I am working on a project to control a RGB led strip via the blynk app.
Unfortunately, my code isn’t working. I have searched my mistake but I couldn’t find it.
Could anybody help me?
Thanks in advance!
Tom
// These are the interrupt and control pins for СС3000
#define ADAFRUIT_CC3000_IRQ 3
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
#include <Adafruit_CC3000.h>
#include <BlynkSimpleCC3000.h>
char auth[] = “XXX”;
// Choose wifi_sec from WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
char ssid[] = “XXX”;
char pass[] = “XXX”;
int wifi_sec = WLAN_SEC_WPA2;
// Output
int redPin = 6; // Red LED, connected to digital pin 9
int grnPin = 9; // Green LED, connected to digital pin 10
int bluPin = 11; // Blue LED, connected to digital pin 11
int BlynkBlue;
int BlynkRed;
int BlynkGreen;
// Color arrays
int black[3] = { 0, 0, 0 };
int white[3] = { 100, 100, 100 };
int red[3] = { 100, 0, 0 };
int green[3] = { 0, 100, 0 };
int blue[3] = { 0, 0, 100 };
int yellow[3] = { 40, 95, 0 };
int dimWhite[3] = { 30, 30, 30 };
// etc.
// Set initial color
int redVal = black[0];
int grnVal = black[1];
int bluVal = black[2];
int wait = 10; // 10ms internal crossFade delay; increase for slower fades
int hold = 20; // Optional hold when a color is complete, before the next crossFade
int DEBUG = 0; // DEBUG counter; if set to 1, will write values back via serial
int loopCount = 60; // How often should DEBUG report?
int repeat = 0; // How many times should we loop before stopping? (0 for no stop)
int j = 0; // Loop counter for repeat
int mode = 0;
// Initialize color variables
int prevR = redVal;
int prevG = grnVal;
int prevB = bluVal;
Blynk.begin(auth, ssid, pass, wifi_sec);
pinMode(redPin, OUTPUT); // sets the pins as output
pinMode(grnPin, OUTPUT);
pinMode(bluPin, OUTPUT);
if (DEBUG) { // If we want to see values for debugging…
Serial.begin(9600); // …set up the serial ouput
delay(100);
// Set up the LED outputs
BLYNK_WRITE(V1)
mode= param.asInt();
BLYNK_WRITE(V6)
BlynkRed= param.asInt();
BLYNK_WRITE(V7)
BlynkGreen = param.asInt();
BLYNK_WRITE(V8)
BlynkBlue = param.asInt();
/* BELOW THIS LINE IS THE MATH – YOU SHOULDN’T NEED TO CHANGE THIS FOR THE BASICS
- The program works like this:
- Imagine a crossfade that moves the red LED from 0-10,
- the green from 0-5, and the blue from 10 to 7, in
- ten steps.
- We’d want to count the 10 steps and increase or
- decrease color values in evenly stepped increments.
- Imagine a + indicates raising a value by 1, and a -
- equals lowering it. Our 10 step fade would look like:
- 1 2 3 4 5 6 7 8 9 10
- R + + + + + + + + + +
- G + + + + +
- B - - -
- The red rises from 0 to 10 in ten steps, the green from
- 0-5 in 5 steps, and the blue falls from 10 to 7 in three steps.
- In the real program, the color percentages are converted to
- 0-255 values, and there are 1020 steps (255*4).
- To figure out how big a step there should be between one up- or
- down-tick of one of the LED values, we call calculateStep(),
- which calculates the absolute gap between the start and end values,
- and then divides that gap by 1020 to determine the size of the step
- between adjustments in the value.
int calculateStep(int prevValue, int endValue) {
int step = endValue - prevValue; // What’s the overall gap?
if (step) { // If its non-zero,
step = 1020/step; // divide by 1020
return step;
/* The next function is calculateVal. When the loop value, i,
- reaches the step size appropriate for one of the
- colors, it increases or decreases the value of that color by 1.
- (R, G, and B are each calculated separately.)
int calculateVal(int step, int val, int i) {
if ((step) && i % step == 0) { // If step is non-zero and its time to change a value,
if (step > 0) { // increment the value if step is positive…
val += 1;
else if (step < 0) { // …or decrement it if step is negative
val -= 1;
// Defensive driving: make sure val stays in the range 0-255
if (val > 255) {
val = 255;
else if (val < 0) {
val = 0;
return val;
/* crossFade() converts the percentage colors to a
- 0-255 range, then loops 1020 times, checking to see if
- the value needs to be updated each time, then writing
- the color values to the correct pins.
void crossFade(int color[3]) {
// Convert to 0-255
int R = (color[0] * 255) / 100;
int G = (color[1] * 255) / 100;
int B = (color[2] * 255) / 100;
int stepR = calculateStep(prevR, R);
int stepG = calculateStep(prevG, G);
int stepB = calculateStep(prevB, B);
for (int i = 0; i <= 1020; i++) {
redVal = calculateVal(stepR, redVal, i);
grnVal = calculateVal(stepG, grnVal, i);
bluVal = calculateVal(stepB, bluVal, i);
analogWrite(redPin, redVal); // Write current values to LED pins
analogWrite(grnPin, grnVal);
analogWrite(bluPin, bluVal);
delay(wait); // Pause for 'wait' milliseconds before resuming the loop
if (DEBUG) { // If we want serial output, print it at the
if (i == 0 or i % loopCount == 0) { // beginning, and every loopCount times
Serial.print("Loop/RGB: #");
Serial.print(i);
Serial.print(" | ");
Serial.print(redVal);
Serial.print(" / ");
Serial.print(grnVal);
Serial.println(bluVal);
DEBUG += 1;
// Update current values for next loop
prevR = redVal;
prevG = grnVal;
prevB = bluVal;
delay(hold); // Pause for optional ‘wait’ milliseconds before resuming the loop
// Main program: list the order of crossfades
if(mode == 0)
crossFade(red);
crossFade(green);
crossFade(blue);
crossFade(yellow);
crossFade(dimWhite);
analogWrite(redPin, BlynkRed); // Write current values to LED pins
analogWrite(grnPin, BlynkGreen);
analogWrite(bluPin, BlynkBlue);
