This is my first post here so tell me if I forgot to state anything.
I’m trying to control two separate servos with two separate sliders connected to an ESP32-CAM board. I can’t get the sliders to do anything. The servos are connected to the GPIO 2 and GPIO 4 pins on the board. The sliders in the app are set to V2 and V4 pins. What am I doing wrong?
Blynk library version: 1.0.0-beta.3
Servo library: ServoESP32
#include <Servo.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char auth[] = "token";
char ssid[] = "ssid";
char pass[] = "password";
Servo servo;
BLYNK_WRITE(V3)
servo.write(param.asInt());
servo.attach(2);
servo.attach(4);
You don’t have any BLYNK_WRITE(vPin) callbacks for these pins in your sketch.
When you do a servo.write(), how does that sketch know which servo it’s supposed to be controlling?
Shouldn’t these servo objects have different names?
Thank you, I’ve managed to get some of it working, but now both sliders are controlling the same servo.
New code:
#include <Servo.h>
#include <WiFi.h>
Servo servo1;
int ServoPin1 = 2;
int currentServoPos1 = 0;
Servo servo2;
int ServoPin2 = 4;
int currentServoPos2 = 0;
servo1.attach(ServoPin1);
servo1.attach(ServoPin2);
BLYNK_WRITE(V2)
int pinValue1 = param.asInt(); // assigning incoming value from pin V2 to a variable
int mappedServo1 = map(pinValue1, 0, 1023, 1, 180);
currentServoPos1 = servo1.read();
Serial.print(" current servo Position is: ");
Serial.println(currentServoPos1);
Serial.print(" current slider Position is: ");
Serial.println(mappedServo1);
if ( mappedServo1 < currentServoPos1)
delay(100);
servo1.write(mappedServo1 -1);
else if (mappedServo1 > currentServoPos1)
delay(100);
servo1.write(mappedServo1 +1);
BLYNK_WRITE(V4)
int pinValue2 = param.asInt(); // assigning incoming value from pin V4 to a variable
int mappedServo2 = map(pinValue2, 0, 1023, 1, 180);
currentServoPos1 = servo2.read();
Serial.println(currentServoPos2);
Serial.println(mappedServo2);
if ( mappedServo2 < currentServoPos2)
delay(100);
servo1.write(mappedServo2 -1);
else if (mappedServo2 > currentServoPos2)
delay(100);
servo1.write(mappedServo2 +1);
