Hola a todos!
ACLARO QUE SOY UN NEÓFITO EN ESTO
Luego de luchar durante mas de 3 días y perder el sueño por los enojos y el esfuerzo mental, finalmente conseguí hacer funcionar un sistema de control de temperatura remoto vía wifi (ESP8266+DHT11+Cargador de celular) y un receptor que se encarga de activar la caldera (ESP8266+Relay+Cargaor de celular)
Hi all!
LET ME FIRST BE CLEAR… I AM A NEOPHYTE IN THIS
After struggling for more than 3 days and losing sleep due to anger and mental effort, I finally managed to operate a remote temperature control system via wifi (ESP8266 + DHT11 + Cell phone charger) and a receiver which is responsible for activating the boiler (ESP8266 + Relay + Cell phone charger)
PROYECTO ESCRITO POR Emanuel Barboni
Basado en el proyecto ThermoX de Eric "chrome1000"
SENSOR DE HUMEDAD Y TEMPERATURA BASADO EN ESP8266+DHT11
#include <DHT.h>
#define DHTTYPE DHT11
#define DHTPIN 2
BlynkTimer timer; // cada un determinado tiempo envia la medición
float TempDes = 21;
float TempAct;
int TempCorrection = 0;
int UpdateFrequency = 5000L; //Update frequency in milliseconds
float LastRead;
float Hu;
int Hysteresis_W = 1; //Summer and Winter hysteresis levels
char auth[] = "XXXXXXXX"; //Enter the Auth code which was send by Blink
char ssid[] = "XXXXXXXXX"; //Enter your WIFI Name
char pass[] = "XXXXXXXXX"; //Enter your WIFI Password
WidgetBridge bridge1(V23); //Initiating Bridge Widget on V1 of Device A
DHT dht(DHTPIN, DHTTYPE, 11); // 11 works fine for ESP8266
Blynk.begin(auth, ssid, pass); // Call blynkAnotherDevice every second
timer.setInterval(4000L, TempUpdate); // EJECUTA MEDICION CADA 4 SEGUNDOS
dht.begin();
// empareja la temperatura deseada con el slider
BLYNK_WRITE(V1){
TempDes = param.asInt();
Blynk.virtualWrite(1,TempDes);
// empareja la Estación deseada con el botón
BLYNK_WRITE(V8){
Hysteresis_W = param.asInt();
Blynk.virtualWrite(8,Hysteresis_W);
// bridge the radiator sensor on or off
void TempUpdate () {
float ReadF = dht.readTemperature();
float Hu = dht.readHumidity();
if (isnan(Hu) || isnan(ReadF)) {
return;
//Emision a la app para monitorear
Blynk.virtualWrite(V5, Hu);
if (isnan(ReadF)) {
return;
else { //Read gets averaged with previous read and limited to 1 degree at a time change
int TempAvg = (int)((ReadF + LastRead + (2 * TempCorrection)) / 2);
if (TempAvg >= TempAct + 1) {
TempAct = TempAct + 1;
if (TempAvg <= TempAct - 1) {
TempAct = TempAct - 1;
LastRead = ReadF;
Blynk.virtualWrite(V6, TempAct); //Report actual temperature in app
if (TempAct < TempDes) {
bridge1.digitalWrite(0, LOW); // Digital Pin 2 on the second board will be set HIGH
bridge1.virtualWrite(V23, 1); // Sends 1 value to BLYNK_WRITE(V23) handler on receiving side.
else if (TempAct >= (TempDes + Hysteresis_W)) {
bridge1.digitalWrite(0, HIGH); // Digital Pin 2 on the second board will be set HIGH
bridge1.virtualWrite(V23, 0); // Sends 1 value to BLYNK_WRITE(V23) handler on receiving side.
BLYNK_CONNECTED() {
bridge1.setAuthToken("XXXXXXXXX"); // Place the AuthToken of the second hardware here
// the loop function runs over and over again forever
yield();
Programa para el lado del Relay
Relay side program
Basado en el proyecto Blynk Bridge www.geekstips.com
SENSOR DE HUMEDAD Y TEMPERATURA BASADO EN ESP8266+Relay v4.0
char auth[] = "XXXXXXXXXXXXXXXXX";
char ssid[] = "XXXXXXX";
char pass[] = "XXXXXXX";
// This code will update the virtual port 5
BLYNK_WRITE(V23) {
int pinData = param.asInt();
Blynk.virtualWrite(V24, 255);// Avisa el estado al led
void setup(){
void loop(){
Espero les sea útil como lo es para mi.
Saludos!
I hope you find it useful as it is for me.
Regards!
