We have built a remote switch using the Arduino Uno and Botletics SIM7000A modem. The device turns on/off a remote switch via LTE-M using Blynk 2.0 App. The device/software works great for several hours but then the device goes offline and never reconnects. We must manually reboot the device to get it to work again.
Initially, we thought that this was a poor signal issue so we added an external high-gain antenna. The signal quality is always excellent with this antenna.
The code is below, is there a way to add code that would, upon detecting the device being offline, would simply reboot the device or restart the connection? We tried to play with the BlinkTimer function but as soon as we declare it, the code breaks - the device will goes into endless loop where it tries to connect go Blynk sever.
Thank you very much for your help.
* This project is for a remote AC outlet switch that is made using
* an Arduino UNO-like microcontroller, and the Blynk IoT library.
// these Blynk definitions ALWAYS have to be first
#define BLYNK_FIRMWARE_VERSION "XX"
#define BLYNK_TEMPLATE_ID "XXX"
#define BLYNK_DEVICE_NAME "Remote Control Switch"
#define BLYNK_AUTH_TOKEN "XXX"
#define BLYNK_NO_FANCY_LOGO
* IMPORTANT: Configuration of Blynk Heartbeat Interval
#define BLYNK_HEARTBEAT 300
// define the SIM type
#define TINY_GSM_MODEM_SIM7000
// libraries
#define SerialMon Serial
// pin definitions
#define TX 10 // Microcontroller RX
#define RX 11 // Microcontroller TX
#define RELAY_PIN1 12 // Relay Control Pin
// just one relay pin needed for now
// if you want to use the other one, just uncomment all the relevant lines
//#define RELAY_PIN2 XX
// initialize software serial
SoftwareSerial SerialAT(TX, RX);
// configure GPRS settings (user and pass may be optional depending on your SIM card)
const char apn[] = "iot.1nce.net";
const char user[] = "";
const char pass[] = "";
// configure Blynk authentication token
const char auth[] = "XXX";
//BlynkTimer timer; // This is breaking the code!
//int timerID;
// initialize modem
TinyGsm modem(SerialAT);
// define global variables
bool startup = true;
float deviceUptime = 0;
bool relayStatus = false;
float relayStartTime = 0;
* called whenever a widget writes to virtual pin V1
* it will switch the relay on and off, turn on the status LED, and push a notification
* lastly it will call the updateDeviceTime() function which will update the uptime
BLYNK_WRITE(V1) {
// retrieve value from virtual pin V1
uint8_t pinValue = param.asInt();
if (pinValue != 0) {
// turn on relay
digitalWrite(RELAY_PIN1, LOW);
//digitalWrite(RELAY_PIN2, LOW);
digitalWrite(LED_BUILTIN, HIGH);
SerialMon.println("RELAY ON");
// turn on Blynk LED
Blynk.virtualWrite(V4, 255);
// push notification that the relay is ON
Blynk.logEvent("relay", "The relay is ON");
// update device uptime
updateDeviceTime();
// start relay uptime
relayStatus = true;
relayStartTime = deviceUptime;
else {
// turn off relay
digitalWrite(RELAY_PIN1, HIGH);
//digitalWrite(RELAY_PIN2, HIGH);
digitalWrite(LED_BUILTIN, LOW);
SerialMon.println("RELAY OFF");
// turn off Blynk LED
Blynk.virtualWrite(V4, 0);
// push notification that the relay is OFF
Blynk.logEvent("relay", "The relay is OFF");
updateDeviceTime();
// stop relay uptime
* called whenever a widget reads virtual pin V7
* first it will update the device uptime then use it to calculate the relay uptime
* after which it will then write it to virtual pin V6
* if relay is not on, it will instead return a value of 0
BLYNK_WRITE(V7) {
if (relayStatus) {
updateDeviceTime();
Blynk.virtualWrite(V6, deviceUptime - relayStartTime);
SerialMon.print("Relay Uptime: ");
SerialMon.println(deviceUptime - relayStartTime);
* called whenever a widget reads virtual pin V8 and returns signal quality to virtual pin V9
BLYNK_WRITE(V8) {
String signalCond = "";
String signalColor = "";
uint8_t signalQuality = 0;
signalQuality = modem.getSignalQuality();
if (signalQuality == 99) {
signalCond = "UNKNOWN";
// grey color
signalColor = "#A0A0A0";
// RSSI less than -93 dBm
else if (signalQuality < 10) {
signalCond = "MARGINAL";
// red color
signalColor = "#FF0000";
// RSSI greater than -95 dBm and less than -83 dBm
else if (signalQuality > 9 && signalQuality < 15) {
signalCond = "OK";
// orange color
signalColor = "#FF7B00";
// RSSI greater than -85 dBm and less than -73 dBm
else if (signalQuality > 14 && signalQuality < 20) {
signalCond = "GOOD";
// light green color
signalColor = "#6EFF00";
// RSSI greater than -75 dBm
else if (signalQuality > 19) {
signalCond = "EXCELLENT";
// brighter darker green color
signalColor = "#04D700";
Blynk.virtualWrite(V9, signalCond);
Blynk.virtualWrite(V10, 255);
Blynk.setProperty(V10, "color", signalColor);
SerialMon.print("Signal Quality: ");
SerialMon.print(signalQuality);
SerialMon.print(" - ");
SerialMon.println(signalCond);
* updates the device uptime in hours, and
* then pushes the uptime to virtual pin V5
void updateDeviceTime() {
deviceUptime = (((millis() / 1000) / 60) / 60);
Blynk.virtualWrite(V5, deviceUptime);
* setup and initializes device on startup (or reboot) and will only run once
//timerID = timer.setInterval(5000L, sensorDataSend); //timer will run every sec
// configure relay and ensure it is off
pinMode(RELAY_PIN1, OUTPUT);
// pinMode(RELAY_PIN2, OUTPUT);
// digitalWrite(RELAY_PIN2, HIGH);
pinMode(LED_BUILTIN, OUTPUT);
// set console baud rate
SerialMon.begin(9600);
// set GSM module baud rate
SerialAT.begin(9600);
delay(6000);
// initialize modem
SerialMon.println("Initializing modem...");
modem.restart();
modem.waitForNetwork(300000L); // 30 second timeout
// get modem info
String modemInfo = modem.getModemInfo();
SerialMon.print("Modem Info: ");
SerialMon.println(modemInfo);
// connect to Blynk
// verify heartbeat is configured correctly
SerialMon.print("Heartbeat (sec): ");
SerialMon.println(BLYNK_HEARTBEAT);
* main function that loops during device operation
* On startup, the device will sync the current value of the virtual pin V1 and V8
* which will call the write functions for those respective pins
* this ensures that if the relay was ON when the device loses power, it will resume on reboot
* it also makes the device check signal quality on startup
//timer.run(); // run timer every second
if (startup) {
// check relay status
Blynk.syncVirtual(V1);
// checks signal quality
Blynk.syncVirtual(V8);
startup = false;
// sends push notification that device has rebooted
Blynk.logEvent("reboot","The device has rebooted");
