I found this code by searching here and it is incredibly close to what I want. I have 3 buttons on my Blynk app that each turn on a light. Then I also have 3 momentary physical buttons that each turn on the same set of lights. The only thing missing is if I turn on a light with the app and the app shows the light being on, I would like the button on the app to turn off if I turn the lights off with the physical button and also show on if I turn it on with the physical button.
What happens now is if I turn the light on with the app, it shows on, but if I turn the light off with the physical button, the app still shows on.
#include <WiFiNINA.h>
#include <BlynkSimpleWiFiNINA.h>
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "xxxxx";
char pass[] = "xxxxx";
// Set your LED and physical button pins here
const int ledPin1 = 9;
const int ledPin2 = 11;
const int ledPin3 = 12;
const int ledPin4 = 15;
const int btnPin1 = 2;
const int btnPin2 = 3;
const int btnPin3 = 4;
const int btnPin4 = 0;
void checkPhysicalButton();
int led1State = LOW;
int btn1State = HIGH;
int led2State = LOW;
int btn2State = HIGH;
int led3State = LOW;
int btn3State = HIGH;
int led4State = LOW;
int btn4State = HIGH;
// Every time we connect to the cloud...
BLYNK_CONNECTED() {
Blynk.syncVirtual(V12);
Blynk.syncVirtual(V13);
Blynk.syncVirtual(V14);
Blynk.syncVirtual(V15);
// Alternatively, you could override server state using:
//Blynk.virtualWrite(V12, led1State);
//Blynk.virtualWrite(V13, led2State);
//Blynk.virtualWrite(V14, led3State);
//Blynk.virtualWrite(V15, led4State);
// When App button is pushed - switch the state
BLYNK_WRITE(V12) {
led1State = param.asInt();
digitalWrite(ledPin1, led1State);
BLYNK_WRITE(V13) {
led2State = param.asInt();
digitalWrite(ledPin2, led2State);
BLYNK_WRITE(V14) {
led3State = param.asInt();
digitalWrite(ledPin3, led3State);
BLYNK_WRITE(V15) {
led4State = param.asInt();
digitalWrite(ledPin4, led4State);
if (digitalRead(btnPin1) == LOW) {
// btn1State is used to avoid sequential toggles
if (btn1State != LOW) {
// Toggle LED state
led1State = !led1State;
// Update Button Widget
btn1State = LOW;
btn1State = HIGH;
if (digitalRead(btnPin2) == LOW) {
if (btn2State != LOW) {
// Toggle LED state
led2State = !led2State;
btn2State = LOW;
btn2State = HIGH;
if (digitalRead(btnPin3) == LOW) {
if (btn3State != LOW) {
// Toggle LED state
led3State = !led3State;
btn3State = LOW;
btn3State = HIGH;
if (digitalRead(btnPin4) == LOW) {
if (btn4State != LOW) {
// Toggle LED state
led4State = !led4State;
btn4State = LOW;
btn4State = HIGH;
{ pinMode(ledPin1, OUTPUT);
pinMode(btnPin1, INPUT_PULLUP);
timer.setInterval(100L, checkPhysicalButton);}
{ pinMode(ledPin2, OUTPUT);
pinMode(btnPin2, INPUT_PULLUP);
pinMode(ledPin3, OUTPUT);
pinMode(btnPin3, INPUT_PULLUP);
{ pinMode(ledPin4, OUTPUT);
pinMode(btnPin4, INPUT_PULLUP);
// Setup a function to be called every 100 ms
