So I wanted to use a custom server so I had to find a copy of the repo because the github repo had been deleted and so I ended getting one working on my raspberry pi and I made a project with the custom server and got authentication tokens sent from it and I put them into my sketch and upload to my esp8266 board and I check the serial monitor and I see that it says [816377] Connecting to 192.168.0.32
[816531] Invalid auth token
and I have tried using multiple tokens and it still hasn’t worked, please help me fix this
just for reference here is my code
http://twitter.com/blynk_app
This example runs directly on NodeMCU.
Please be sure to select the right NodeMCU module
in the Tools -> Board menu!
For advanced settings please follow ESP examples :
- ESP8266_Standalone_Manual_IP.ino
- ESP8266_Standalone_SmartConfig.ino
- ESP8266_Standalone_SSL.ino
/* Fill-in your Template ID (only if using Blynk.Cloud) */
//#define BLYNK_TEMPLATE_ID "YourTemplateID"
char auth[] = "8m5RAH9e-y4j6-N0Ig2Cj3gJ2YxsgQR0";
char ssid[] = "I do not want to show my wifi";
char pass[] = "or my wifi password";
// You can also specify servers
Blynk.begin(auth, ssid, pass, IPAddress(192,168,0,32), 8080);
