I am starting to blynk over USB serial; it works at home and now I tried to run the same sketch at work but get the following error
could it be the company firewall?
Connecting device at COM11 to cloud.blynk.cc:8442âŚ
OpenC0C("\.\COM11", baud=9600, data=8, parity=no, stop=1) - OK
Connect(): connect(âcloud.blynk.ccâ, â8442â) ERROR Unknown error (10061)
Reconnecting in 3sâŚ
Waiting for 0 seconds, press a key to continue âŚ
- This example shows how to use ordinary Arduino Serial
- to connect your project to Blynk.
- Feel free to apply it to any other example. Itâs simple!
- Optional, but recommended.
- Connect additional USB-serial adapter to see the prints.
- Edit auth token and upload this sketch.
- Run the script (script located in âscriptsâ folder of library root,
- e.g. âblynk-library/scriptsâ) for redirecting traffic to server:
for Windows: scripts/blynk-ser.bat
for Linux and OSX: ./scripts/blynk-ser.sh (may need to run with sudo)
- You can specify port, baud rate, and server endpoint like this:
./blynk-ser.sh -c <serial port> -b <baud rate> -s <server address> -p <server port>
- For instance :
./blynk-ser.sh -c /dev/ttyACM0 -b 9600 -s cloud.blynk.cc -p 8442
- Run blynk-ser.sh -h for more information
- Be sure to select the right serial port (there may be multiple).
- Attention!
Arduino IDE may complain with "programmer is not responding".
You need to terminate script before uploading new sketch.
- Start blynking!
- Start blynking!
SoftwareSerial SwSerial(10, 11);
#define BLYNK_PRINT SwSerial
#include <BlynkSimpleSerial.h>
char auth[] = âXXXXXXXXXXXâ;
WidgetLED led1(1);
WidgetLED led2(2);
SwSerial.begin(9600);
Blynk.begin(auth);
timer.setInterval(1000, sendUptime);
timer.setInterval(1000, blinkLedWidget);
timer.setInterval(1500, fadeLedWidget);
// Default baud rate is 9600. You could specify it like this:
//Blynk.begin(auth, 57600);
void sendUptime()
// Please donât send more that 10 values per second.
Blynk.virtualWrite(5, millis()/1000);
Blynk.virtualWrite(6, millis()/1000);
void blinkLedWidget()
if (led1.getValue()) {
led1.off();
BLYNK_LOG(âLED1: offâ);
led1.on();
BLYNK_LOG(âLED1: onâ);
void fadeLedWidget()
if (led2.getValue()) {
led1.off();
BLYNK_LOG(âLED2: offâ);
led2.on();
BLYNK_LOG(âLED2: onâ);
