i am total begginer .i want to control two dc motor with blynk for rc car .i get it to work with arduino uo board and now i want to connect to android through blynk .i searched web but dont get mush help.how do i connect it to blynk .i have a ESP 12E wifi module.can some body provide me a sketch and code for the same
i got this code from this forum but no physical connection of wires given.
//#define BLYNK_DEBUG
int motorA ;
int motorB ;
int X=0;
int Y=0;
int Steer=0;
int maximo=0;
char auth[] = "b41ff7f1659b4badb694be4c59601c2c";
// Set console baud rate
Blynk.begin(auth,"100Grand","Mob4life");
pinMode(motorA, OUTPUT);
pinMode(motorB, OUTPUT);
pinMode(0,OUTPUT);
pinMode(2,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
BLYNK_WRITE(V1)
int X1 = param[0].asInt();
X=X1;
int Y1 = param[1].asInt();
Y=Y1;
BLYNK_WRITE(V0)// slider de 100 a 255!!!!
int vel = param.asInt();
maximo=vel;
if(X == 128 && Y == 128) // Stop
motorA = 0;
motorB = 0;
analogWrite(5, motorA);
analogWrite(4, motorA);
analogWrite(0, motorB);
analogWrite(2, motorB);
if(Y > 130 && X > 127 && X < 129) //Forward
motorA = Y;
motorB = Y;
motorA = map(motorA, 450,maximo,130, 255);
digitalWrite(0,LOW);
motorB = map(motorA, 450,maximo,130, 255);
analogWrite(4, motorB);
digitalWrite(2,HIGH);
else if(Y < 126 && X > 127 && X < 129) //Reverse
motorA = Y;
motorB = Y;
motorA = map(motorA, 450,maximo,126, 0);
digitalWrite(0,HIGH);
motorB = map(motorA, 450,maximo,126, 0);//something is wrong with HIGH signal
digitalWrite(2,LOW);
if(Y > 130 && X < 126) //Steer Left
motorA = Y;
motorB = Y;
Steer = map(X, 450,maximo, 126,0);
Steer = X / maximo;
analogWrite(5, motorA * (1 + Steer));
analogWrite(4, motorB * (1 - Steer));
if(Y > 130 && X > 130) //Steer Right
motorA = Y;
motorB = Y;
Steer = X / maximo;
analogWrite(5, motorA * (1 - Steer));
analogWrite(4, motorB * (1 + Steer));
