Guys, how can I get control a step motor with blynk? I tryed do a virtual slider control the rpm, but I failed
I would also use virtual pin for that. Could you provide more details.
Set up
Arduino model
Connection type
Mobile OS
Device
Code
It’s hard to tell without knowing it.
first question I have is how do you control it today? take Blynk out of the equation. how are you accomplishing the task now? (It will be easy to recommend how to put blynk into it once you know that)
I tried something like servo example:
#include <Stepper.h>
const int stepsPerRevolution = 200;
Stepper myStepper(stepsPerRevolution, 8,9,10,11);
Blynk.begin(auth);
BLYNK_WRITE(1)
myStepper.setSpeed(asInt()); **// rpm**
But in step motor code you need to put this part :
myStepper.step(stepsPerRevolution);
delay(500);
myStepper.step(-stepsPerRevolution);
delay(500);
I thing that my mistake is here, were I put this part ?
And the details :
Arduino Mega 2560, Ethernet module W5100, iPhone 6 plus and ios 8.1.3
Please format code by selecting it and pressing Ctrl+K before posting
Blynk.begin(auth);
BLYNK_WRITE(1)
delay(500);
delay(500);
You may want to do a little homework around the web, this project and community isnt really focused on “how to” with code.
here are some links to jump start you… once you have it working without Blynk… it will be real easy to add Blynk ![]()
http://www.arduino.cc/en/reference/stepper
http://www.arduino.cc/en/Tutorial/MotorKnob
Even that, I can’t do the step motor works with Blynk. I didn’t understand very well the library and how it works
It seems that you have modified the example and not getting the parameter from Virtual Pin correctly.
// Here you state that you have a widget (e.g Slider)
// attached to Virtual Pin 1
BLYNK_WRITE(1)
vpinValue = param.asInt(); // This is the value you get from the Slider
myStepper.setSpeed(pinValue); // Here you write this value to your motor
It should work. Let me know.
#include <Ethernet.h>
#include <BlynkEthernet.h>
int pinValue=0;
Stepper myStepper(stepsPerRevolution,53,51,49,47);
char auth[] = "b52126f2528748b38d6dd65b30d22762";
Blynk.begin(auth);
BLYNK_WRITE (1){
pinValue=(param.asInt());
delay(500);
delay(500);
I tried to change the location(before and after blynk.run), tried to put in (BLYNK_WRITE), I even tried to cut off this part :
delay(500);
delay(500);
But with no success
Daniel, what are you trying to achieve? Change the speed of the motor with the Slider Widget? Or rotate it with the slider?
Did you have any success making it work without Blynk? It’s really hard to help you without understanding your end goal
I’m just trying to change the speed. Yes, I can do this without Blynk. The only thing I don’t get it is how can I put the Blynk in this system? How use the code?
Really thank you for your help
ahh that helps a lot… so here is a draft for you…
* You can use this sketch as a debug tool that prints all incoming values
* sent by a widget connected to a Virtual Pin 1 in the Blynk App.
* App dashboard setup:
* Slider widget (0...100) on V1
// This function will be called every time
// when App writes value to Virtual Pin 1
BLYNK_WRITE(1)
// BLYNK_LOG("Got a value: %s", param.asStr());
// You can also use: asInt() and asDouble()
int stepsPerRevolution = param.asInt();
Geab, how did you do to work?
@DanielFerreira seems I was to positive to early
I thought I could control the blinking freq of the LED on the Arduino UNO with a delay via a slider on V3
BLYNK_WRITE(3)
int timeled = param.asInt();
digitalWrite(13, HIGH);
delay(timeled);
digitalWrite(13, LOW);
but so far I fail
this may put you back on track…
int led = 13;
int timeled = 1000;
BLYNK_WRITE(1)
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(timeled); // wait
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
good idea @Spudgunman did modify your input to fit into what I have tried earlier
SoftwareSerial SwSerial(10, 11);
#define BLYNK_PRINT SwSerial
#include <BlynkSimpleSerial.h>
char auth[] = "";
int timeled = 400;
pinMode(13, OUTPUT);
SwSerial.begin(9600);
Blynk.begin(auth);
timer.setInterval(1000, sendUptime);
void sendUptime()
Blynk.virtualWrite(5, millis()/1000);
Blynk.virtualWrite(6, millis()/1000);
BLYNK_READ(5)
// This command writes Arduino's uptime in seconds to Virtual Pin (5)
Blynk.virtualWrite(5, timeled);
BLYNK_WRITE(3)
//timer.setInterval(50, Blink_On);
the virtual pin 5 will either show the uptime of the arduino or timeled
The uptime works fine but the timeled will stay at the 400 defined in the beginning of the sketch
int timeled = 400;
whats on virtual pin 3 in the blynk app? also uncomment the log shown here to help you debug
also so people dont mess with you - you may want to remove your API key from that last post.
