I am a total novice to coding.
I can get the app to work the way I want it to, but now I need to have physical buttons at the location to operate the relay module. Here is the code as I have it so far:
#define BLYNK_TEMPLATE_ID "xxxxxxxxx"
#define BLYNK_DEVICE_NAME "Testing Template"
#define BLYNK_AUTH_TOKEN "xxxxxxxxx"
char ssid[] = "xxxxxxxxx";
char pass[] = "xxxxxxxxx";
// Set your LED and physical button pins here
const int ledPin1 = 2;
const int ledPin2 = 2;
const int ledPin3 = 2;
const int btnPin1 = 1;
const int btnPin2 = 3;
const int btnPin3 = 13;
const int btnPin4 = 15;
void checkPhysicalButton();
int ledState = LOW;
int btnState = HIGH;
int RelayPin1 = 4;
int RelayPin2 = 5;
int RelayPin3 = 12;
int RelayPin4 = 14;
// Every time we connect to the cloud...
BLYNK_CONNECTED() {
Blynk.syncVirtual(V0);
Blynk.syncVirtual(V1);
Blynk.syncVirtual(V2);
Blynk.syncVirtual(V3);
BLYNK_WRITE(V0) {
int pinValue = param.asInt();
digitalWrite(RelayPin1, pinValue);
BLYNK_WRITE(V1) {
digitalWrite(RelayPin2, pinValue);
BLYNK_WRITE(V2) {
digitalWrite(RelayPin3, pinValue);
BLYNK_WRITE(V3) {
digitalWrite(RelayPin4, pinValue);
if (digitalRead(btnPin) == LOW) {
if (btnState != LOW) {
// Toggle LED state
ledState = !ledState;
digitalWrite(ledPin, ledState);
// Update Button Widget
Blynk.virtualWrite(V2, ledState);
btnState = LOW;
btnState = HIGH;
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
pinMode(ledPin, OUTPUT);
pinMode(RelayPin1, OUTPUT);
pinMode(RelayPin2, OUTPUT);
pinMode(RelayPin3, OUTPUT);
pinMode(RelayPin4, OUTPUT);
pinMode(btnPin, INPUT_PULLUP);
//TURN OFF all Relays on Start
digitalWrite(RelayPin1, HIGH);
digitalWrite(RelayPin2, HIGH);
digitalWrite(RelayPin3, HIGH);
digitalWrite(RelayPin4, HIGH);
// Setup a function to be called every 100 ms
timer.setInterval(100L, checkPhysicalButton);
I am really trying to figure out how to incorporate the example here:
but I cannot understand what I need to do.
