Hello everyone!
I am currently facing a problem which looks trivial even to me, if not for the fact that i can’t solve it!
I have written a simple code that allows me to control several LEDs with Widgets. What i would like to do now is to have a push button turn off one of these LEDs when it is pressed. Simple enough. However, i can’t get it to work!
I’ve written a different code to read the button values and test if everything works as it should and it does indeed work as intended, so i know the hardware isn’t the problem, nor is it the overall code. But i can’t get to replicate the result in the blynk code!
I’ve tried reading the button from the loop function and from the BLYNK_WRITE() function, but it just… doesn’t. I get no readings and therefore no hardware control based on said readings.
Does anyone see what i’m doing wrong?
This is the code:
#define BLYNK_TEMPLATE_ID ""
#define BLYNK_TEMPLATE_NAME ""
#define BLYNK_AUTH_TOKEN ""
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32_SSL.h>
char ssid[] = "";
char pass[] = "";
BLYNK_WRITE(V0){
if(param.asInt()==1){
digitalWrite(5,HIGH);
digitalWrite(5,LOW);
BLYNK_WRITE(V1){
digitalWrite(21,HIGH);
digitalWrite(21,LOW);
BLYNK_WRITE(V4){
digitalWrite(2,HIGH);
Blynk.setProperty(V5,"isDisabled",true);
digitalWrite(2,LOW);
Blynk.setProperty(V5,"isDisabled",false);
BLYNK_WRITE(V5){
digitalWrite(4,HIGH);
Blynk.setProperty(V4,"isDisabled",true);
digitalWrite(4,LOW);
Blynk.setProperty(V4,"isDisabled",false);
if(digitalRead(14)==LOW){
Serial.println("off") //this will become digitalWrite(something) as soon as i understand how to get the readings
pinMode(2,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(21,OUTPUT);
pinMode(14,INPUT_PULLUP);
