Hye! We already configured the Arduino Mega with GPRS SIM900 with current sensor. We want to receive the data via Blynk apps. Here is ur code. But the problem is in blynkapps, it shows the device is offline while it is connected.
// Select your modem:
//#define TINY_GSM_MODEM_SIM800
#define TINY_GSM_MODEM_SIM900
//#define TINY_GSM_MODEM_M590
//#define TINY_GSM_MODEM_A6
//#define TINY_GSM_MODEM_A7
//#define TINY_GSM_MODEM_BG96
//#define TINY_GSM_MODEM_XBEE
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
//#define BLYNK_HEARTBEAT 30
#include <TinyGsmClient.h>
char auth[] = "HXpRfORzTv_83PSSkDU9bsNgE49mcGVv";
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[] = "net";
char user[] = "";
char pass[] = "";
// Hardware Serial on Mega, Leonardo, Micro
SoftwareSerial SerialAT(10, 11); // RX, TX
// or Software Serial on Uno, Nano
//#include <SoftwareSerial.h>
//SoftwareSerial SerialAT(10, 11); // RX, TX
TinyGsm modem(SerialAT);
float reading = 0;
float currentValue = 0;
float powerValue = 0;
void sendSensor()
reading = analogRead(A5); //Raw data reading
currentValue = (reading - 510) * 5 / 1024 / 0.04 - 0.24;
powerValue = ( currentValue * 254);
Serial.print("\t Amps = "); //shows the current value
Serial.println(currentValue); //the '2' allows you to display 2 digit
Serial.print("\t Watts = "); //shows the current value
Serial.println(powerValue, 2); //the '2' allows you to display 2 digit
delay(3);
void setup(){
// Set GSM module baud rate
SerialAT.begin(115200);
delay(3000);
modem.restart();
// Unlock your SIM card with a PIN
//modem.simUnlock("1234");
