Hello everyone. I try to control a dc motor with blynk app. I create a button in the app and set to virtual pin. What I want to do is, when I press the button (logic 1) the motor rotates 90°, when I press the button again (logic 0) the motor returns to its starting position. I use rotary sensor for angle control. I can find the angle of rotation of the motor by doing analog reading. I can’t read analog inside the loop function. Because I’m disconnected from blynk server. I did analog reading within the BLYNK_WRITE(V5) function. This time, the problem is that it only read analog when I press the button. So the function only works when I press the button. Therefore, although the sensor 90°, the microprocessor can’t give a stop command to the motor. How can I continuously read the data from the sensor without writing it to the loop function. I would be very greatful if you could support me with the issue. I am sharing the code I prepared below for you to review.
#define motorSpeed D5
#define motorDir D6
#define encoderPin A0
//#define BLYNK_TEMPLATE_ID "YourTemplateID"
char auth[] = "***********************************";
char ssid[] = "VsFuar";
char pass[] = "***************";
int motorAngle;
int eMin=510;
int eMax=1023;
int count=0;
pinMode(motorSpeed,OUTPUT);
pinMode(motorDir, OUTPUT);
pinMode(encoderPin, INPUT);
BLYNK_WRITE(V5)
int pinValue=param.asInt();
Serial.println(pinValue);
motorAngle=analogRead(encoderPin);
motorAngle=map(motorAngle, eMin, eMax, 0, 180);
if(pinValue==1)
if((pinValue==1) && (motorAngle<=20))
digitalWrite(motorSpeed,HIGH);
digitalWrite(motorDir, LOW);
if(motorAngle>=90)
digitalWrite(motorSpeed,LOW);
if(pinValue==0)
if((pinValue==0) && (motorAngle>=90))
digitalWrite(motorDir, HIGH);
if(motorAngle<=1)
