Could someone please give me some more detailed instructions on how to get blynk to run on start up on raspberry pi. I have tried everything. Thanks
You try this (from https://github.com/blynkkk/blynk-server)?
I’ve had great success with the crontab- make sure you’re typing in the correct server version that you’ve downloaded. Also, have you actually tried starting up the server?
Enabling server auto restart on unix-like systems
To enable server auto restart find /etc/init.d/rc.local file and add :
java -jar /home/pi/server-0.15.2.jar -dataFolder /home/pi/Blynk &
Or in case above approach doesn't work for you, execute
crontab -e
add the following line
@reboot java -jar /home/pi/server-0.15.2.jar -dataFolder /home/pi/Blynk &
