Couldn't set own certificate
Hi everybody i couldnt set own certificate so my reset pass and .csv data sender not work.
I try to build crt and pem file and config server.properties but i cant solve that.
Please somebody help me.
The topic you originally posted on started almost two years ago.
I moved your question into it’s own topic. Please supply some further details on your issue…
What are you running Local Server off of?
Do you require your own certificates or can you simple use the built in ones?
Did you follow the current instructions?
I try that but i couldn’t do it.
