hi guys, I am learning how to control dfplayer mini module over wifi, can you share your experience to me? Thank you.
hi guys, I do a lot of research about blynk music player widget, however not much information from the internet…can you share it with me? Thank you.
- how music player widget works?
- control module?MP3?
- how to connect the jumpers?
Thank you
This depends on if the module even has TTL type controls that can be manipulated by Arduino or ESP digital pins.
Not a clue what you are referring to.
1.Connection and Diagram can be found here https://www.dfrobot.com/wiki/index.php/DFPlayer_Mini_SKU:DFR0299#Connection_Diagram 2.This code is tested on Arduino Uno, Leonardo, Mega boards.
