Dear all,
I’ve a problem with my Wemos D1 mini that still loss connection with Blynk server (sometimes in few minutes and sometimes in 3-4 hours).
The project uses a STH30 probe to measure temperature and humidity and a ACS712 to measure the power of the boiler. Data is send every 1 second. Also time, date and a check on pin D1 (to check if it is actually activated) are send to server every 1 second.
Is possible that is a flood error? As for the code I used only SimpleTimer for send data and no code has been edited in loop () section.
I’ve read the DOC section but I didn’t found “how many” measures for a time is possible to send.
This is the complete code, could you please help me? The project is very simple, but required me a lot of time to set up.
Thank you
//#define BLYNK_PRINT Serial
#include <WidgetRTC.h>
#include <WEMOS_SHT3X.h>
char auth[] = "XXXXXXXX";
char ssid[] = "XXXXX";
char pass[] = "XXXXXX";
#define pinout_d5 D5
#define pin_potenza A0
WidgetRTC rtc;
WidgetLED led_boiler(V3);
SHT3X sht30(0x45);
pinMode(pinout_d5, OUTPUT);
pinMode(pin_potenza, INPUT);
// Serial.begin(115200);
rtc.begin();
timer.setInterval(1000L, clockDisplay); //invia orario
timer.setInterval(1000L, statoBoiler); //invia se acceso o spento
timer.setInterval(1000L, inviaMisuraPotenza); //invia misura assorbimento e potenza
timer.setInterval(1000L, inviaMisuraTempHum); //invia misura temperatura e umidità
// recupera tutti i valori dal server nel caso in cui WeMas si spenga o resetti
BLYNK_CONNECTED() {
Blynk.syncAll();
BLYNK_WRITE(V1) // Button Widget writes to Virtual Pin V1
boolean valore = param.asInt();
if(valore == 1) {
digitalWrite(pinout_d5, HIGH);
else {
digitalWrite(pinout_d5, LOW);
BLYNK_WRITE(V2) // Widget timer writes to Virtual Pin V2
if(valore == 1) {
else {
// Digital clock display of the time
void clockDisplay()
// You can call hour(), minute(), ... at any time
// Please see Time library examples for details
String currentTime = String(hour()) + ":" + minute(); // + ":" + second();
// String currentDate = String(day()) + " " + month(); // + " " + year();
Blynk.virtualWrite(V50, currentTime);
// Blynk.virtualWrite(V51, currentDate);
void statoBoiler() //leggo lo stato fisico del pin D1
int state = digitalRead(D5);
if(state == 1) {
Blynk.setProperty(V3, "color", "#64C800");
led_boiler.on();
else {
Blynk.setProperty(V3, "color", "#FF0000");
led_boiler.on();
void inviaMisuraPotenza()
// misuro la potenza in ingresso =================
// int lettura_analog = 0;
float ampere = 0;
for (byte i = 0; i < 5; i++) { //Esegue l'istruzione successiva 5 volte
ampere += ((0.0322 * analogRead(pin_potenza) - 23.7) );
// lettura_analog += analogRead(pin_potenza);
ampere /= 5; //Calcola la media dei valori letti
// Serial.println(ampere);
// lettura_analog /= 5;
// Serial.println(lettura_analog);
float potenza = ampere*220;
Blynk.virtualWrite(6, potenza);
Blynk.virtualWrite(7, potenza);
Blynk.virtualWrite(5, ampere); // invia al pin virtuale 5 il valore della potenza
void inviaMisuraTempHum()
if(sht30.get()==0){
// Serial.print("Temperature in Celsius : ");
// Serial.println(sht30.cTemp);
Blynk.virtualWrite(10, sht30.cTemp);
// Serial.print("Temperature in Fahrenheit : ");
// Serial.println(sht30.fTemp);
// Serial.print("Relative Humidity : ");
// Serial.println(sht30.humidity);
Blynk.virtualWrite(12, sht30.humidity);
// Serial.println();
// Serial.println("Error!");
timer.run(); // esegue timer
