices → select one device → device menu ‘transfer’
the pop-up ‘transfer device’ is showing, select ‘transfer to anoter user’
entering new owner’s account email address different as the current owner, then clicking on Transfer I get the error message :
‘Can’t transfer to the same owner’
while the new owner’s email address is different from the old one
If I try to add a new user by inviting him with new email address, I got the message : ‘This email address already exists’ while it does not exists in my users list. where does it exists ?
what are the requirements for the new owner’s account email address for the transfer to be successful ?
You cannot transfer the device to another user that is not a member of your root or sub organization.
If an error occurs when inviting using this email, it means that a user with this email already exists in our system.
In order for you to invite this user, the user must log into his account and delete it.
