I am a beginner with blynk and recently wrote some code to control two DC motors on Raspberry Pi 2. The code works perfectly fine but i can’t find a way to control them using blynk.
I control the motors with the keys “w a s d” with a l293d motor driver IC.
Here is the code:
#!/usr/local/bin/python
import RPi.GPIO as GPIO
from time import sleep
import time
import os
import sys
from msvcrt import getch
import termios
import tty
TERMIOS=termios
f_t = "MOVING FORWARDS"
b_t = "MOVING BACKWARDS"
a_t = "TURNING ANTI-CLOCKWISE"
c_t = "TURNING CLOCKWISE"
GPIO.setmode(GPIO.BOARD)
GPIO.setwarnings(False)
Motor1A = 16
Motor1B = 18
Motor1E = 22
Motor2A = 19
Motor2B = 21
Motor2E = 23
delay = 0.2
GPIO.setup(Motor1A,GPIO.OUT)
GPIO.setup(Motor1B,GPIO.OUT)
GPIO.setup(Motor1E,GPIO.OUT)
GPIO.setup(Motor2A,GPIO.OUT)
GPIO.setup(Motor2B,GPIO.OUT)
GPIO.setup(Motor2E,GPIO.OUT)
def getkey():
fd = sys.stdin.fileno()
old = termios.tcgetattr(fd)
new = termios.tcgetattr(fd)
new[3] = new[3] & ~TERMIOS.ICANON & ~TERMIOS.ECHO
new[6][TERMIOS.VMIN] = 1
new[6][TERMIOS.VTIME] = 0
termios.tcsetattr(fd, TERMIOS.TCSANOW, new)
c = None
try:
c = os.read(fd, 1)
finally:
termios.tcsetattr(fd, TERMIOS.TCSAFLUSH, old)
return c
def forwards():
print(f_t)
GPIO.output(Motor1A,GPIO.HIGH)
GPIO.output(Motor1B,GPIO.LOW)
GPIO.output(Motor1E,GPIO.HIGH)
GPIO.output(Motor2A,GPIO.LOW)
GPIO.output(Motor2B,GPIO.HIGH)
GPIO.output(Motor2E,GPIO.HIGH)
time.sleep(delay)
GPIO.output(Motor1E,GPIO.LOW)
GPIO.output(Motor2E,GPIO.LOW)
def backwards():
print(b_t)
GPIO.output(Motor1A,GPIO.LOW)
GPIO.output(Motor1B,GPIO.HIGH)
GPIO.output(Motor2A,GPIO.HIGH)
GPIO.output(Motor2B,GPIO.LOW)
time.sleep(delay)
def t_a():
print(a_t)
time.sleep(0.25)
def t_c():
print(c_t)
time.sleep(delay)
count=0
while count < 1:
key=getkey()
if key=="w":
forwards()
elif key=="s":
backwards()
elif key=="a":
t_a()
elif key=="d":
t_c()
elif key=="e":
print("EXIT")
sys.exit(0)
else:
print("no key")
count=0
I want to switch on and off the motor from the app on android.
Thanks for any help
