Hi, I have a led strip controller with nodemcu which using blynk. In phone app I have button which toggle the fade, fade speed slider (500 - 10) and zeRGBa whose I use to control led when fade is turned off. When I set slider less than 100 my led start fading like no delay. How can I fix it?
Code:
http://twitter.com/blynk_app
This example runs directly on NodeMCU.
Please be sure to select the right NodeMCU module
in the Tools -> Board menu!
For advanced settings please follow ESP examples :
- ESP8266_Standalone_Manual_IP.ino
- ESP8266_Standalone_SmartConfig.ino
- ESP8266_Standalone_SSL.ino
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "xx";
char pass[] = "xxxxxxxxx";
int REDPIN = 14;
int GREENPIN = 4;
int BLUEPIN = 5;
int toggle, FADESPEED, FADERECEIVE;
int r, g, b;
int ra, ga, ba;
BLYNK_WRITE(V1) //Button Widget is writing to pin V1
toggle = param.asInt();
BLYNK_WRITE(V0) // Widget zeRGBa WRITEs to Virtual Pin V0
ra = param[0].asInt(); // getting red value
ga = param[1].asInt(); // getting green value
ba = param[2].asInt(); // getting blue value
BLYNK_WRITE(V2) //Button Widget is writing to pin V1
FADERECEIVE = param.asInt();
Serial.println("Fade speed: ");
Serial.println(FADERECEIVE);
FADESPEED = FADERECEIVE * 0.01;
if(toggle == 1){
r = 0;
g = 0;
b = 0;
for (r = 0; r < 1023; r++) {
analogWrite(REDPIN, r);
delay(FADESPEED);
if (toggle != 1){break;}
Serial.println("// fade from violet to red");
for (b = 1022; b > 0; b--) {
analogWrite(BLUEPIN, b);
delay(FADESPEED);
Serial.println("// fade from red to yellow");
for (g = 0; g < 1023; g++) {
analogWrite(GREENPIN, g);
delay(FADESPEED);
Serial.println("// fade from yellow to green");
for (r = 1022; r > 0; r--) {
delay(FADESPEED);
Serial.println("// fade from green to teal");
for (b = 0; b < 1023; b++) {
delay(FADESPEED);
Serial.println("// fade from teal to blue");
for (g = 1022; g > 0; g--) {
delay(FADESPEED);
}else{
r = ra;
g = ga;
b = ba;
