Hello Mr Pete I hope you are doing fine and your family can you plz help me to understand how I can fix this problem
Executable segment sizes:
ICACHE : 32768 - flash instruction cache
IROM : 255220 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 28897 / 32768 - code in IRAM (IRAM_ATTR, ISRs…)
DATA : 1564 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 2540 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 27144 ) - zeroed variables (global, static) in RAM/HEAP
Le croquis utilise 288221 octets (27%) de l’espace de stockage de programmes. Le maximum est de 1044464 octets.
Les variables globales utilisent 31248 octets (38%) de mémoire dynamique, ce qui laisse 50672 octets pour les variables locales. Le maximum est de 81920 octets.
esptool.py v3.0
Traceback (most recent call last):
Serial port COM5
File “C:\Users\HP\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2/tools/upload.py”, line 66, in
esptool.main(cmdline)
File “C:/Users/HP/Documents/ArduinoData/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py”, line 3551, in main
esp = chip_class(each_port, initial_baud, args.trace)
File “C:/Users/HP/Documents/ArduinoData/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py”, line 271, in init
self.port = serial.serial_for_url(port)
File "C:/Users/HP/Documents/ArduinoData/packages/esp8266/hardware/esp8266/3.0.2/tools/pyserial\serial_init.py", line 90, in serial_for_url
Une erreur est survenue lors du transfert du croquis
instance.open()
File “C:/Users/HP/Documents/ArduinoData/packages/esp8266/hardware/esp8266/3.0.2/tools/pyserial\serial\serialwin32.py”, line 64, in open
raise SerialException(“could not open port {!r}: {!r}”.format(self.portstr, ctypes.WinError()))
serial.serialutil.SerialException: could not open port ‘COM5’: FileNotFoundError(2, ‘Le fichier sp�cifi� est introuvable.’, None, 2)
