Hello sirs,
Please help with this, I checked other topic in this forum but didnot find any similar thread that helps.
I wonder only me or anybody else that run into this issue of Blynk data streaming?
I tried to give command at IFTTT and Google Assistant.
Following this instruction of getting value as:
https://{server_address}/external/api/get?token={token}&dataStreamId={id}
I found out that no matter value you put (0 or 1), it all returned to the current state of the Pin.
For example: if I used the mobile app to turn the V0 value to 1 (then my LED was ON).
Then when I pasted this string to Chrome, it all returned to 1 (no matter I put the V0=0 or V0=1)
In attached picture, when I used mobile app to switch value of the V0 to 0 (then my LED was OFF).
Then the webserver only returns to 0 (no matter what value I put 0 or 1).
So I guess this is unusual response from Blynk server?
Please help clarify that this can happen or not? Or else I need to find error in my code though now It is working fine with the mobile app.
Thank you for your time.!
