Connecting to blynk-cloud.com:80 ESP8266
Hello, I am having connection issues trying to run my Wemos with blynk.
My code is the following (ESP8266 Standalone example):
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  This example runs directly on ESP8266 chip.
  Please be sure to select the right ESP8266 module
  in the Tools -> Board menu!
char auth[] = "token";
char ssid[] = "TP-LINK";
char pass[] = "Pass";
It works, but when I reset my router, blynk server does not connect again.
I have the follwoing message continuosly printed:
Any idea?
Thanks a lot,
Alberto
I fixed your code formatting, as requested in the instructions you deleted in order to post this :wink:
Blynk - FTFC
Lots…
  • Search this forum for keywords like connection management, reconnection, with or without WiFi, etc. :wink:
HINT, somewhere in here is one… C++ Blynk - Code Examples for Basic Tasks (Work in Progress)
  • Use Blynk.config() not Blynk.begin()
http://docs.blynk.cc/#blynk-firmware-configuration
  • And look in the Docs for connection management commands.
http://docs.blynk.cc/#blynk-firmware-connection-management
My code is just the ESP8266_Standalone example. Do you mean the example needs to be fixed?
No, it means the example is an example… for anything more advanced you need to research and learn.
I already referenced a more advanced example… did you look for it?
I just want to start with the most basic example and then try to do more dificult projects.
I took the following code from one of your examples:
  WiFi.begin(ssid, pass);
  Blynk.config(auth);
  Blynk.connect();
And same result:
[5421]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ / '/
//_, /////_
__/ v0.5.1 on Arduino
[5438] Connecting to blynk-cloud.com:80
[9629] Ready (ping: 1ms).
[109848] Connecting to blynk-cloud.com:80
[116509] Connecting to blynk-cloud.com:80
[123508] Connecting to blynk-cloud.com:80
[130508] Connecting to blynk-cloud.com:80
[137507] Connecting to blynk-cloud.com:80
[144507] Connecting to blynk-cloud.com:80
[151556] Connecting to blynk-cloud.com:80
[158556] Connecting to blynk-cloud.com:80
[165555] Connecting to blynk-cloud.com:80
[172581] Connecting to blynk-cloud.com:80
[179755] Connecting to blynk-cloud.com:80
[186829] Connecting to blynk-cloud.com:80
[193879] Connecting to blynk-cloud.com:80
[201003] Connecting to blynk-cloud.com:80
[208078] Connecting to blynk-cloud.com:80
[215178] Connecting to blynk-cloud.com:80
[222252] Connecting to blynk-cloud.com:80
[229426] Connecting to blynk-cloud.com:80
[236476] Connecting to blynk-cloud.com:80
[243651] Connecting to blynk-cloud.com:80
At [109848] I reset the router and after that, blynk does not reconnect.
No, and it won’t until you add in a bunch more code to make it try to reconnect… as I said, look at the more advanced examples :wink: Check that first link I supplied…
Try using Blynk.begin(auth, ssid, pass);
@ldb OP was already using that :wink: … issue is reconnecting after reset of router. One solution has already been supplied
All good, I suppose didn’t read the beginning properly. :slight_smile:
