I am currently working on a quite complicated project which involves controlling a pump and solenoid valve with 5 different float switches. These together will be used to drain 1/8 of an aquarium and refill it with fresh water. Now, this is my problem, I decided to use the integrated touch sensors in the ESP32 to be able to control the system from either the Blynk app or a small PCB touch Panel. I tried the ESP32`s touch sensor without BLYNK and they worked but when I tried to integrate Blynk I get frequent crashes
This is an example:
21:10:26.619 -> Guru Meditation Error: Core 1 panic'ed (Interrupt wdt timeout on CPU1)
21:10:26.723 -> Core 1 register dump:
21:10:26.723 -> PC : 0x4008b92e PS : 0x00060d34 A0 : 0x8008aa7b A1 : 0x3ffbdf90
21:10:26.828 -> A2 : 0x3ffcb3ec A3 : 0x3ffb8074 A4 : 0x00000001 A5 : 0x00000001
21:10:26.933 -> A6 : 0x00060d23 A7 : 0x00000000 A8 : 0x3ffb8074 A9 : 0x3ffb8074
21:10:27.002 -> A10 : 0x00000018 A11 : 0x00000018 A12 : 0x00000001 A13 : 0x00000001
21:10:27.107 -> A14 : 0x00060d21 A15 : 0x00000000 SAR : 0x00000019 EXCCAUSE: 0x00000006
21:10:27.211 -> EXCVADDR: 0x00000000 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff
21:10:27.281 -> Core 1 was running in ISR context:
21:10:27.350 -> EPC1 : 0x40089f02 EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008b92e
21:10:27.419 ->
21:10:27.419 -> Backtrace: 0x4008b92e:0x3ffbdf90 0x4008aa78:0x3ffbdfb0 0x4008950b:0x3ffbdfd0 0x40101ad9:0x3ffbe010 0x400f0857:0x3ffbe030 0x40102011:0x3ffbe060 0x40102471:0x3ffbe080 0x400ef69e:0x3ffbe0c0 0x400f0159⸮
This occurs very randomly, sometimes when the ESP32 Connects to wifi and sometimes when using the touch inputs. Sometimes the ESP32 resets and does not display a crash.
I have attached the program I am using below. This is a very small part of the complete code because It would be very long to include here.
In this example, I am changing the message on the LCD Widget.
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
int threshold = 10;
int notif = 0;
int lastnotif = 0;
WidgetLCD lcd(V13);
char auth[] = "50107xxxxxxxxxxxxxxxxxxxxxxxxxxxxdcd1071a2";
char ssid[] = "OnePlus";
char pass[] = "oneplus7pro";
touchAttachInterrupt(T4, FILL, threshold);
touchAttachInterrupt(T5, DRAIN, threshold);
touchAttachInterrupt(T0, AUTO, threshold);
touchAttachInterrupt(T2, _OFF, threshold);
BLYNK_WRITE(V0) // Fill
if (param.asInt() == 1)
FILL();
BLYNK_WRITE(V1) // Drain
if ( param.asInt() == 1 )
DRAIN();
BLYNK_WRITE(V5) // Auto
AUTO();
BLYNK_WRITE(V6) // Off
if ((param.asInt() == 1))
_OFF();
void FILL() {
notification(1);
Serial.println("FILL");
void DRAIN() {
notification(2);
Serial.println("DRAIN");
void _OFF() {
notification(16);
Serial.println("OFF");
void AUTO() {
notification(8);
Serial.println("AUTO");
void notification(int notif) {
if (notif != lastnotif) {
lcd.clear();
BLYNK_LOG("Notif = %d", notif);
switch (notif) {
case 1: lcd.print(0, 0, "Draining");
break;
case 2: lcd.print(0, 0, "Drained");
Blynk.notify("Drained");
break;
case 3: lcd.print(0, 0, "Draining");
lcd.print(0, 1, "Bucket Full");
Blynk.notify("Bucket Full");
break;
case 4: lcd.print(0, 0, "Filling");
break;
case 5: lcd.print(0, 0, "Filled");
Blynk.notify("Filled");
break;
case 6: lcd.print(0, 0, "Filling");
lcd.print(0, 1, "Bucket Empty");
Blynk.notify("Bucket Empty");
break;
case 7: lcd.print(0, 0, "Automatic");
lcd.print(0, 1, "Draining");
break;
case 8: lcd.print(0, 0, "Automatic");
break;
case 9: lcd.print(0, 0, "Automatic");
lcd.print(0, 1, "Drained");
break;
case 10: lcd.print(0, 0, "Automatic");
lcd.print(0, 1, "Filling");
break;
case 11: lcd.print(0, 0, "Automatic");
break;
case 12: lcd.print(0, 0, "Done");
Blynk.notify("Done");
break;
case 13: Blynk.notify("Water Detected, Operation Haulted");
lcd.print(0, 0, "Water Detected, Operation Haulted");
break;
case 14: Blynk.notify("Timeout 1hr Passed");
lcd.print(0, 0, "Timeout 1hr Passed");
break;
case 15: lcd.print(0, 0, "Blynk Disconnected");
Blynk.notify("Blynk Disconnected");
break;
case 16:lcd.clear();
break;
default:
//lcd.clear();
break;
lastnotif = notif;
One other problem I also noticed is sometimes the ESP32 Hangs on Connecting to xxxWifi-Namexxxx on the Serial Monitor. The only way to get it to connect is to reset it until it connects successfully.
