* Description
* Controlling led strip over wifi using Blynk library and nodemcu (ESP8266)
* Input
* LDR
* A0: One leg of the LDR is connected to VCC (5V) on the Arduino, and the other to the analog pin 0 on the Arduino. A 100K resistor is also connected to the same leg and grounded.
* BTN
* V2 : Virtual Blynk Button
* Output
* LED
* D7: Voltage HIGH | LOW
* Note: When the button is turned on, it bypasses the LDR sensor. In other words the led strip works continuously
// Constants
char auth[] = "auth token";
char ssid[] = "ssid";
char pass[] = "ssid password";
const int digitalPinD7 = 13;
// Objects
//WidgetLED led(V3);
// Variables
int buttonVirtualPin;
int ldrSensorData;
BLYNK_WRITE(V2)
buttonVirtualPin = param.asInt();
//Serial.print("V2 value is: ");
//Serial.println(buttonVirtualPin);
void sendSensor()
ldrSensorData = analogRead(A0); //reading the sensor on A0
if ( isnan(ldrSensorData) ){
Serial.println("Failed to read from LDR sensor!");
return;
//Serial.println(ldrSensorData);
if ( buttonVirtualPin == 1 )
digitalWrite(13, HIGH);
if ( ldrSensorData < 400 ) {
digitalWrite(13, LOW);
WiFi.hostname("Aethelwulf"); // all my devices have Vikings name (I know it's geek)
timer.setInterval(3000L, sendSensor);
