How To Install Using Arduino Library Manager
This library is a Credentials / WiFi Connection Manager with fallback web configuration portal similar to other WiFiManagers
This library supports Teensy, SAM DUE, SAMD, STM32, etc. boards running ESP8266 AT-command shields.
The web configuration portal, served from the ESP8266 AT-command shields is operating as an access point (AP) with configurable static IP address or use default IP Address of 192.168.4.1
Sample Code
#define _ESP_AT_LOGLEVEL_ 0
#define DEBUG_WIFIMGR true //false
#if ( defined(STM32F0) || defined(STM32F1) || defined(STM32F2) || defined(STM32F3) ||defined(STM32F4) || defined(STM32F7) )
#if defined(ESP8266_AT_USE_STM32)
#undef ESP8266_AT_USE_STM32
#endif
#define ESP8266_AT_USE_STM32 true
#endif
#if ( defined(ARDUINO_SAM_DUE) || defined(__SAM3X8E__) )
#if defined(ESP8266_AT_USE_SAM_DUE)
#undef ESP8266_AT_USE_SAM_DUE
#endif
#define ESP8266_AT_USE_SAM_DUE true
#endif
#if ( defined(ARDUINO_SAMD_ZERO) || defined(ARDUINO_SAMD_MKR1000) || defined(ARDUINO_SAMD_MKRWIFI1010) \
|| defined(ARDUINO_SAMD_NANO_33_IOT) || defined(ARDUINO_SAMD_MKRFox1200) || defined(ARDUINO_SAMD_MKRWAN1300) || defined(ARDUINO_SAMD_MKRWAN1310) \
|| defined(ARDUINO_SAMD_MKRGSM1400) || defined(ARDUINO_SAMD_MKRNB1500) || defined(ARDUINO_SAMD_MKRVIDOR4000) || defined(__SAMD21G18A__) \
|| defined(ARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS) )
#if defined(ESP8266_AT_USE_SAMD)
#undef ESP8266_AT_USE_SAMD
#endif
#define ESP8266_AT_USE_SAMD true
#endif
#ifdef CORE_TEENSY
// For Teensy 4.0
#define EspSerial Serial2 //Serial2, Pin RX2 : 7, TX2 : 8
#if defined(__IMXRT1062__)
#define BOARD_TYPE "TEENSY 4.0"
#elif ( defined(__MKL26Z64__) || defined(ARDUINO_ARCH_AVR) )
#define BOARD_TYPE "TEENSY LC or 2.0"
#else
#define BOARD_TYPE "TEENSY 3.X"
#endif
#elif (ESP8266_AT_USE_SAMD)
// For SAMD
#define EspSerial Serial1
#if defined(ARDUINO_SAMD_ZERO)
#define BOARD_TYPE "SAMD Zero"
#elif defined(ARDUINO_SAMD_MKR1000)
#define BOARD_TYPE "SAMD MKR1000"
#elif defined(ARDUINO_SAMD_MKRWIFI1010)
#define BOARD_TYPE "SAMD MKRWIFI1010"
#elif defined(ARDUINO_SAMD_NANO_33_IOT)
#define BOARD_TYPE "SAMD NANO_33_IOT"
#elif defined(ARDUINO_SAMD_MKRFox1200)
#define BOARD_TYPE "SAMD MKRFox1200"
#elif ( defined(ARDUINO_SAMD_MKRWAN1300) || defined(ARDUINO_SAMD_MKRWAN1310) )
#define BOARD_TYPE "SAMD MKRWAN13X0"
#elif defined(ARDUINO_SAMD_MKRGSM1400)
#define BOARD_TYPE "SAMD MKRGSM1400"
#elif defined(ARDUINO_SAMD_MKRNB1500)
#define BOARD_TYPE "SAMD MKRNB1500"
#elif defined(ARDUINO_SAMD_MKRVIDOR4000)
#define BOARD_TYPE "SAMD MKRVIDOR4000"
#elif defined(ARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS)
#define BOARD_TYPE "SAMD ARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS"
#elif ( defined(__SAM3X8E__) || (__SAM3X8E__) || (__CPU_ARC__) )
#define BOARD_TYPE "SAMD Board"
#else
#define BOARD_TYPE "SAMD Unknown"
#endif
#elif (ESP8266_AT_USE_SAM_DUE)
// For SAM DUE
#define BOARD_TYPE "SAM DUE"
#elif (ESP8266_AT_USE_STM32)
// For STM32F
#define BOARD_TYPE "STM32F"
#else
// For other boards. Change Serial as necessary
#define EspSerial Serial3
#define BOARD_TYPE "Unknown"
#endif
// Must be before #include <ESP_AT_WiFiManager.h>
#define EEPROM_START 0
#include <ESP_AT_WiFiManager.h> //https://github.com/khoih-prog/ESP_AT_WiFiManager
// Your Mega <-> ESP8266 baud rate:
#define ESP8266_BAUD 115200
// SSID and PW for Config Portal
#ifdef CORE_TEENSY
String ssid = "ESP_AT_" + String(0x1ABCDEF, HEX);
#else
String ssid = "ESP_AT_" + String(0xABCDEF, HEX);
#endif
const char* password = "ESP_AT_PW";
IPAddress staticAP_IP = IPAddress(192,168,100,1);
// SSID and PW for your Router
String Router_SSID;
String Router_Pass;
// Onboard LED I/O pin on board
const int LOCAL_PIN_LED = 13; // Pin 13, Controls the onboard LED.
#define LED_ON HIGH
#define LED_OFF LOW
void heartBeatPrint(void)
static int num = 1;
if (WiFi.status() == WL_CONNECTED)
Serial.print("H"); // H means connected to WiFi
Serial.print("F"); // F means not connected to WiFi
if (num == 80)
Serial.println();
num = 1;
else if (num++ % 10 == 0)
Serial.print(" ");
void check_status()
static unsigned long checkstatus_timeout = 0;
//KH
#define HEARTBEAT_INTERVAL 10000L
// Print hearbeat every HEARTBEAT_INTERVAL (10) seconds.
if ((millis() > checkstatus_timeout) || (checkstatus_timeout == 0))
heartBeatPrint();
checkstatus_timeout = millis() + HEARTBEAT_INTERVAL;
void enterConfigPortal(void)
//Local intialization. Once its business is done, there is no need to keep it around
ESP_AT_WiFiManager ESP_AT_wiFiManager;
ESP_AT_wiFiManager.setDebugOutput(true);
ESP_AT_wiFiManager.setMinimumSignalQuality(-1);
ESP_AT_wiFiManager.setAPChannel(1);
// Default AP IP is 192.168.4.1. Uncomment to use different AP IP
ESP_AT_wiFiManager.setAPStaticIPConfig(staticAP_IP);
// Set static STA IP
ESP_AT_wiFiManager.setSTAStaticIPConfig(IPAddress(192,168,2,114));
//Check if there is stored WiFi router/password credentials.
//If not found, device will remain in configuration mode until switched off via webserver.
Serial.print("Opening Config Portal. ");
Router_SSID = ESP_AT_wiFiManager.WiFi_SSID();
Router_Pass = ESP_AT_wiFiManager.WiFi_Pass();
if (Router_SSID != "")
ESP_AT_wiFiManager.setConfigPortalTimeout(60); //If no access point name has been previously entered disable timeout.
Serial.println(F("Got stored Credentials. Timeout 60s"));
Serial.println(F("No stored Credentials. No timeout"));
// SSID to uppercase
ssid.toUpperCase();
//Starts an AP and goes into a blocking loop awaiting configuration
Serial.println("Start Config Portal, SSID = " + ssid + ", Pass = " + password);
digitalWrite(LOCAL_PIN_LED, LED_ON); // Turn led on as we enter Config Portal
if (!ESP_AT_wiFiManager.startConfigPortal((const char *) ssid.c_str(), password))
Serial.println(F("Not connected to WiFi but continuing anyway."));
Serial.println(F("WiFi connected...yeey"));
digitalWrite(LOCAL_PIN_LED, LED_OFF); // Turn led off as we exit Config Portal
// initialize the LED digital pin as an output.
pinMode(LOCAL_PIN_LED, OUTPUT);
digitalWrite(LOCAL_PIN_LED, LED_ON); // turn the LED on by making the voltage LOW to tell us we are in configuration mode.
unsigned long startedAt = millis();
delay(200);
Serial.println("\nStart ConfigOnStartup on " + String(BOARD_TYPE));
// initialize serial for ESP module
EspSerial.begin(115200);
// initialize ESP module
WiFi.init(&EspSerial);
// check for the presence of the shield
if (WiFi.status() == WL_NO_SHIELD)
Serial.println(F("WiFi shield not present"));
// don't continue
while (true);
enterConfigPortal();
// For some unknown reason webserver can only be started once per boot up
// so webserver can not be used again in the sketch.
#define WIFI_CONNECT_TIMEOUT 30000L
#define WHILE_LOOP_DELAY 200L
#define WHILE_LOOP_STEPS (WIFI_CONNECT_TIMEOUT / ( 3 * WHILE_LOOP_DELAY ))
while ( (WiFi.status() != WL_CONNECTED) && (millis() - startedAt < WIFI_CONNECT_TIMEOUT ) )
int i = 0;
while((!WiFi.status() || WiFi.status() >= WL_DISCONNECTED) && i++ < WHILE_LOOP_STEPS)
delay(WHILE_LOOP_DELAY);
Serial.print(F("After waiting "));
Serial.print((millis()- startedAt) / 1000);
Serial.print(F(" secs in setup(), connect result is "));
Serial.print(F("connected. Local IP: "));
// put your main code here, to run repeatedly
check_status();
This is the terminal output when running Teensy 4,0 board with ESP8266 AT shield
Start ConfigOnSwitch on TEENSY 4.0
Opening Config Portal. *WM: Header = ESP_AT, SSID = ****, PW = ****
*WM: Host Name = nothing
Start Config Portal, SSID = ESP_AT_1ABCDEF, Pass = ESP_AT_PW
*WM: Configure AP: ESP_AT_1ABCDEF
*WM: AP PW: ESP_AT_PW
*WM: Custom AP IP: 192.168.100.1
*WM: AP IP: 192.168.100.1
*WM: HTTP server on channel 1
*WM: Handle root
*WM: Info
*WM: Sent info page
*WM: Handle root
*WM: Handle WiFi
*WM: Scan Network
*WM: HueNet / -28
*WM: HueNet1 / -41
*WM: HueNet2 / -59
*WM: Sent config page
*WM: WiFi save
*WM: Sent wifisave page
*WM: Connect to new AP
*WM: Connect wifi with new params
*WM: Data cleared
*WM: Static IP : 192.168.2.114
*WM: Connect result: WL_CONNECTED
After waiting 0 secs in setup(), connect result is connected. Local IP: 192.168.2.114
HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH
And the Config Portal screens:
Updated: Mar 20th 2020
ESP_AT_WiFiManager library v1.0.0 just got included into Arduino Library Manager.
Now you can install this library directly from Arduino Library Manager
