hello, good morning, I have a slightly strange problem, I have two esp32 in an industrial environment and I have done connection tests outside the factory and I have a pretty good range of 100m but when I put it in the factory they are about 15m from the router when I put it on new ones are fine but after a week they start disconnecting and connecting continuously and lose data. I have two esp 32 to the same router the router is gl-x300b. It has 300mpb and I don’t know if it could be the channel that is too busy. can someone help me to give a solution. Change from an esp8266 with external antenna to an esp 32 with external antenna. I also wanted to ask how you can change the reception channel of the esp 32 in blynk edgent. It’s too complex and I don’t really know where to do it without damaging it. Thanks for your help. all the best.I leave you my code in case there is any problem in it. Thanks for all, greetings
//14 aceite bajo
//35 analogica entrada temperatura 10k a ,masa y potenciometro de 100k puesto a 21k
//4 baliza roja
//12 llamada operario
//32 conteo caja
//33 final de averia
//pantalla lcd 128x64 st 7920---------------
//BLK-GND
//BLA-3,3v
//RST-22
//PBS-GND
//E -18
//R/W-23
//RS -5
//VCC-5v
//GND-GND
#define BLYNK_TEMPLATE_ID ""
#define BLYNK_DEVICE_NAME ""
//#define BLYNK_DEBUG
#define APP_DEBUG
#define USE_WROVER_BOARD
#include "BlynkEdgent.h"
#include <Arduino.h>
#include <U8g2lib.h>
#ifdef U8X8_HAVE_HW_SPI
#endif
#ifdef U8X8_HAVE_HW_I2C
#include <Wire.h>
#endif
unsigned long h;
int i = 0;
int j = 0;
int l = 0;
int n = 0;
int r = 0;
int k = 0;
int o = 0;
int q = 0;
int w = 0;
int x = 0;
int z = 0;
U8G2_ST7920_128X64_F_SW_SPI u8g2(U8G2_R0, /* clock=*/ 18, /* data=*/ 23, /* CS=*/ 5, /* reset=*/ 22); // ESP32 ACTUAL
int luzboton = 21;
int aceitedepo = 14;
unsigned long tiempo_guardado = 0 ;
unsigned long tiempo_guardado1 = 0 ;
int ma = 0;
float temp = 35; //etiqueta para lectura anal�gica PARA SENSOR DE TEMPERAURA
int y = 0;
//---------------------------------pines virtuales para la placa hacia la aplicacion
BLYNK_WRITE(V5) { //luz de botonera
int pinValue = param.asInt();
digitalWrite(luzboton, pinValue);
BLYNK_WRITE(V6) { //SENSOR MINIMO ACEITE DEL DEPOSITO esta asociada a la aplicacion atraves de V0 y V0 es correo
int pinValue = param.asInt();//asocia pinValue a un entero en este caso es V0 que es pin 5 de wemos que D1
digitalWrite(aceitedepo, pinValue);//V0 es correo
//-------------------------------------boleanos para los leds de la aplicacion.
WidgetLED led3(V2);//ESTE ES EL LED DE LA BALIZA ROJA ES UN BOLEANO QUE VIGILA LA SEÑAL PARA CAMBIAR DE ESSTADO
boolean btnState = false;
void ledblynk()
boolean isPressed = (digitalRead(4) == HIGH);
if (isPressed != btnState) {
if (isPressed) {
led3.on();
r = 1;
led3.off();
r = 0;
btnState = isPressed;
WidgetLED led4(V3);//ESTE ES EL LED DE LLAMADA DE OPERARIO ES UN BOLEANO QUE VIGILA LA SEÑAL PARA CAMBIAR DE ESSTADO
boolean btnState1 = false;
void ledblynk1()
boolean isPressed = (digitalRead(12) == HIGH);
if (isPressed != btnState1) {
if (isPressed) {
led4.on();
k = 1;
btnState1 = isPressed;
WidgetLED led5(V6);//ESTE ES EL LED DE NIVEL MINIMO DE DEPOSITO ES UN BOLEANO QUE VIGILA LA SEÑAL PARA CAMBIAR DE ESSTADO
boolean btnState2 = false;
void ledblynk2()
boolean isPressed = (digitalRead(14) == HIGH);
if (isPressed != btnState2) {
if (isPressed) {
led5.off();
unsigned long tiempo = millis();
tiempo_guardado = tiempo;
led5.on();
q = 0;
btnState2 = isPressed;
WidgetLED led6(V5);//ESTE ES EL LED de conteo de las cajas rodadas
boolean btnState3 = false;
void ledblynk3()
boolean isPressed = (digitalRead(32) == LOW);
if (isPressed != btnState3) {
if (isPressed) {
led6.off();
led6.on();
tiempo_guardado1 = tiempo;
x = 1;
delay(100);
btnState3 = isPressed;
u8g2.begin();
//-----------------------------------------LOGO DE JOHN DEERE Y SERVEO
logo();
timer.setInterval(1000L, ledblynk);
timer.setInterval(1000L, ledblynk1);
timer.setInterval(1000L, ledblynk2);
timer.setInterval(1000L, ledblynk3);
BlynkEdgent.begin();
pinMode(luzboton, OUTPUT);
pinMode(4, INPUT_PULLDOWN);
pinMode(12, INPUT_PULLDOWN);
pinMode(32, INPUT_PULLDOWN);
pinMode(33, INPUT_PULLDOWN);
BlynkEdgent.run();
//--------------------------------pines virtuales a aplicacion.
int llamadaoperario = 0;
llamadaoperario = digitalRead(12);// 12 LLAMADA OPERARIO ES U positivo LA SEÑAL ES DE ENTRADA
if ( (llamadaoperario == HIGH) && ( k == 1) && (o == 0))
digitalWrite(luzboton, HIGH);
Serial.println("se ha pulsado boton de llamada");
Blynk.logEvent("llamaope");
ledblynk1();
o = 1;
Serial.print("estado k llamada ");
Serial.println(k);
Serial.print("estado o llamada ");
Serial.println(o);
delay(5000);
//--------------------------------------parpadeo del boton cuando esta activa la averia
int lb = 0;
lb = digitalRead(21);//parpadeo del la luz de la botonera
if (lb == HIGH) {
digitalWrite(luzboton, LOW);
delay(300);
delay(300);
//--------------------------------------cuenta caja cada vez que se rueda 5 minutos seguidos para llevar preventivos en cuenta
int cuenta = digitalRead(32);//conteo cajas
if ((cuenta == 1) && (tiempo - tiempo_guardado1 >= 300000) && (btnState3 == LOW) && (x == 1)) {
w++;
z++;
x = 0;
delay(200);
Serial.print("caja rodada ");
Blynk.virtualWrite(V1, w);
Blynk.virtualWrite(V8, z);
Blynk.virtualWrite(V7, 33);// final averia ES positivo LA SEÑAL DE ENTRADA
int finalaveria = 0;
finalaveria = digitalRead(33);
if ((finalaveria == HIGH) && (o == 1))
led4.off();
Serial.println("se ha terminado la averia");
Blynk.logEvent("finalaveria");
o = 0;
delay(5000);
Serial.print("estado k terminada ");
Serial.println(k);
Serial.print("estado o terminada ");
Serial.println(o);
//++++++++++++++++++++++++++++++++++resear contador dos botones pulsados a la vez pulsado 10 segundos
if ((finalaveria == HIGH) && (llamadaoperario == HIGH))
w = 0;
delay(200);
delay(200);
delay(200);
//++++++++++++++++++++++++++++++++++analogica de temperatura
int pot = 0;
pot = analogRead(temp);
y = map(pot, 0, 4095, 0, 100); //funci�n map para escalado
//delay(1000);
Blynk.virtualWrite(V0, y);
//Serial.println(y);
if ( y >= 80)
Serial.println("temperatura alta");
Blynk.logEvent("tempalta");
delay(100);
//A ACTVAR CUANDO EL PROTOTIPO ESTE CORRECTO
/* int ram=0;
ram=digitalRead(luzboton);
if ( (ram==HIGH)&&(y<=80))
digitalWrite(5,HIGH);
Serial.println("resistencias apagadas manualmante");
Blynk.logEvent("aparesis");
delay(2000);
if ((tiempo - tiempo_guardado >= 10000) && (btnState2 == 1) && (q == 0)) //envia a los 10 segundos de falta de aceite
{ //para evitar parpadeos del sensor
q = 1;
Serial.println("bajo nivel de aceite");
Blynk.logEvent("minimoaceite");
delay(100);
ledblynk2();
delay(2000);
Serial.print("estado q llamada ");
Serial.println(q);
int bl = 0;// D2 BALIZA ROJA ACTIVA LA SEÑAL DE ENTRADA ES positivo
bl = digitalRead(4);
if ( (bl == HIGH) && (r == 0))
Serial.println("baliza roja encendida");
Blynk.logEvent("balizaroja");
ledblynk();
delay(2000);
Serial.print("estado r baliza roja ");
Serial.println(r);
h = digitalRead(14); // SENSOR DE ACEITE ES POSITIVO LA SEÑAL DE ENTRADA
i = digitalRead(26); // CONTEO DE PRUEBAS REALIZADAS
j = digitalRead(12); // LLAMADA OPERARIO ES un positivo LA SEÑAL ES DE ENTRADA
l = digitalRead(4); // BALIZA ROJA ACTIVA LA SEÑAL DE ENTRADA ES positivo
n = digitalRead(33); // final averia ES positivo LA SEÑAL DE ENTRADA
//-----------------------------------DIBIJO DE CUADROS Y SEÑALES DE ENTRADA Y SALIDA
u8g2.clearBuffer();
u8g2.drawRFrame(0, 0, 128, 10, 0);
u8g2.setFont(u8g2_font_u8glib_4_hr);
u8g2.drawStr(4, 7, "ENTRADAS Y SALIDAS ");
u8g2.drawStr(92, 7, "ESTADO");
u8g2.drawStr(4, 17, "SENSOR DE ACEITE.......");
u8g2.drawStr(4, 25, "NUMERO DE RODAJES....");
u8g2.drawStr(4, 33, "LLAMADA OPERARIO.....");
u8g2.drawStr(4, 41, "BALIZA ROJA........");
u8g2.drawStr(4, 49, "FINAL AVERIA.............");
u8g2.drawStr(4, 59, "TEMPERATURA ACEITE");
u8g2.drawRFrame(0, 9, 90, 55, 0);
u8g2.drawRFrame(89, 0, 39, 64, 0);
if (h == 0) {
u8g2.setCursor(93, 17);
u8g2.print("LLENO");
if (h != 0) {
u8g2.print("FALTA");
u8g2.setCursor(93, 25);
u8g2.print(w);
if (j == 0) {
u8g2.setCursor(93, 33);
u8g2.print("NO PULS");
if (j != 0) {
u8g2.print("PULSADO");
if (l != 0) {
u8g2.setCursor(93, 41);
u8g2.print("ACTIVA");
if (l == 0) {
u8g2.print("NO ACTV");
if (n != 0) {
u8g2.setCursor(93, 49);
if (n == 0) {
u8g2.setFont(u8g2_font_courB10_tf);
u8g2.setCursor(100, 61);
u8g2.print(y);
u8g2.sendBuffer();
//Serial.print("estado k final ");
//Serial.println(k);
//Serial.print("estado o final ");
//Serial.println(o);
//Serial.print("estado r final ");
//Serial.println(r);
//Serial.print("estado q final ");
//Serial.println(q);
//Serial.print("estado w final ");
//Serial.println(w);
void logo()
u8g2.setFont(u8g2_font_lucasarts_scumm_subtitle_r_tf);
u8g2.clearBuffer();
u8g2.drawRFrame(0, 46, 128, 64, 7);
u8g2.drawStr(4, 60, "SERVEO ");
u8g2.drawStr(0, 80, "in association ");
u8g2.drawStr(0, 100, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 44, 128, 64, 7);
u8g2.drawStr(4, 58, "SERVEO ");
u8g2.drawStr(0, 78, "in association ");
u8g2.drawStr(0, 98, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 42, 128, 64, 7);
u8g2.drawStr(4, 56, "SERVEO ");
u8g2.drawStr(0, 76, "in association ");
u8g2.drawStr(0, 96, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 40, 128, 64, 7);
u8g2.drawStr(4, 54, "SERVEO ");
u8g2.drawStr(0, 74, "in association ");
u8g2.drawStr(0, 94, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 38, 128, 64, 7);
u8g2.drawStr(4, 52, "SERVEO ");
u8g2.drawStr(0, 72, "in association ");
u8g2.drawStr(0, 92, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 36, 128, 64, 7);
u8g2.drawStr(4, 50, "SERVEO ");
u8g2.drawStr(0, 70, "in association ");
u8g2.drawStr(0, 90, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 34, 128, 64, 7);
u8g2.drawStr(4, 48, "SERVEO ");
u8g2.drawStr(0, 68, "in association ");
u8g2.drawStr(0, 88, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 32, 128, 64, 7);
u8g2.drawStr(4, 46, "SERVEO ");
u8g2.drawStr(0, 66, "in association ");
u8g2.drawStr(0, 86, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 30, 128, 64, 7);
u8g2.drawStr(4, 44, "SERVEO ");
u8g2.drawStr(0, 64, "in association ");
u8g2.drawStr(0, 84, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 28, 128, 64, 7);
u8g2.drawStr(4, 42, "SERVEO ");
u8g2.drawStr(0, 62, "in association ");
u8g2.drawStr(0, 82, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 26, 128, 64, 7);
u8g2.drawStr(4, 40, "SERVEO ");
u8g2.drawStr(0, 60, "in association ");
u8g2.drawStr(0, 80, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 24, 128, 64, 7);
u8g2.drawStr(4, 38, "SERVEO ");
u8g2.drawStr(0, 58, "in association ");
u8g2.drawStr(0, 78, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 22, 128, 64, 7);
u8g2.drawStr(4, 36, "SERVEO ");
u8g2.drawStr(0, 56, "in association ");
u8g2.drawStr(0, 76, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 20, 128, 64, 7);
u8g2.drawStr(4, 34, "SERVEO ");
u8g2.drawStr(0, 54, "in association ");
u8g2.drawStr(0, 74, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 18, 128, 64, 7);
u8g2.drawStr(4, 32, "SERVEO ");
u8g2.drawStr(0, 52, "in association ");
u8g2.drawStr(0, 72, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 16, 128, 64, 7);
u8g2.drawStr(4, 30, "SERVEO ");
u8g2.drawStr(0, 50, "in association ");
u8g2.drawStr(0, 70, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 14, 128, 64, 7);
u8g2.drawStr(4, 28, "SERVEO ");
u8g2.drawStr(0, 48, "in association ");
u8g2.drawStr(0, 68, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 12, 128, 64, 7);
u8g2.drawStr(4, 26, "SERVEO ");
u8g2.drawStr(0, 46, "in association ");
u8g2.drawStr(0, 66, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 10, 128, 64, 7);
u8g2.drawStr(4, 24, "SERVEO ");
u8g2.drawStr(0, 44, "in association ");
u8g2.drawStr(0, 64, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 8, 128, 64, 7);
u8g2.drawStr(4, 22, "SERVEO ");
u8g2.drawStr(0, 42, "in association ");
u8g2.drawStr(0, 62, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 6, 128, 64, 7);
u8g2.drawStr(4, 20, "SERVEO ");
u8g2.drawStr(0, 40, "in association ");
u8g2.drawStr(0, 60, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 4, 128, 64, 7);
u8g2.drawStr(4, 18, "SERVEO ");
u8g2.drawStr(0, 38, "in association ");
u8g2.drawStr(0, 58, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 2, 128, 64, 7);
u8g2.drawStr(4, 16, "SERVEO ");
u8g2.drawStr(0, 36, "in association ");
u8g2.drawStr(0, 56, " JOHN DEERE ");
u8g2.sendBuffer();
delay(20);
u8g2.clearBuffer();
u8g2.sendBuffer();
u8g2.clearBuffer();
u8g2.drawRFrame(0, 0, 128, 64, 7);
u8g2.drawStr(4, 14, "SERVEO ");
u8g2.drawStr(0, 34, "in association ");
u8g2.drawStr(0, 54, " JOHN DEERE ");
u8g2.sendBuffer();
delay(2000);
u8g2.setFont(u8g2_font_squeezed_b6_tr );
u8g2.clearBuffer();
u8g2.drawStr(0, 14, " ANGEL PALACIOS");
u8g2.drawStr(0, 34, " PATRICK KOLBUSZOWSKI ");
u8g2.sendBuffer();
well, I’ve been correcting the code and putting a timer in it and it’s cleaner. Well, what has been said, notice to surfers, if you put in SIM cards, take into account the sufficient bandwidth data.
the issue is resolved
