Hola: he creado un proyecto con un servidor local Blynk. Tengo inconvenientes con el envío de mails tanto a partir del widgets como para el envío del token. La dirección de email es de gmail y están habilitadas las aplicaciones poco seguras. Gracias por la respuesta. Miguel
Hi, I created a project with a local Blynk server. I have problems with sending mails both from the widgets and the token delivery. The email address is from gmail and unsafe applications are enabled. Thanks for the reply. Michael
I am carrying out the project with a NodeMCU and on the local server I should configure the mail.properties file, but where is that file located?
Is that file necessary to report the outgoing mail pass to the server?
psoro
December 11, 2019, 10:58pm
5
You have to create that file, please check:
# What is Blynk?
Blynk is a platform with iOS and Android apps to control Arduino, ESP8266, Raspberry Pi and the likes over the Internet.
You can easily build graphic interfaces for all your projects by simply dragging and dropping widgets.
If you need more information, please follow these links:
* [Blynk site](https://www.blynk.cc)
* [Blynk docs](http://docs.blynk.cc)
* [Blynk community](https://community.blynk.cc)
* [Blynk Examples generator](https://examples.blynk.cc)
* [Facebook](http://www.fb.com/blynkapp)
* [Twitter](http://twitter.com/blynk_app)
* [App Store](https://itunes.apple.com/us/app/blynk-control-arduino-raspberry/id808760481?ls=1&mt=8)
* [Google Play](https://play.google.com/store/apps/details?id=cc.blynk)
* [Blynk library](https://github.com/blynkkk/blynk-library)
* [Kickstarter](https://www.kickstarter.com/projects/167134865/blynk-build-an-app-for-your-arduino-project-in-5-m/description)
This file has been truncated. show original
That file must be at the same folder as the jar file
