adding datastreams can be very tedious when building lists
it would be great to have additionnal fields in the datastream editor to give range and step to clone the data stream
for example :
I need 10 same datastreams, from virtual pin 1 to 45 steps 5 : the datastreams V1, V5, V10… V45 will be created at once with same properties, if no collision with existing datastreams occurs.
thank a lot !
Bruno
