Please i am having issues with my blank app , i uploaded a blynk sketch and av done the required editing as regards wifi name and password, also authentication token
After uploading the code , my blynk app connects and disconnect almost immediately and am not even to know what exactly is going on , kindly help out , am using an esp32 board to controll just 16 relays , opening serial monitor i see the eap32 connected with blynk server but on my blynk app , it just connect and disconnect within 1 second
@Igbasan_Taye ive moved your post to a new topic, as it is not relevant to the topic that you originally posted in.
Please provide the following information…
Before creating the topic
• Smartphone OS (iOS or Android) + Blynk app version
• Blynk Library version
• Add your sketch code.
Code should be formatted as example below.
Your sketch in here……
Hello , please help me out with my Blynk app , it disconnect within 1 second after connecting with my esp32 , i know the code was successfully uploaded and that the wifi , pass and authentication token was rightly placed and i only picked the blynk sketch so i didn’t mess with anything , on the blynk app also i selected the wedge gave the right value and pin number . but it connect and disconnect almost immediately , what am i doing wrong please ?
Esp32_wifi
Android + blynk version 2.27.32
Blynk server
Blynk library version 1.0.1
http://twitter.com/blynk_app
This example runs directly on ESP32 chip.
Note: This requires ESP32 support package:
https://github.com/espressif/arduino-esp32
Please be sure to select the right ESP32 module
in the Tools -> Board menu!
/* Fill-in your Template ID (only if using Blynk.Cloud) */
//#define BLYNK_TEMPLATE_ID "YourTemplateID"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char auth[] = "t0o66sa5Y-r8xIexNICpbBTZ4bWyPNHD";
char ssid[] = "Longman's Note 8";
char pass[] = "Longman1";
You are using Blynk Legacy, so this should be library version 0.6.1
What does your serial monitor show?
It shows that the wifi is connected and blink server is connected also , but after that , nothing more
Copy and paste the serial output, and use triple backticks the way you did with your sketch.
I used my laptop to upload the codes and it still does the same thing , it connects with the blink server but on my phone , inside the blink app , it shows connected and disconnected almost instantly
Here is what the serial monitor is displaying
0dA⸮!⸮⸮
\B⸮⸮⸮⸮@[26] Connecting to Longman's Note 8
[2634] Connected to WiFi
[2634] IP: 192.168.43.172
[2634]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.6.1 on ESP32
[2709] Connecting to blynk-cloud.com:80
[3598] Ready (ping: 408ms).
And here is my code
#include <WiFi.h>
At the back of my esp32 board , i can see Esp32_DEVK1tc_v4 but on the board selection menu , i only have esp32 dev module ,
Will this in any way affect the result of the upload ?
You have a ping at 408 ms, that is abnormal.,
You should have less than 100 ms
Check the ping with your computer and show us the results and tell us the country where you live.
About esp32 choice it doesn’t matter.
@Igbasan_Taye please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Please do the same for your serial monitor output.
How do i reduce the ping to 100, please help with the steps
You never do what we told you.
How do i do check the ping ?
My country is Nigeria , why is that relevant to the code ?
Are you using your phone as a WiFi hotspot?
Yes i am using my phone as hotspot for the setup
