Can anyone copy paste some code for controlling the speed and direction of a dc motor with a joystick(Horizontal)
thanks in advance.
thanks in advance.
Can you do that without Blynk?
Well I think so?
maybe not the two at the same time?
First of all, you should make it work without Blynk. Then decide on the communication (wifi, ethernet…etc)
Then add Blynk on top of it, which is really easy.
Well I don’t have a joystick but i did do it with 2 buttons (forwards and backwards)
How does your internet connection look like?
Check out documentation on how to use virtual pins and you should be good to go.
Ah thanks that helps
I’m basically doing the same with an old stepper motor of a printer. You should get a motor driver as not to overload your Arduino (or other hardware). But as @Pavel said, it should be done in about no time with Blynk.
Can you post your current Sketch/code of what you made so far? I’d be happy to take a look as how to incorporate Blynk for you
Here is what I have so far. I had great success with this method on a romeo ble but not so much on NodeMCU (ESP8266) with Blynk Standalone and Merged Joystick.
* Downloads, docs, tutorials: http://www.blynk.cc
* Blynk community: http://community.blynk.cc
* Social networks: http://www.fb.com/blynkapp
* http://twitter.com/blynk_app
* This example runs directly on ESP8266 chip.
* You need to install this for ESP8266 development:
* https://github.com/esp8266/Arduino
* Please be sure to select hte right ESP8266 module
* in the Tools -> Board menu!
* Change WiFi ssid, pass, and Blynk auth token to run :)
char auth[] = "************";
//Standard PWM DC control
int E1 = 5; //M1 Speed Control D1 Motor A
int E2 = 4; //M2 Speed Control D2 Motor B
int M1 = 0; //M1 Direction Control D3 Motor A
int M2 = 2; //M2 Direction Control D4 Motor B
/* --GPIO Define
2 function initGPIO()
3 --1,2EN D1 GPIO5
4 --3,4EN D2 GPIO4
5 --1A ~2A D3 GPIO0
6 --3A ~4A D4 GPIO2
pinMode(5, OUTPUT);//power to motor
pinMode(4, OUTPUT);//power to motor
pinMode(0, OUTPUT);//Reverse Motor Direction
pinMode(2, OUTPUT);//Reverse Motor Direction
Blynk.begin(auth, "********", "*******");
// This function will be called every time
// when App writes value to Virtual Pin 1
BLYNK_WRITE(V1) {
int x = param[0].asInt();
int y = param[1].asInt();
// Do something with x and y
Serial.print("X = ");
Serial.print(x);
Serial.print("; Y = ");
Serial.println(y);
if (y > 30){
analogWrite (E1,-y); //PWM Speed Control 4
digitalWrite(M1,LOW);
analogWrite (E2,-y+abs(x/2)); //5
digitalWrite(M2,HIGH);
else if (y < -30){
analogWrite (E1,y+abs(x/2)); //PWM Speed Control 4
digitalWrite(M1,HIGH);
analogWrite (E2,y); //5
digitalWrite(M2,LOW);
/* if (y > 30 && x < -30){
analogWrite (E1,1-(y+abs(x))); //PWM Speed Control
analogWrite (E2,1-(y-abs(x)));
if (y > 30 && x > 30){
analogWrite (E1,1-(y-abs(x))); //PWM Speed Control
analogWrite (E2,1-y+abs(x));
/* else if (x < -30 && y > 0){
// analogWrite (E1,1+(y-abs(x))); //PWM Speed Control
analogWrite (E1,-y-abs(x));
analogWrite (E2,-y+abs(x));
else if (x > 30 && y > 0){
analogWrite (E1,-y+abs(x)); //PWM Speed Control
analogWrite (E2,-y-abs(x));
else {
analogWrite (E1,0);
analogWrite (E2,0);
What i have now is pretty simple, it uses 4 button widgets for controlling the rc
include "blynk/blynk.h"
#include "blynk/blynk.h"
const int motorIn1 = D6;
const int motorIn2 = D5;
const int motorIn3 = D4;
const int motorIn4 = D3;
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
pinMode(motorIn1,OUTPUT);
pinMode(motorIn2,OUTPUT);
pinMode(motorIn3,OUTPUT);
pinMode(motorIn4,OUTPUT);
delay(5000);
Blynk.begin(auth);
void Clockwise(int Speed)
digitalWrite(motorIn1,Speed);
digitalWrite(motorIn2,0);
void Counterclockwise(int Speed)
analogWrite(motorIn1,0);
analogWrite(motorIn2,Speed);
digitalWrite(motorIn3,Speed);
digitalWrite(motorIn4,0);
analogWrite(motorIn3,0);
analogWrite(motorIn4,Speed);
BLYNK_WRITE(10)
if (param.asInt())
Clockwise(255);
digitalWrite(motorIn1,LOW);
(I am using a Spark core)
This looks pretty awesome did you have to include any specific libraries for the spark core to work with this code besides Blynk? Are all these variables local to the sketch?
Only The Blynk Library Was included
I just realised i did a redefenition of "Clockwise" and "Counterclockwise" here's the working code
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
delay(5000);
Blynk.begin(auth);
void ClockWise(int Speed)
void CounterclockWise(int Speed)
BLYNK_WRITE(10)
if (param.asInt())
Clockwise(255);
Please edit your post. Code should be formatted.
Wrap the code by pressing this magic button (Backtick`) 3 times (before the code and after it):**
Example:
``` <--- insert this
Paste your code here
This makes your code beautiful with highlighted syntax, like this:
//comment goes here
void helloWorld() {
String message = "hello" + "world";
You can also select the code and press </> button in the top menu:
I changed it, thanks
Hi! I am making a project like this one! Using 4 buttons for controls
I had trouble in using the blynk buttons. Could you please help me? :’( pleassse
Get it working with physical buttons first… then convert them to Blynk buttons.
Working forward instead of backwards will eliminate problems
do you know the flow chart of this?
