I have an ESP32 (Chip is ESP32-D0WDQ6 (revision 1), Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None, Crystal is 40MHz) connecting to Blynk cloud over WiFi. Here is my sketch.
#define BLYNK_TEMPLATE_ID "REMOVED"
#define BLYNK_DEVICE_NAME "REMOVED"
#define BLYNK_AUTH_TOKEN "REMOVED"
// #define BLYNK_PRINT Serial
#include <WiFi.h>
#include <BlynkSimpleEsp32.h>
#include <DHTesp.h>
char ssid[] = "REMOVED";
char pass[] = "REMOVED";
BlynkTimer readAndSendTimer;
ComfortState externalDHT11ComfortState;
ComfortState externalDHT22ComfortState;
ComfortState internalTopDHT11ComfortState;
ComfortState internalTopDHT22ComfortState;
ComfortState internalMiddleDHT11ComfortState;
ComfortState internalMiddleDHT22ComfortState;
ComfortState internalBottomDHT11ComfortState;
ComfortState internalBottomDHT22ComfortState;
/** Initialize DHTs */
DHTesp externalDHT11;
DHTesp externalDHT22;
DHTesp internalTopDHT11;
DHTesp internalTopDHT22;
DHTesp internalMiddleDHT11;
DHTesp internalMiddleDHT22;
DHTesp internalBottomDHT11;
DHTesp internalBottomDHT22;
/** Define signal connection pins */
int externalDHT11SignalPin = 12;
int externalDHT22SignalPin = 13;
int internalTopDHT11SignalPin = 15;
int internalTopDHT22SignalPin = 2;
int internalMiddleDHT11SignalPin = 4;
int internalMiddleDHT22SignalPin = 16;
int internalBottomDHT11SignalPin = 17;
int internalBottomDHT22SignalPin = 5;
int heaterRelaySignalPin = 14;
int humidifierRelaySignalPin = 27;
int topFanRelaySignalPin = 26;
int waterLevelSignalPin = 25;
// Read and VirtualWrite all values to Blynk Virtual Pins
void readAndSendSensorData() {
//Serial.println("Attempting sensing from external DHT11.");
float externalDHT11Humidity = externalDHT11.getHumidity();
Blynk.virtualWrite(V0, externalDHT11Humidity);
float externalDHT11Temperature = externalDHT11.getTemperature();
Blynk.virtualWrite(V1, externalDHT11Temperature);
//Serial.println("External DHT11: Data sent to Blynk:");
//Serial.println("Humidity (%)\tTemperature");
//Serial.print(externalDHT11Humidity, 1);
//Serial.print("\t\t");
//Serial.print(externalDHT11Temperature, 1);
//Serial.println("");
//Serial.println("Attempting sensing from external DHT22.");
float externalDHT22Humidity = externalDHT22.getHumidity();
Blynk.virtualWrite(V2, externalDHT22Humidity);
float externalDHT22Temperature = externalDHT22.getTemperature();
Blynk.virtualWrite(V3, externalDHT22Temperature);
float externalDHT22DewPoint = externalDHT22.computeDewPoint(externalDHT22Humidity, externalDHT22Temperature, false);
Blynk.virtualWrite(V4, externalDHT22DewPoint);
float externalDHT22AbsoluteHumidity = externalDHT22.computeAbsoluteHumidity(externalDHT22Temperature, externalDHT22Humidity, false);
Blynk.virtualWrite(V5, externalDHT22AbsoluteHumidity * 1000); // Blynk has milligrams/cubic meter as a listed unit
int externalDHT22HumanPerception = externalDHT22.computePerception(externalDHT22Temperature, externalDHT22Humidity, false);
String externalDHT22HumanPerceptionText = getHumanPerceptionText(externalDHT22HumanPerception);
Blynk.virtualWrite(V6, externalDHT22HumanPerceptionText);
float externalDHT22ComfortRatio = externalDHT22.getComfortRatio(externalDHT22ComfortState, externalDHT22Temperature, externalDHT22Humidity, false);
String externalDHT22ComfortStatusText = getComfortStatusText(externalDHT22ComfortState);
Blynk.virtualWrite(V7, externalDHT22ComfortStatusText);
//Serial.println("External DHT22: Data sent to Blynk:");
//Serial.println("Humidity (%)\tTemperature (C)\tDew Point (C)\tAbsolute Humidity (g/cu. m)\tHuman Perception Status\t\tComfort Status");
//Serial.print(externalDHT22Humidity, 1);
//Serial.print(externalDHT22Temperature, 1);
//Serial.print(externalDHT22DewPoint, 1);
//Serial.print(externalDHT22AbsoluteHumidity, 1);
//Serial.print("\t\t\t\t" + externalDHT22HumanPerceptionText);
//Serial.println("\t\t\t" + externalDHT22ComfortStatusText);
//Serial.println("Attempting sensing from internal top DHT11.");
float internalTopDHT11Humidity = internalTopDHT11.getHumidity();
Blynk.virtualWrite(V8, internalTopDHT11Humidity);
float internalTopDHT11Temperature = internalTopDHT11.getTemperature();
Blynk.virtualWrite(V9, internalTopDHT11Temperature);
//Serial.println("Internal top DHT11: Data sent to Blynk:");
//Serial.println("Humidity (%)\tTemperature (C)");
//Serial.print(internalTopDHT11Humidity, 1);
//Serial.print(internalTopDHT11Temperature, 1);
//Serial.println("Attempting sensing from internal top DHT22.");
float internalTopDHT22Humidity = internalTopDHT22.getHumidity();
Blynk.virtualWrite(V10, internalTopDHT22Humidity);
float internalTopDHT22Temperature = internalTopDHT22.getTemperature();
Blynk.virtualWrite(V11, internalTopDHT22Temperature);
float internalTopDHT22DewPoint = internalTopDHT22.computeDewPoint(internalTopDHT22Humidity, internalTopDHT22Temperature, false);
Blynk.virtualWrite(V12, internalTopDHT22DewPoint);
float internalTopDHT22AbsoluteHumidity = internalTopDHT22.computeAbsoluteHumidity(internalTopDHT22Temperature, internalTopDHT22Humidity, false);
Blynk.virtualWrite(V13, internalTopDHT22AbsoluteHumidity * 1000); // Blynk has milligrams/cubic meter as a listed unit
int internalTopDHT22HumanPerception = internalTopDHT22.computePerception(internalTopDHT22Temperature, internalTopDHT22Humidity, false);
String internalTopDHT22HumanPerceptionText = getHumanPerceptionText(internalTopDHT22HumanPerception);
Blynk.virtualWrite(V14, internalTopDHT22HumanPerceptionText);
float internalTopDHT22ComfortRatio = internalTopDHT22.getComfortRatio(internalTopDHT22ComfortState, internalTopDHT22Temperature, internalTopDHT22Humidity, false);
String internalTopDHT22ComfortStatusText = getComfortStatusText(internalTopDHT22ComfortState);
Blynk.virtualWrite(V15, internalTopDHT22ComfortStatusText);
//Serial.println("Internal top DHT22: Data sent to Blynk:");
//Serial.println("Humidity (%)\tTemperature (C)\tDew Point (C)\tAbsolute Humidity (g./cu. m)\tHuman Perception Status\t\tComfort Status");
//Serial.print(internalTopDHT22Humidity, 1);
//Serial.print(internalTopDHT22Temperature, 1);
//Serial.print(internalTopDHT22DewPoint, 1);
//Serial.print(internalTopDHT22AbsoluteHumidity, 1);
//Serial.print("\t\t\t\t" + internalTopDHT22HumanPerceptionText);
//Serial.println("\t\t\t" + internalTopDHT22ComfortStatusText);
//Serial.println("Attempting sensing from internal middle DHT11.");
float internalMiddleDHT11Humidity = internalMiddleDHT11.getHumidity();
Blynk.virtualWrite(V16, internalMiddleDHT11Humidity);
float internalMiddleDHT11Temperature = internalMiddleDHT11.getTemperature();
Blynk.virtualWrite(V17, internalMiddleDHT11Temperature);
//Serial.println("Internal middle DHT11: Data sent to Blynk:");
//Serial.print(internalMiddleDHT11Humidity, 1);
//Serial.print(internalMiddleDHT11Temperature, 1);
//Serial.println("Attempting sensing from internal middle DHT22.");
float internalMiddleDHT22Humidity = internalMiddleDHT22.getHumidity();
Blynk.virtualWrite(V18, internalMiddleDHT22Humidity);
float internalMiddleDHT22Temperature = internalMiddleDHT22.getTemperature();
Blynk.virtualWrite(V19, internalMiddleDHT22Temperature);
//Serial.println("Internal middle DHT22: Data sent to Blynk:");
//Serial.print(internalMiddleDHT22Humidity, 1);
//Serial.print(internalMiddleDHT22Temperature, 1);
//Serial.println("Attempting sensing from internal bottom DHT11.");
float internalBottomDHT11Humidity = internalBottomDHT11.getHumidity();
Blynk.virtualWrite(V20, internalBottomDHT11Humidity);
float internalBottomDHT11Temperature = internalBottomDHT11.getTemperature();
Blynk.virtualWrite(V21, internalBottomDHT11Temperature);
//Serial.println("Internal bottom DHT11: Data sent to Blynk:");
//Serial.print(internalBottomDHT11Humidity, 1);
//Serial.print(internalBottomDHT11Temperature, 1);
//Serial.println("Attempting sensing from internal bottom DHT22.");
float internalBottomDHT22Humidity = internalBottomDHT22.getHumidity();
Blynk.virtualWrite(V22, internalBottomDHT22Humidity);
float internalBottomDHT22Temperature = internalBottomDHT22.getTemperature();
Blynk.virtualWrite(V23, internalBottomDHT22Temperature);
//Serial.println("Internal bottom DHT22: Data sent to Blynk:");
//Serial.print(internalBottomDHT22Humidity, 1);
//Serial.print(internalBottomDHT22Temperature, 1);
// Read the analog value from the water level sensor in the humidifier container
int waterLevel = analogRead(waterLevelSignalPin);
Blynk.virtualWrite(V24, waterLevel);
//Serial.print("Water level in the humidifier container is:");
//Serial.print(waterLevel, 1);
Control heater based on internal top DHT22. This relay is wired Normally
Open (Normally open pin starts sending current on HIGH, and vice versa)
if (internalTopDHT22Temperature < 28) {
digitalWrite(heaterRelaySignalPin, HIGH);
Blynk.virtualWrite(V25, HIGH);
digitalWrite(heaterRelaySignalPin, LOW);
Blynk.virtualWrite(V25, LOW);
Control humidifier based on internal top DHT22. This relay is wired Normally
if (internalTopDHT22Humidity < 70) {
digitalWrite(humidifierRelaySignalPin, HIGH);
Blynk.virtualWrite(V26, HIGH);
digitalWrite(humidifierRelaySignalPin, LOW);
Blynk.virtualWrite(V26, LOW);
Control top fan based on internal top DHT22. This relay is wired Normally
if (internalTopDHT22Humidity > 70 || internalTopDHT22Temperature > 28) {
digitalWrite(topFanRelaySignalPin, HIGH);
Blynk.virtualWrite(V27, HIGH);
digitalWrite(topFanRelaySignalPin, LOW);
Blynk.virtualWrite(V27, LOW);
Read and send the WiFi's Received Signal Strength Indicator (RSSI) of the WiFi connection - an integer
int wifiSignalStrength = WiFi.RSSI();
//Serial.print("WiFi signal strength (RSSI): ");
//Serial.println(wifiSignalStrength);
Blynk.virtualWrite(V28, wifiSignalStrength);
//Serial.begin(115200);
//Serial.println("Setup started.");
WiFi.mode(WIFI_STA);
//Serial.println("WiFi capability set to STATION mode.");
//Serial.println("Authorised to send data to Blynk.");
// Set up pin modes
pinMode(externalDHT11SignalPin, INPUT);
pinMode(externalDHT22SignalPin, INPUT);
pinMode(internalTopDHT11SignalPin, INPUT);
pinMode(internalTopDHT22SignalPin, INPUT);
pinMode(internalMiddleDHT11SignalPin, INPUT);
pinMode(internalMiddleDHT22SignalPin, INPUT);
pinMode(internalBottomDHT11SignalPin, INPUT);
pinMode(internalBottomDHT22SignalPin, INPUT);
pinMode(heaterRelaySignalPin, OUTPUT);
pinMode(humidifierRelaySignalPin, OUTPUT);
pinMode(topFanRelaySignalPin, OUTPUT);
pinMode(waterLevelSignalPin, INPUT);
// Set up DHTs
externalDHT11.setup(externalDHT11SignalPin, DHTesp::DHT11);
externalDHT22.setup(externalDHT22SignalPin, DHTesp::DHT22);
internalTopDHT11.setup(internalTopDHT11SignalPin, DHTesp::DHT11);
internalTopDHT22.setup(internalTopDHT22SignalPin, DHTesp::DHT22);
internalMiddleDHT11.setup(internalMiddleDHT11SignalPin, DHTesp::DHT11);
internalMiddleDHT22.setup(internalMiddleDHT22SignalPin, DHTesp::DHT22);
internalBottomDHT11.setup(internalBottomDHT11SignalPin, DHTesp::DHT11);
internalBottomDHT22.setup(internalBottomDHT22SignalPin, DHTesp::DHT22);
//Serial.println("All DHT11 & DHT22 set up.");
// Setup 10 seconds interval for the readAndSensorData function
readAndSendTimer.setInterval(30000L, readAndSendSensorData);
readAndSendTimer.run();
Comfort Status Text
0 -> OK
1 -> Too Hot
2 -> Too cold
4 -> Too dry
5 -> Hot and dry
6 -> Cold and dry
8 -> Too humid
9 -> Hot and humid
10 -> Cold and humid
String getComfortStatusText(int reportedComfortState) {
String comfortStatusText;
switch (reportedComfortState) {
case Comfort_OK:
comfortStatusText = "OK";
break;
case Comfort_TooHot:
comfortStatusText = "Too Hot";
break;
case Comfort_TooCold:
comfortStatusText = "Too Cold";
break;
case Comfort_TooDry:
comfortStatusText = "Too Dry";
break;
case Comfort_TooHumid:
comfortStatusText = "Too Humid";
break;
case Comfort_HotAndHumid:
comfortStatusText = "Hot and Humid";
break;
case Comfort_HotAndDry:
comfortStatusText = "Hot and Dry";
break;
case Comfort_ColdAndHumid:
comfortStatusText = "Cold and Humid";
break;
case Comfort_ColdAndDry:
comfortStatusText = "Cold and Dry";
break;
default:
comfortStatusText = "Unknown";
break;
return comfortStatusText;
Human Perception Text
0 -> Dry
1 -> Very comfortable
2 -> Comfortable
3 -> Ok
4 -> Uncomfortable
5 -> Quite uncomfortable
6 -> Very uncomfortable
7 -> Severe uncomfortable
String getHumanPerceptionText(int reportedHumanPerceptionValue) {
String humanPerceptionText;
switch (reportedHumanPerceptionValue) {
case 0:
humanPerceptionText = "Dry";
break;
case 1:
humanPerceptionText = "Very comfy";
break;
case 2:
humanPerceptionText = "Comfy";
break;
case 3:
humanPerceptionText = "OK";
break;
case 4:
humanPerceptionText = "Uncomfy";
break;
case 5:
humanPerceptionText = "Quite uncomfy";
break;
case 6:
humanPerceptionText = "Very uncomfy";
break;
case 7:
humanPerceptionText = "Severely uncomfy";
break;
return humanPerceptionText;
I was about to add multiple setTimeouts, putting each virtual write in a separate Timeout, when I saw this thread, and instead used multiple Blynk.run() in accordance to this thread.
Despite everything that I do, the Blynk web dashboard shows the device online, as soon as it boots, and starts sending data to Blynk, but, right around 4 minutes and 30 seconds the device goes offline. Can someone help please? @PeteKnight
UPDATE: After multiple edits and commenting all the Serial prints, the code is above. This is connected for the last 20 minutes now, so looks like the problem has been resolved, but this makes me concerned, since Blynk has a Virtual Write limit of 10 per second. Shall that not be an issue?
