I made a project which controls a greenhouse. I used a nodemcu which is connected with blynk. I used blynk.adgent. I started the program using the scetch example of arduino Blynk.Edgent and I was adding code step by step according to my needs. I noticed that some pins didn’t work properly.
I’ m using 5 DHT11 sensors, 2 relays for controling light and watering and 4 relays for controling 2 motors for opening windows at the greenhouse. Unfortunatelly pins D3 and D4 doesn’t work. If I connect a sensor or a relay on D3 or D4 nodemcu stops communication with the blynk. So I didn’t connect a DHT11 sensor (which gives output) and an input of a relay. If I connect one or two relays or sensors on D3 or D4, without using any other pin, nodemcu can establish communication with nodemcu and the project works. I want to take advantage of all of the pins in order my project to work, but D3 and D4 don’t responding. I read about using a resistor but I don’t understand how to connect it and if this action is going to solve the problem.
Adding my code:
#define BLYNK_TEMPLATE_ID "TMPLtQmUC3jM"
#define BLYNK_TEMPLATE_NAME "Remote Greenhouse IOT"
#define BLYNK_FIRMWARE_VERSION "0.2.6"
#include "DHT.h"
#define sensor A0
#define BLYNK_DEBUG
#define APP_DEBUG
#define USE_NODE_MCU_BOARD
#include "BlynkEdgent.h"
DHT dht1,dht2,dht3,dht4;
double Temperature1,Humidity1,Temperature2,Humidity2,Temperature3,Humidity3,Temperature4,Humidity4,avg_temperature,avg_humidity;
int soil_moisture_value,percentageSM;
const int dry = 595; // value for dry sensor 595
const int wet = 239; // value for wet sensor 239
BLYNK_WRITE(V0) { //Light uses D0 and V0
bool value = param.asInt();
// Check these values and turn the relay1 ON and OFF
if (value == 1) {
digitalWrite(D0, LOW);
Serial.println("Turn on the light");
else {
digitalWrite(D0, HIGH);
Serial.println("Turn off the light");
BLYNK_WRITE(V1) { //Watering uses D1 and V1
if (value == 1) {
digitalWrite(D1, LOW);
Serial.println("Start watering");
else {
digitalWrite(D1, HIGH);
Serial.println("Stop watering");
BLYNK_WRITE(V2) { //Left motor (open) uses D5 and V2
if (value == 1) {
digitalWrite(D5, LOW);
digitalWrite(D6, HIGH);
Blynk.virtualWrite(V3, LOW);
Serial.println("Open left window");
else {
digitalWrite(D5, HIGH);
Serial.println("Stop left window at this position");
BLYNK_WRITE(V3) { //Left motor (close) uses D6 and V3
if (value == 1) {
digitalWrite(D6, LOW);
Blynk.virtualWrite(V2, LOW);
Serial.println("Close left window");
else {
BLYNK_WRITE(V10) { //Right motor (open) uses D4 and V10
if (value == 1) {
digitalWrite(D3, LOW);
digitalWrite(D8, HIGH);
Blynk.virtualWrite(V11, LOW);
Serial.println("Open right window");
else {
digitalWrite(D3, HIGH);
Serial.println("Stop right window at this position");
BLYNK_WRITE(V11) { //Right motor (close) uses D8 and V11
if (value == 1) {
digitalWrite(D8, LOW);
Blynk.virtualWrite(V10, LOW);
Serial.println("Close right window");
else {
pinMode(D0,OUTPUT); //Lamp
pinMode(D1,OUTPUT); //Watering
pinMode(D5,OUTPUT); //Left motor open window
pinMode(D6,OUTPUT); //Left motor close window
pinMode(D3,OUTPUT); //Right motor open window
pinMode(D8,OUTPUT); //Right motor close window
dht1.setup(D2);
dht2.setup(D7);
dht3.setup(D9); //RX
dht4.setup(D10); //TX
BlynkEdgent.begin();
BlynkEdgent.run();
Temperature1 = dht1.getTemperature();
Humidity1 = dht1.getHumidity();
Temperature2 = dht2.getTemperature();
Humidity2 = dht2.getHumidity();
Temperature3 = dht3.getTemperature();
Humidity3 = dht3.getHumidity();
Temperature4 = dht4.getTemperature();
Humidity4 = dht4.getHumidity();
avg_temperature=(Temperature1+Temperature2+Temperature3+Temperature4)/4.0;
avg_humidity=(Humidity1+Humidity2+Humidity3+Humidity4)/4.0;
soil_moisture_value = analogRead(A0);
percentageSM = map(soil_moisture_value, wet, dry, 100, 0);
Serial.print("Temperature1: " + String(Temperature1) + " *C");
Serial.print("\t");
Serial.println("Humidity1: " + String(Humidity1) + " %");
Serial.println("=================================================");
Serial.print("Temperature2: " + String(Temperature2) + " *C");
Serial.print("\t");
Serial.println("Humidity2: " + String(Humidity2) + " %");
Serial.print("Temperature3: " + String(Temperature3) + " *C");
Serial.print("\t");
Serial.println("Humidity3: " + String(Humidity3) + " %");
Serial.print("Temperature4: " + String(Temperature4) + " *C");
Serial.print("\t");
Serial.println("Humidity4: " + String(Humidity4) + " %");
Serial.print("Average temperature: " + String(avg_temperature) + " *C");
Serial.print("\t");
Serial.println("Average humidity: " + String(avg_humidity) + " %");
Serial.println("Soil Moisture: " + String(percentageSM) + " %");
Blynk.virtualWrite(V6, avg_temperature); //Average temprature uses V6
Blynk.virtualWrite(V7, avg_humidity); //Average Humidity uses V7
Blynk.virtualWrite(V4, percentageSM); //Soil moisture uses V4
delay(2000);
