Arduino UNO with Ethernet Shield
I connected ethernet shield to arduino uno and to the router using a cable .
but the serial gave this
Connecting to blynk-cloud.com:80
Packet too big :20527
Exactly which Ethernet shield are you using, and what chipset does it have?
I can’t read the chipset info from the photos.
You seem to have chosen the W5500 chipset from the sketch builder examples, was there a reason for this?
What happens if you try the other Ethernet chipset examples?
When you compile the code, do you get any warning messages about multiple versions of the Ethernet.h library being found?
I tried all the examples related to ethernet found in this link
https://examples.blynk.cc/?board=Arduino%20Uno&shield=Ethernet%20Shield%20W5500&example=GettingStarted%2FBlynkBlink
but the serial only shows : Getting IP…
On the chip " ethernet w5100 "is written .
Then that’s the sketch you should use in the sketch builder.
In the Arduino IDE, go to File > Preferences and choose Verbose output for compilation then re-compile your code.
Copy and paste the compiler output using CTRL C (don’t screenshot it) then post the compiler output here, with triple backticks at the beginning and end.
code:
http://twitter.com/blynk_app
You’ll need:
- Blynk App (download from AppStore or Google Play)
- Arduino Uno board
example.
#include <Ethernet.h>
char auth[] = "alVUxuiIYdU0C9-bNfDTV6U0DkbOP_Uz";
#define W5100_CS 10
#define SDCARD_CS 4
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
Blynk.begin(auth);
//Blynk.begin(auth, "blynk-cloud.com", 80);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8080);
// to avoid delay() function!
debug window :
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Doha\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10809 -build-path C:\Users\Doha\AppData\Local\Temp\arduino_build_69837 -warnings=none -build-cache C:\Users\Doha\AppData\Local\Temp\arduino_cache_198341 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr -verbose C:\Users\Doha\Documents\Arduino\uno_w5100\uno_w5100.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Doha\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10809 -build-path C:\Users\Doha\AppData\Local\Temp\arduino_build_69837 -warnings=none -build-cache C:\Users\Doha\AppData\Local\Temp\arduino_cache_198341 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr -verbose C:\Users\Doha\Documents\Arduino\uno_w5100\uno_w5100.ino
Using board 'uno' from platform in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\sketch\\uno_w5100.ino.cpp" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\sketch\\uno_w5100.ino.cpp" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\libraries\\Ethernet\\src" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\sketch\\uno_w5100.ino.cpp" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\libraries\\Ethernet\\src" "-IC:\\Users\\Doha\\Documents\\Arduino\\libraries\\blynk-library-master\\src" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\sketch\\uno_w5100.ino.cpp" -o nul
Using cached library dependencies for file: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\SPI\src\SPI.cpp
Using cached library dependencies for file: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Ethernet\src\Dhcp.cpp
Using cached library dependencies for file: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Ethernet\src\Dns.cpp
Using cached library dependencies for file: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Ethernet\src\Ethernet.cpp
Using cached library dependencies for file: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Ethernet\src\EthernetClient.cpp
Using cached library dependencies for file: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Ethernet\src\EthernetServer.cpp
Using cached library dependencies for file: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Ethernet\src\EthernetUdp.cpp
Using cached library dependencies for file: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Ethernet\src\socket.cpp
Using cached library dependencies for file: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Ethernet\src\utility\w5100.cpp
Using cached library dependencies for file: C:\Users\Doha\Documents\Arduino\libraries\blynk-library-master\src\utility\BlynkDebug.cpp
Using cached library dependencies for file: C:\Users\Doha\Documents\Arduino\libraries\blynk-library-master\src\utility\BlynkHandlers.cpp
Using cached library dependencies for file: C:\Users\Doha\Documents\Arduino\libraries\blynk-library-master\src\utility\BlynkTimer.cpp
Using cached library dependencies for file: C:\Users\Doha\Documents\Arduino\libraries\blynk-library-master\src\utility\utility.cpp
Generating function prototypes...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\libraries\\Ethernet\\src" "-IC:\\Users\\Doha\\Documents\\Arduino\\libraries\\blynk-library-master\\src" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\sketch\\uno_w5100.ino.cpp" -o "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\libraries\\Ethernet\\src" "-IC:\\Users\\Doha\\Documents\\Arduino\\libraries\\blynk-library-master\\src" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\sketch\\uno_w5100.ino.cpp" -o "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\sketch\\uno_w5100.ino.cpp.o"
Compiling libraries...
Compiling library "SPI"
Using previously compiled file: C:\Users\Doha\AppData\Local\Temp\arduino_build_69837\libraries\SPI\SPI.cpp.o
Compiling library "Ethernet"
Using previously compiled file: C:\Users\Doha\AppData\Local\Temp\arduino_build_69837\libraries\Ethernet\EthernetUdp.cpp.o
Using previously compiled file: C:\Users\Doha\AppData\Local\Temp\arduino_build_69837\libraries\Ethernet\EthernetServer.cpp.o
Using previously compiled file: C:\Users\Doha\AppData\Local\Temp\arduino_build_69837\libraries\Ethernet\socket.cpp.o
Using previously compiled file: C:\Users\Doha\AppData\Local\Temp\arduino_build_69837\libraries\Ethernet\Dhcp.cpp.o
Using previously compiled file: C:\Users\Doha\AppData\Local\Temp\arduino_build_69837\libraries\Ethernet\Ethernet.cpp.o
Using previously compiled file: C:\Users\Doha\AppData\Local\Temp\arduino_build_69837\libraries\Ethernet\EthernetClient.cpp.o
Using previously compiled file: C:\Users\Doha\AppData\Local\Temp\arduino_build_69837\libraries\Ethernet\Dns.cpp.o
Using previously compiled file: C:\Users\Doha\AppData\Local\Temp\arduino_build_69837\libraries\Ethernet\utility\w5100.cpp.o
Compiling library "blynk-library-master"
Using previously compiled file: C:\Users\Doha\AppData\Local\Temp\arduino_build_69837\libraries\blynk-library-master\utility\BlynkDebug.cpp.o
Using previously compiled file: C:\Users\Doha\AppData\Local\Temp\arduino_build_69837\libraries\blynk-library-master\utility\utility.cpp.o
Using previously compiled file: C:\Users\Doha\AppData\Local\Temp\arduino_build_69837\libraries\blynk-library-master\utility\BlynkTimer.cpp.o
Using previously compiled file: C:\Users\Doha\AppData\Local\Temp\arduino_build_69837\libraries\blynk-library-master\utility\BlynkHandlers.cpp.o
Compiling core...
Using precompiled core: C:\Users\Doha\AppData\Local\Temp\arduino_cache_198341\core\core_arduino_avr_uno_180a539c02cce575fcd7710170113f75.a
Linking everything together...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837/uno_w5100.ino.elf" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\sketch\\uno_w5100.ino.cpp.o" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\libraries\\Ethernet\\Dhcp.cpp.o" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\libraries\\Ethernet\\Dns.cpp.o" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\libraries\\Ethernet\\Ethernet.cpp.o" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\libraries\\Ethernet\\EthernetClient.cpp.o" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\libraries\\Ethernet\\EthernetServer.cpp.o" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\libraries\\Ethernet\\EthernetUdp.cpp.o" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\libraries\\Ethernet\\socket.cpp.o" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\libraries\\Ethernet\\utility\\w5100.cpp.o" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\libraries\\blynk-library-master\\utility\\BlynkDebug.cpp.o" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\libraries\\blynk-library-master\\utility\\BlynkHandlers.cpp.o" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\libraries\\blynk-library-master\\utility\\BlynkTimer.cpp.o" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837\\libraries\\blynk-library-master\\utility\\utility.cpp.o" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837/..\\arduino_cache_198341\\core\\core_arduino_avr_uno_180a539c02cce575fcd7710170113f75.a" "-LC:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837" -lm
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837/uno_w5100.ino.elf" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837/uno_w5100.ino.eep"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837/uno_w5100.ino.elf" "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837/uno_w5100.ino.hex"
Multiple libraries were found for "BlynkSimpleEthernet.h"
Used: C:\Users\Doha\Documents\Arduino\libraries\blynk-library-master
Not used: C:\Users\Doha\Documents\Arduino\libraries\blynk-library-0.6.1
Not used: C:\Users\Doha\Documents\Arduino\libraries\Blynk
Using library SPI at version 1.0 in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\SPI
Using library Ethernet at version 2.0.0 in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Ethernet
Using library blynk-library-master at version 0.6.1 in folder: C:\Users\Doha\Documents\Arduino\libraries\blynk-library-master
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\Doha\\AppData\\Local\\Temp\\arduino_build_69837/uno_w5100.ino.elf"
Sketch uses 20892 bytes (64%) of program storage space. Maximum is 32256 bytes.
Global variables use 722 bytes (35%) of dynamic memory, leaving 1326 bytes for local variables. Maximum is 2048 bytes.
serial:
[0] Getting IP...
[1694] IP:192.168.10.107
[1695]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.6.1 on Arduino Uno
[1814] Connecting to blynk-cloud.com:80
[1989] Packet too big: 20527
[6949] Connecting to blynk-cloud.com:80
[7085] Packet too big: 20527
[12044] Connecting to blynk-cloud.com:80
[12177] Packet too big: 20527
This looks a bit strange to me. You seem to have three locations where this Blynk library is installed. It’s impossible to tell from the information provided if the versions are all the same, but you need to do some clean-up of your libraries, and probably reinstall the Blynk library correctly.
hi mr PeteKnight, please i had the same issue like fatima except that i am using arduino mega2560 instead of uno?
this is debug window output
…C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\mustapha\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10612 -build-path C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\mustapha\Desktop\test\test.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\mustapha\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10612 -build-path C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\mustapha\Desktop\test\test.ino
Using board ‘mega’ from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core ‘arduino’ from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used…
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\sketch\test.ino.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\sketch\test.ino.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src” “-IC:\Program Files (x86)\Arduino\libraries\Ethernet\src” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\sketch\test.ino.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src” “-IC:\Program Files (x86)\Arduino\libraries\Ethernet\src” “-IC:\Users\mustapha\Documents\Arduino\libraries\Blynk\src” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\sketch\test.ino.cpp” -o “nul”
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src\SPI.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\libraries\Ethernet\src\Dhcp.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\libraries\Ethernet\src\Dns.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\libraries\Ethernet\src\Ethernet.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\libraries\Ethernet\src\EthernetClient.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\libraries\Ethernet\src\EthernetServer.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\libraries\Ethernet\src\EthernetUdp.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\socket.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5100.cpp
Using cached library dependencies for file: C:\Users\mustapha\Documents\Arduino\libraries\Blynk\src\utility\BlynkDebug.cpp
Using cached library dependencies for file: C:\Users\mustapha\Documents\Arduino\libraries\Blynk\src\utility\BlynkHandlers.cpp
Using cached library dependencies for file: C:\Users\mustapha\Documents\Arduino\libraries\Blynk\src\utility\BlynkTimer.cpp
Using cached library dependencies for file: C:\Users\mustapha\Documents\Arduino\libraries\Blynk\src\utility\utility.cpp
Generating function prototypes…
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src” “-IC:\Program Files (x86)\Arduino\libraries\Ethernet\src” “-IC:\Users\mustapha\Documents\Arduino\libraries\Blynk\src” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\sketch\test.ino.cpp” -o “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\preproc\ctags_target_for_gcc_minus_e.cpp”
“C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino10/ctags” -u --language-force=c++ -f - --c+±kinds=svpf --fields=KSTtzns --line-directives “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\preproc\ctags_target_for_gcc_minus_e.cpp”
Compilation du croquis…
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src” “-IC:\Program Files (x86)\Arduino\libraries\Ethernet\src” “-IC:\Users\mustapha\Documents\Arduino\libraries\Blynk\src” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\sketch\test.ino.cpp” -o “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\sketch\test.ino.cpp.o”
Compiling libraries…
Compiling library “SPI”
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\SPI\SPI.cpp.o
Compiling library “Ethernet”
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Ethernet\Dhcp.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Ethernet\Dns.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Ethernet\Ethernet.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Ethernet\EthernetClient.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Ethernet\EthernetServer.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Ethernet\EthernetUdp.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Ethernet\utility\socket.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Ethernet\utility\w5100.cpp.o
Compiling library “Blynk”
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Blynk\utility\BlynkDebug.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Blynk\utility\BlynkHandlers.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Blynk\utility\BlynkTimer.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Blynk\utility\utility.cpp.o
Compiling core…
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc” -c -g -x assembler-with-cpp -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring_pulse.S” -o “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\wiring_pulse.S.o”
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\WInterrupts.c.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\hooks.c.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\wiring.c.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\wiring_analog.c.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\wiring_digital.c.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\wiring_pulse.c.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\wiring_shift.c.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\CDC.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\HardwareSerial.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\HardwareSerial0.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\HardwareSerial1.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\HardwareSerial2.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\HardwareSerial3.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\IPAddress.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\PluggableUSB.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\Print.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\Stream.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\Tone.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\USBCore.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\WMath.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\WString.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\abi.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\main.cpp.o
Utilisation du fichier déjà compilé : C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\new.cpp.o
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\wiring_pulse.S.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\WInterrupts.c.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\hooks.c.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\wiring.c.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\wiring_analog.c.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\wiring_digital.c.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\wiring_pulse.c.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\wiring_shift.c.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\CDC.cpp.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\HardwareSerial.cpp.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\HardwareSerial0.cpp.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\HardwareSerial1.cpp.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\HardwareSerial2.cpp.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\HardwareSerial3.cpp.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\IPAddress.cpp.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\PluggableUSB.cpp.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\Print.cpp.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\Stream.cpp.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\Tone.cpp.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\USBCore.cpp.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\WMath.cpp.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\WString.cpp.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\abi.cpp.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\main.cpp.o”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar” rcs “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\core.a” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\core\new.cpp.o”
Linking everything together…
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc” -w -Os -flto -fuse-linker-plugin -Wl,–gc-sections,–relax -mmcu=atmega2560 -o “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353/test.ino.elf” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\sketch\test.ino.cpp.o” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\SPI\SPI.cpp.o” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Ethernet\Dhcp.cpp.o” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Ethernet\Dns.cpp.o” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Ethernet\Ethernet.cpp.o” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Ethernet\EthernetClient.cpp.o” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Ethernet\EthernetServer.cpp.o” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Ethernet\EthernetUdp.cpp.o” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Ethernet\utility\socket.cpp.o” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Ethernet\utility\w5100.cpp.o” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Blynk\utility\BlynkDebug.cpp.o” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Blynk\utility\BlynkHandlers.cpp.o” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Blynk\utility\BlynkTimer.cpp.o” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353\libraries\Blynk\utility\utility.cpp.o” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353/core\core.a” “-LC:\Users\mustapha\AppData\Local\Temp\arduino_build_728353” -lm
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy” -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353/test.ino.elf” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353/test.ino.eep”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy” -O ihex -R .eeprom “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353/test.ino.elf” “C:\Users\mustapha\AppData\Local\Temp\arduino_build_728353/test.ino.hex”
Utilisation de la bibliothèque SPI version 1.0 dans le dossier: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
Utilisation de la bibliothèque Ethernet version 1.1.2 dans le dossier: C:\Program Files (x86)\Arduino\libraries\Ethernet
Utilisation de la bibliothèque Blynk version 0.6.1 dans le dossier: C:\Users\mustapha\Documents\Arduino\libraries\Blynk
Le croquis utilise 19 296 octets (7%) de l’espace de stockage de programmes. Le maximum est de 253 952 octets.
Les variables globales utilisent 656 octets (8%) de mémoire dynamique, ce qui laisse 7 536 octets pour les variables locales. Le maximum est de 8 192 octets…
